Question about JVC KD-G421 CD Player
WHAT DOES 000A MEAN - JVC KD-G421 CD Player
I have a sentry safe and the paper work is inside of the safe for the factory code
call a locksmith and ask what the factory code is for your make and model safe
it will be a simple combination like 0000 or 000a and when the safe is open the instructions will say how to set the code for you
write it down somewhere and put in a place easily remembered but secure --not back in the safe
Oct 30, 2016 | Home Security
Can i know E315 000A is what problem
The error code E315 is caused by the Reader Controller not communicating with the feeder controler, try replacing the Reader Controller to correct
Mar 19, 2010 | Canon imageRUNNER 5000 Copier
Have got pioneer xv-dv303 dvd/cd receiver.It does not play any dvd and cd these days. I think it needs the firmware update. How can do that.
You need:
PDA w/Palm OS 3.0 or later
OmniRemote Pro V2.02 (http://www.pacificneotek.com/)
Sony Clie peg-SL10
Type in (or transfer) the memo below to your PDA.
As a memo you can import it into OmniRemote with this menu command:
Advanced-->Databases-->Import category
When done, point your PDA towards your DV-454, put OmniRemote in TV-mode and press 0 (Zero)
That's it!!
Some stores charge $35 for this! All I ask is a small donation ($1 or more if you like) to help my site!
Memo (Name: Category-TV):
Category-TV
Button name-Enter
0000 0067 0000 0000
Button name-0
0000 0069 0049 0000 0154 00AA 001E 0032 0019 003C 001E 000F 0019 000F 001E 000A 001E 0037 0014 0005 0005 000A 001E 0037 001E 000A 001E 000F 0014 003C 001E 0037 001E 0037 0014 0014 001E 0037 0014 0014 001E 0037 001E 000A 001E 000A 001E 0037 001E 0037 001E 000A 001E 000A 0019 003C 001E 000F 0014 003C 001E 0037 001E 000A 001E 000F 0014 0005 0005 0032 001E 0037 001E 000A 001E 045B 0154 00AA 001E 0032 001E 0037 001E 0037 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 0014 0014 001E 000A 001E 000F 0019 000F 001E 0037 0019 000F 001E 0037 0019 000F 001E 0037 0014 0014 001E 0037 001E 0032 001E 000F 001E 0032 001E 000F 0014 0005 0005 0037 0019 000F 001E 0037 0019 000F 0014 0005 0005 000A 001E 0037 001E 000A 001E 0037 001E 0037 0014 0465 014F 0000
Button name-7
0000 0067 0000 0000
Button name-8
0000 0067 0000 0000
Button name-9
0000 0067 0000 0000
Button name-4
0000 0067 0000 0000
Button name-5
0000 0067 0000 0000
Button name-6
0000 0067 0000 0000
Button name-1
0000 0067 0000 0000
Button name-2
0000 0067 0000 0000
Button name-3
0000 0067 0000 0000
Button name-Channel up
0000 0067 0000 0000
Button name-Channel dn
0000 0067 0000 0000
Button name-Last
0000 0067 0000 0000
Button name-Volume up
0000 0067 0000 0000
Button name-Volume dn
0000 0067 0000 0000
Button name-Mute
0000 0067 0000 0000
Button name-Power
0000 0067 0000 0000
Button name-Favorite
0000 0067 0000 000
Feb 11, 2010 | Pioneer XV-HTD520 Multi-disc DVD Player
Needs ethernet drivers
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCG-V505ECP&region_id=1
Link to the page . Go down to network file, download and save to a disk or stick from another computer of course. Use whatever media you put it on to install on your laptop.
If this was helpful please rate.
Oct 03, 2009 | Sony VAIO PCG-V505CP Notebook
Need to install driver
Just go to this page to get the drivers you need:
http://www.brother-usa.com/printer/modeldetail.aspx?PRODUCTID=HL2040&tab=supp
Let me know if it solved your problem.
Sep 23, 2009 | Brother HL-2040 Laser Printer
I have got a zyxel and i cant conect to internet with my itouch. The wifi work fine with any other computer wireless and cabeled. If i let the dhcp server do its job then it gives it a incorrect ip address...
Windows detected a new device attached to your computer, but could not find the driver software it needs to make the device usable. Each device manufacturer typically includes driver software of a CD that comes with the device, or as a download from its website. The hardware ID of your device is BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000a.
Problem signature:
Problem Event Name: PnPDriverNotFound
Architecture: x86
Hardware Id: BTHENUM\{00005005-0000-1000-8000-0002ee000001}_LOCALMFG&000a
OS Version: 6.0.6001.2.1.0.768.3
Locale ID: 2057
Aug 11, 2009 | Zyxel ZyAIR B-220 Wireless LAN USB Stick...
Website building
I suggest you this way, keep these ways:
1. At first learn HTML,DHTML,XML languages (these languages are the base of web designing, and easy to learn, Don't worry about it!)
2. Learn Frontpage
3.Learn Photoshop
4. Learn Dreamweaver
And if you have enough time learn
5. Freehand
6. Flash
Good luck
Jul 08, 2008 | @ Your E-Service Intro to Web Design...
Outlook calendar will not synch to handheld
Here are two resource pages which hopefully will help. The first is Palm support page with an update to download for users of Outlook 2003. The second is a discussion thread of Treo users troubleshooting the same problem. Even if the PDA is different, the issue (and error code) is practically the same, Rather than cut and paste what I think is relevant, read the thread and see if one of the solutions listed helps you.
http://www.palm.com/us/support/downloads/pim_update.html
http://discussion.treocentral.com/archive/index.php/t-96051.html
Let us know how you make out.
PS - What PDA, operating systems (PC and PDA) and version of Outlook are you using?
Jan 05, 2008 | Palm Tungsten E2 Handheld
Used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
Sep 10, 2007 | Washing Machines
JVC KD-G421 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
