Round 478,432.341 to the nearest hundred. - Office Equipment & Supplies
3 Suggested Answers
  • 8064 Answers
SOURCE: ACME Skateboards Inc., has paid
Doesn't any body do their homework anymore? How are they supposed to learn anything?
Draw your graphs by hand or on a graphing calculator.
Think about the intersection points. (What does that mean when two curves intersect?)
Use the equation for the demand to obtain D for a particular x.
You can also determine by how much one function exceeds another for a particular value of the x variable (the graph is rather clear).
I assume you can solve a quadratic equation.
Use these hints to solve the problem.
Here is a graph. I even restricted it to the first quadrant so as not to mislead you into giving meaningless answers.
Hope it helps.
Posted on Oct 04, 2009
SOURCE: i need to round 301,421,
Well that would be... 301,500,000 rounded UP, or 301,400,000 rounded down.
BUT the second answer, 301,400,000... is YOUR answer....
The nearest hundred thousand is 400,000... hence the answer, see?
Posted on Aug 19, 2010
How do you round 5,403.264 to the nearest hundred
Assuming you do mean to the nearest hundred, answer the question 'is this number closer to 5400 or 5500?' It is closer to 5400 (The first digit to the left of the decimal point is 'ones', the second place is 'tens', the third place is 'hundreds', so you look at the third digit to the left to round to the nearest hundred)
If, in fact, you meant hundredth, answer the question 'is it closer to 5403.26 or 5403.27?' It is closer to 5403.26 (The first digit to the right of the decimal point is 'tenths', the second digit is 'hundredths', so you look at the second digit to the right to round to the nearest hundredth)
Sep 17, 2014 | The Learning Company Achieve! Math &...
I neeed to round 740,692 to the place value
Round to which place value?
To the nearest million: 1,000,000
To the nearest hundred thousand: 700,000
To the nearest ten thousand: 740,000
To the nearest thousand: 741,000
To the nearest hundred: 740,700
To the nearest ten: 740,690
Sep 02, 2014 | Office Equipment & Supplies
How can i round to the hundreds or thousands?
Put the calculator in scientific display mode (SHIFT>MODE(Setup)>FIX. You will be asked to enter the number of fixed decimal digits. Enter 2 for hundredths, and 3 for thousandths. To round to the nearest hundreds or the nearest thousands, do it by hand as follows.
For hundreds
Locate the hundred digit. Let it be h.
If the next digit (the tens digits is less than 5 replace the 10 and unit digits each by 0. Your result will look like ...h00.
If the 10s digit is 5 or above (5, 6, 7, 8, 9) you must round up by increasing the hundreds digits by 1. Your result will look like ...(h+1)00
For thousands
Let the thousand digits be t
If the hundreds digits to its right is less than 5, replace it and the digits following it by 0. Your result will look like ...t000.
If the hundreds digit is 5 or higher, increase the thousands digits by 1 and replace the hundreds, tens, and units digits by 0. You result will end with (t+1) 000
Note if (h+1) or (t+1) give you 10, put a zero at their positions and increase the digit to the left by 1.
Example. 78997 to the nearest hundreds 78997 becomes 789(9+1)0 or 78(9+1)00 or 79000
May 22, 2014 | Casio FX-115ES Scientific Calculator
53017 round to the nearest hundreds
The same way you would do it if the digit is something other than zero.
53017 rounded to the nearest hundreds is 53000.
Feb 14, 2014 | Office Equipment & Supplies
Round off to the nearest hundred 2x12x0.23
2x12x0.23 is 5.52. 5.52 rounded to the nearest hundred is 0 (zero).
If you want the result rounded to the nearest hundredth, it's 5.52.
Feb 04, 2014 | Office Equipment & Supplies
Round to nearest hundred thousand
Round what to the nearest hundred thousand? On what make and model calculator?
Oct 18, 2013 | Office Equipment & Supplies
How to round off 41 to the highest value
What do you want to round it to? To the nearest unit, 41 is 41. To the nearest ten, 41 is 40, to the next highest ten, 50. To the nearest hundred, 41 is 0, to the next highest hundred, 100.
Jan 10, 2013 | Office Equipment & Supplies
I need to round 301,421, 900 to the nearest hundred thousand can you help me?
Aug 19, 2010 | Casio MS-80TE Calculator
158 people viewed this question
k24674
jasbo
jasbo
