Question about HP OfficeJet 7310 All-In-One InkJet Printer
Paper jam on my hp 7310 all in one
My printer is twisting the paper as it pulls it in causing a paper jam. I have pulled the paper out but it continues to do the same thing. What do I do?
  • Wilkie14 Apr 24, 2009
    I have the same problem, I was printing an envelope and it twisted and jammed. As I pulled it back it tore and a piece is stuck inside. Now all my paper twists and jams everytime. How do I open the insides of the machine to clear this up?
sandrew
  • 2961 Answers
SOURCE: HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Posted on Jun 24, 2007
SOURCE: HP PSC 2355 paper jam
I had the same problem. When I inspected the printer inside I detected that on the right sight of the metal thing that's guide te cartridge holder some plactic piece had broken.
When I glued it, everything went OK for a couple of minutes. Because of the presure on that plastic nock it broken again and the same error appeared on the screen.
Posted on Apr 19, 2008
SOURCE: How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
Posted on Apr 20, 2008
  • 685 Answers
SOURCE: I have a paper jam
On that printer, you can't pull out the main tray. This video shows how to clear a paper jam on the C7280.
Posted on Jun 17, 2009
bob_computer
  • 3153 Answers
SOURCE: My printer pulls in about 8 sheets of paper at
It may think there is a jam because it expected lets say a single A4 and when it shot the paper through the sheets became separated a little so it looked longer than a sheet of A4.
A real easy way on ensuring that you don't get too many of these situations is not to overload the feed tray. Also just before you put the paper in do the "desktop shuffle" separate it a little then tap the sheets back together on the table both top and side. Also never use paper that has been allowed to become damp in any way.
If you found this information useful please click below
Posted on Aug 12, 2009
Paper jammed while trying to fax through the feeder. Help
turn it off slowly work the paper out by pulling it slowly from the direction you fed it or by whatever direction you find it will come out the easiest. If it tears you be patient and work out pieces you aren't the first person that ever jammed paper in a fax just take patience to get it all out.
Jul 04, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Tip
How to troubleshoot paper jam problem in printers?
Most common reason are as follows:-- Among the most common problems with any make of printer are paper jams. A printer will jam for any number of reasons: It’s dirty, the wrong paper type is being used, or the rollers on the printer that feed the paper through its pathway are worn down. While cleaning the printer periodically and using the correct paper type are easy fixes, roller replacement can be a difficult job depending on the model of HP printer. For some HP printers, the rollers are easily accessible, but you'll need to completely tear down other models to remove the rollers. Regardless of the cause, when removing a paper jam, always pull the paper in the direction of the paper path, because pulling it backwards can severely damage the printer.
Certain HP printers are more susceptible to paper jams than others. In my experience, any printer that holds the paper vertically and then pulls it down through the printer invariably ends up having paper jam problems. These models aren't designed for heavy use, but many organizations make use of them on individual systems and should be aware of this flaw. In addition, some people have trouble with the newer HP 4000 series printers' paper pickup rollers—which is odd, because the older 4000 and 5000 series HP printers are considered rock solid and don't seem to have any trouble with their pickup rollers.
This will help.good luck.
on Mar 05, 2010 | Office Equipment & Supplies
Paper is jammed and unaccessible to pull out is
Never try to pull paper from front cover, if cause mechanical damage to the device, Try to pull it from back of the printer or from paper tray,Visit this link to clear paper jam & Carefully follow the instruction:-
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09128&cc=us&lc=en&dlc=en&product=60096
Have a nice day....don't forget to rate the solution.
Feb 20, 2010 | HP DeskJet 930c InkJet Printer
The paper twists and causes a jam on every print
sounds like something jamed in the rollers like a pin etc
Jan 05, 2010 | Epson Stylus R265 InkJet Photo Printer
Says its out of paper, but there is paper in it
look and make sure that the paper roller is taking it. its a small roller that sucks the paper in, and they go bad and can be replaced. if its not taking it, look for tiny remnants of a paper jam that someone may have pulled out, usually very very small and have to use tweezers to pull out.
if no jam and the paper tries to feed but slips than rough up the roller and clean with rub. alch.
also, look for a sensor or a button like on a refridgerator to make the light go out, you know what i mean, and sometimes it can be stuck or dirty or ink covered or broken.
Jul 17, 2009 | HP OfficeJet 7310 All-In-One InkJet...
The print output on the paper is crooked.
The back of the unit has a piece which pulls off to clear paper jams. It was not fully pushed in. I found the solution on another post that was on your site.
Apr 02, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310
please check gear train and confirm no broken one-check of selonid not working in a right way and no foreign object droped inside(like pins).-check of smoth actuation of paper present detector.(in place and movement when you put papers
Mar 01, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Document feeder works for printing but not for scanning
Hi, When you had the doucment feed jam were you able to clean or remove any paper that might be blocking the paper to be scanned? It sounds like there is paper still in the document feeder , I would open the DF and check very closely to make sure no paper is in the way!Good Luck!
Dec 02, 2007 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
140 people viewed this question
Seeker5211
Seeker5211
