Question about Sony BDVE300 Theater System
Sony DHC FLX5D DISC TRAY DOESNT OPEN - Sony BDVE300 Theater System
  • 3 Answers
SOURCE: Everytime I try to open the disc tray it flashes either EX-Change or mechanical error and won't open
I have a Sony MHC-GX555 stereo and every time I try to open the disc tray it either flashes EX-Change or mechanical error and it won't open.
Posted on Jun 18, 2009
  • 1810 Answers
SOURCE: disc tray on RDR-HX720 doesn't open and display
1 of 2 things
can you hear the motor running inside the player ????
there is usualy a snall pin hole under the tray insert a paper clip into this hile and push it in if tray starts to auto open it might be just a dry set of rails
if rails asumed dry open unit and coat the rails with anti seize and try again with the switch on front cover
Posted on Aug 03, 2009
SOURCE: disc tray will not open
I've not found one, no, but I have managed to strip the machine down, get the disc out and rebuild... I guess this is too late for you but it's simple enough if you're still trying.
Posted on Mar 28, 2010
  • 70 Answers
SOURCE: I have a Sony DHC
Sounds like laser unit is faulty, can get it replaced by repair shop.
Posted on Jan 02, 2011
gopakumarg43
  • 74383 Answers
SOURCE: sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
Posted on May 15, 2012
System DHC-FL5D shows a red light near power on switch but won't start
inside, some flap cable may have been disconnected. get it serviced. also let me know if you want to sell.
Apr 25, 2015 | Sony Audio Players & Recorders
Digipad Remote for sony Hifi FLX5D is constantly sending signals
Basically what is wrong is that the remote should be replaced.
Jan 16, 2014 | Sony Televison & Video
Sony DHC FLX5D hifi system shows a red light near power on switch but won't start
You opened the case to check the fuses, do that again and look at the devices that resemble small cans. See if the are bulging, leaking or exploded.
Jan 06, 2014 | Sony Audio Players & Recorders
Sony HCD FLX5D not turning on
I know Ashish you fixed it but which transistor was it? Can you please let me know as i have the exact same problem....
Jan 05, 2014 | Audio Players & Recorders
How do i get my sony dvd off lock
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 23, 2010 | Sony Televison & Video
Disc tray doesn't open
Unplug and plug in the powercable then try again. Be sure that the cable goes in the powerslot as far as it needs.
Good luck to you
Dec 12, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Surround speakers don't work
Check which Channel you are using on the Remote. i.e. 2.1 Multichannel or Auto the Centre Speaker and the 2 rear speakers don't work if its 2.1 channel setting
Feb 22, 2008 | LG LHT734 System
I can not eject the disc tray
I too had a similar problem with my DHC FL7D. The front moving panel would not move up. The screen used to say 'please wait' endlessly whenever I pressed the DVD button. I thought the drive belt might have got cut. There is a drive belt for the front panel to move upwards and downwards. Since that was intact, I disconnected the front panel from the main body to access the DVD drive system. I had to disconnect many cables and PCBs to do so. Then I opened the DVD compartment and removed all the DVDs which were stuck and re-alligned all the disc trays to its original state. I checked if all the drive belts inside the DVD compartment, it was ok. Also I tried moving the laser lens assembly to check if it was moving. Since there was no problem I closed the system. <br />After I switched on it worked again . I think it might be to do with the fact that the disc trays might have been stuck for some reason or may be the there was a software glitch.<br />
Jan 08, 2008 | Sony DHC-FL7D System
Sony BDVE300 Theater System Logo
69 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
