I have just bought a durabrand mp3 player and can only fit 4 tracks before the memory is full. how do i compress the tracks to give me the maximum listening time.
MP3 players can only play music files in mp3 file format.
You can download mp3 music files from the Internet to
your computer and then copy them to your MP3 player using the USB cable.
For your CD collection, you need to convert your CDs to
mp3 music files onto your computer or download them from the Internet and then
copy them to your MP3 player after you have connected the USB cable to
the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will
create a MP3 music file for each music track.
Click on this link for instruction on converting music
files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Change the Rip Format in Windows Media Player to mp3 instead - WAV's take up too much space, and the player will only play its own WAV's that it creates using the record feature anyways. For regular music files, you always want mp3 format.
Hi FixYa.My Guru Dili sugested I use software to convert the wav format ,which he said was taking up to much disc space .On converting the wav format to MP3 I have found that the conversion did not reduce the MB sum considerably less than the wav format .However I have tried reducing the rip speed on my media player but I have yet to compare the output quality of the sound at the reduced rip speed on my MP3 player .So for Windows XP,- media player,- rip options, then alter the scale down to a lower scale reading . Si.
if your mobile supports OGG format. then you can convert MP3-OGG format. OGG format can hold 200 songs on 1GB memory card. use Mp3-OGG convertor.Similiarly you can also AAC format. But compared to OGG AAC files requires bit more space
This can some times be caused by VBR audio encoded files as opposed to CBR audio some standalone DVD players will exhibit sound lag in this case. It is a good idea to re-encode the VBR to CBR audio this usually solved the problem.
Although this is usually with DivX (AVI) files that have been re-authored to DVD-Video I suggest that you convert all audio to CBR to avoid any such errors.
this conversion process it a bit of a long way around I know, but it does work!
1) Open video in VirtualDubMod or VirtualDubMP3 (if there is an index error this can sometimes fix it for you.
2) Ignore the error warning that the video contains vbr audio.
3) Extract audio as mp3 ("demux" in VdubMod or "save as wav", then rename to mp3 in VdubMP3).
5) Open original video in VirtualDub,
choose "direct stream copy" for video and "Wav audio" with "Full audio
processing" with cbr mp3 compression (and interleaving with appropriate
delay if out of sync) for audio.
You could also use several other methods including AVIDemux which uses VDub Mod or scan in the DVD-Video using TMPEnc v4.0 Xpress and applying a time lead OR lag however this doex not solve a progressive lag but can be used to reauthor a fixed error.
