Question about Canon imageRUNNER 2200
Ir error code machine cannon e0024 001 - Canon imageRUNNER 2200
skone
  • 20 Answers
SOURCE: Cannon IR 2200
OK i am having the same problem but here is the solution that I have found online that I am going to try in the next 5 minutes:
waste toner container is placed left-rear side of the machine. Take out one screw,small cover will come out then pull out plastic container. Empty the container and clean the head really well as this can cause problems with the fuser.
good luck!
Posted on Nov 28, 2008
  • 6 Answers
SOURCE: Cannon IR 3100 CN Itermediate Transfer Belt error code E00070-000
The E00070-000 is not a ITB problem, but a full wastetoner. Open the front cover find the white bottle in the middle, remove the black screw, remove the cover over the top of the bottle and empty the bottle. Be sure to clean the top of the bottle so the sensor can see that the bottle is empty. Restart the copier.
Posted on Jun 07, 2009
SOURCE: Canon IR C3200 Error Code E000020-03C0?
plz tell me reason of e602 code in canon ir c3200
Posted on Nov 20, 2009
  • 525 Answers
SOURCE: My xerox machine cannon IR
E007 - Fixing film rotation error
You have to disassemble fuser unit and inspect a fixing film, if damaged - replace.
The official documentation says:
E007 0000 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
Posted on Jan 20, 2011
spinal
  • 287 Answers
SOURCE: my cannon ir 2018i has error code [E000007, we've
Hi robin,
Hope you are well. I participate in the FIXYA forum to help people, and it makes me smile when when I can help folks avoid costly repairs. I don't get paid, (yet) :-) despite the fact the fact I am rated as expert/guru. Anyway.... I dont have good news. Your copier (as all do) has an assemby called a fixing unit/fusing unit. This is an area that by heat and pressure "bonds" the toner to the paper. Because of the extreme heat, all copiers monitor this assembly closely. Your error code means that the copier cannot accurately determine the speed of the fixing assmbly. Which would be like letting an iron rest in one spot rather than moving back and forth across the clothes. The fixing assembly must be replaced.The part # is FM3-3651-000. The first problem is that Canon wont sell parts like this to the general public. Then of course comes, who has the ability to replace it, as it is not really an intuitive repair. It could be done by a layperson, but....... I am so very sorry than I could not "FIXYA" but I hope I have given you enough info that you you won't be in the dark when and if you decide to seek professional help. All dealers have different rates for labor and parts markup. My company charges $150 an hour. The part is about $100. $250 sounds like the ball park. Please be kind enough to provide as favorable review to my time and help as you can when you report to "FIXYA". I wish you the best. SPINAL
I have IR Canon 2420 copier machine it shows E000007-0000 please help me what is the problem Thank yoyu
as the error codes are cannon specific I suggest that you contact a canon service dealer and ask them what the codes mean
Sep 03, 2015 | Canon Office Equipment & Supplies
How to go service mode Cannon ir 400 ?
Here is the error code page http://www.scribd.com/doc/56428927/iR-400-Code-List
And here is the service manual
http://www.scribd.com/doc/135167936/canon-Ir-400-Service-Manual
Looking at what the error is, getting into the service mode will not allow you to fix it; you have some parts to replace first.
Jul 20, 2014 | Cannon Office Equipment & Supplies
Cannon 3200 when machine has warmed up error code 000732-001
This is a reader communications error. It's been a long time since I worked an IR-C3200 copier but all cables must be plugged in. They will only go where they were intended to go. Reseat all those cables and good luck, other wise you have a professional help problem. Make sure all the cable checks are done with power off. Then power up agai n and see what happens.
May 07, 2017 | Canon imageRUNNER C3200 Color Printer
Error code E000005-0001 cannon ir-adv 6055
I have a problem with my machine,
Canon IR 6570 with error code E000005-0001
beg for a solution
Nov 09, 2011 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
IR 400 MACHINE ERROR CODE IS E803-000
E 803 Codes are Coming IN Cannon IR 400 Copier Machines.Need the solution For How to olve it?
Oct 21, 2010 | Canon imageRUNNER 400S Copier
My cannon ir 3300 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
My cannon ir 2200 machine show me Error code E 000530-0000 from last 2 days please give me solution for emergency
Sep 09, 2010 | Office Equipment & Supplies
Canon ir 7086 error code e00005-0010
give me the solusion of error code 225 of machine cannon 7086
reply plzzzzzzz
Apr 07, 2010 | Office Equipment & Supplies
Our Canon Image Runner 330S shows error message E014....
is there an error code appear on panel display?
if there a error appear try to reset you may press * key,press 2&8 simultaneously, the select copier then select fuction then clear then error then ok then turn off& on
Jan 04, 2010 | Canon imageRUNNER 400S Copier
Canon imageRUNNER 2200 Logo
52 people viewed this question
old marine
old marine
