Question about Garden
My John Deere 5325 tractor ignition doesn't start, tried restarting the battery, still nothing. what's my best bet?
2 Suggested Answers
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
LX176 John Deere lawn tractor doesn’t get power to the starter, I have replaced the ignition switch and still nothing. Can anyone help?
Oftentimes there are switches at the blade engagement lever and under the seat...for safety reasons. I can't start my mower if the blade drive is engaged and /or I'm not in the seat. That's a clue to check , however I'd check the starter solenoid first.
Oct 17, 2017 | John Deere Garden
Does anybody know why steering column doesn't lock on a 5325 john deere tractor?
Its likely worn out.The key switch could be working fine but their is a pin that locks the column spring loaded that maybe worn or damaged or the column tube that receives the pin .
As long as it runs OK and the steering wheel turns its not going to effect anything else but the steering lock .
Oct 28, 2016 | John Deere Garden
I have a 5325 john deere tractor, 7 it's steering column does not lock
And you are sure it has this feature, many newer equipment types don't.
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
