Question about Garden
Need a spark plug wire and solenoid for lesco walk behind blower
  • 3 Answers
SOURCE: changing spark plug wires
WEll u dont need to remove anything This is what i did lift your car up with a jack. where you oil filter is you will see you plug wires running into your (ICM) Ignition Module unplug them and slide them to the top of your motor. dont get them mixed up otherwise your timeing will be messed up and your car wont start. on the ICM from the top to bottom the plug numbers are 2,3,1,4 and on top of the moter from left to right 1,2,3,4 just make for sure u have the right order..
Posted on Sep 16, 2008
  • 571 Answers
SOURCE: Need a manual and the spark plug number and gap
Find the model no. on the mower. The first 3 numbers such as 123.45678 the 123 is the sears mfg code. Google "sears mfg codes" and you will get a lot of hits. Find one that gives complete llist (as some just give appliances). Find mfg. Then go to their website and you will then have to find your mower. Sometimes this is very hard to do, but if you can find one that will let you look at the mowers, you should find it. You can then print you a manual and order parts at a much lower price also. Or you can call sears 800 no. for parts and they can probably provide you with the manual, at a cost.
Posted on Mar 30, 2009
  • 109 Answers
SOURCE: what size spark plug
Champion J-19
Posted on Apr 29, 2009
  • 133 Answers
SOURCE: i have a walk behind mower with a 14 hp kawasaki
Try cleaning the magnets on the fly wheel. Use emery cloth or fine sandpaper. Also clean the little prongs by the fly wheel.
Good luck
Posted on Sep 01, 2009
  • 279 Answers
SOURCE: My walk behind mower wont start..has no spark with
Rust on the magneto has no bearing on the output of a spark. The magneto or the points if it has them could be the problem. If the unit has points they may be under the flywheel. If so equiped, that would be the logical place to start. If no points, I would replace the magneto. When you place the new one on, place a piece of paper between the flywheel and the magneto. When you tighten the magneto, pull out the paper and turn the flywheel by hand. If the magneto turns without touching, put everything together and try it out. Good luck...Lee
Posted on Sep 09, 2009
Toro 52" walk behind with Fb460v kawasaki has no spark
Sounds like your off on switch may be grounded.
Oct 07, 2014 | Garden
Why would Lesco Walk Behind Mower get no fuel?? Has New Pump and Fuel Filter
Be sure your petcock is in the open position. Not uncommon to forget to open it after working on the carb
Jun 17, 2014 | Garden
Where safety switches are located on lesco walk behind commericial lawn mower?
usually the only safety is the engine shut down control cable that is attached to a smaller handle on the main handle that you must hold to have the mower to start and run part number for the cable is 946-0957
May 29, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
Walk behind leaf blower shuts off when it gets hot
When a failing coil gets hot they quit putting out spark
Sep 14, 2013 | Briggs & Stratton 190cc 875 Series OHV...
Toro walk behind model 20016. The starter rope did not break it just won't pull out??? HELP
Remove the rope case and see if it is the mower -also - remove the spark plug and try it - also - - after removing the spark plug - also -try spinning the blade. If you remove the top you will see the problem sooner.
Gary @ Fix Ya
Sep 09, 2010 | Toro Lawn Mower With Toro Power Tools
HELP, 2007 Toro walk behind mower
There is a drain plug on the block of the motor usually it looks square. if its not behind the blade on the under carriage, then it will be on top above the blades were the motor is visible. you may have to tip the mower on its side to completely drain all the oil. but the plug is always going to be on the motor either on the side or on the bottom. if the plug is on the bottom were the blade is remove the spark plug wire first. a mower can start if you turn the blade by hand and that would be vary bad news so always take the spark plug wire off and make sure it can not come in contact with the spark plug before going underneath the mower.
Jul 30, 2009 | Garden
Garden Logo
21 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
