I have a Sharp LC-32SB23U. The channel/audio indicator keep poping up on the screen. It seems to be more during commercials. Are there any settings to eliminate this?
  • 1 more comment
  • sunde1 Apr 23, 2009
    1. This TV is off a Directv reciever. The picture is perfect. The audio goes through the RG6 Cable so there is no other Audio cable. This is in our Motor Home. All connections of the RG6 cable appear good. Any other suggestions?
    There is one other TV connected to the Directv reciever and it does not indicate the same problem. Also the channel/audio pop up happens mostly and more often when commercials come on. Sorry but that is about all the information I can provide.
    I will take the TV in for repair as this is a new TV.
    Thanks,
  • 3,866 Answers
Looks like the system on board that controls these indicators is going out on you and needs to be repaired before other system do the same. You can try these tips to illimate this make sure that no buttons on the TV are jammed in or stuck if not and they are free and not obstructed. If you inclined to pop open the back of the TV and give it a good cleaning with a can of forced air you can pick up from a computer retail shop. Spray out all the dust you can find. Be careful not to tilt the can because liquid will spray out. Let the TV sit for 15 mins cleaned out, try to see if that will shore up the problem, otherwise your going to need another control logic board replacment.
I hope this give you some idea's on steps to take to a successful solution.
Posted on Apr 23, 2009
    Brigadier General:
  • 3,614 Answers
are you using a local antenna on your tv or a cable box..?
try to check first the video / antenna connections on your tv, this can only be your loosing signal..
let me know
  • micromaster
    micromaster Apr 23, 2009
    before we go any further, better do disconnecting the cable connections, this can remove any possible grounded contact on the connector,.
Is the audio amp on the main board of a sharp lcd tv
A manual for a measure of the voltage line thats goes to the audioboard and there can be used a fuseresistor a resistor to protect the audioboard if .......
SHARP LC 32M44L LC 32SBB21U LC 32SB23U LC 32SB220U SUPP Service Manual...
Suc6
Oct 25, 2015 | Sharp LC-32SB23U 32 in. LCD TV
No picture
It sounds like the Bluray player may be outputting the signal at a higher resolution than the TV supports. If the Bluray player has a scart or composite connection, connect with those first, and adjust its settings to output a lower resolution. Then reconnect the HDMI. Hope this works for you.
Jul 17, 2010 | Sharp LC-32SB23U 32 in. LCD TV
The power light blinks and the tv doesn't turn on
you should perform the initialization to factory defaults.
May 24, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Tv takes forever to turn on sharp television LC-32SB23U
This problems very common with sharp tv.The Main Turner Signal board have problems.Keep using it,when it stop and completely dead 20-30 on-off no backlight show up and picture.U know ur Tuner board signal board is dead, have to replaced it.
Jan 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Audio keeps switching from mono to stereo
on every channel ? then av board is failing
on a single channel then it is their signal not you set
Nov 24, 2009 | Sharp LC-32SB21U 32 in. LCD TV
Where can I download a updated software driver for a sharp television model LC-32SB23U?
If you refering to firmware upgrade- there is non avalable for this model.
Nov 04, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Cannot turn off Closed Caption
Here's the copy on CC from my manual LC-32SB23U.
1. Press CC.
This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
Press repeatedly until you select the desired closed
caption service.
INFO BOX ON THE SCREEN,
Air ANALOG
Audio : MONO
CC : 1/2 CC1 ------ Closed Caption information
Ratings : NONE
Example:
If a program has three services (Digital CC(ENG), CC1
and Text1), the closed caption display will toggle in this
sequence:
1/3 ENG -- 2/3 CC1 --- 3/3 Text1 -- Off
The CC button keeps a record of the last service
selected in its memory.
If the last closed caption mode (e.g. 1/3ENG) you
selected is not available for the next program, or on
another channel, the closed caption service that is
available is automatically selected, and this service
appears in parentheses, e.g. “1/3(CC1)”.
Closed Caption services that appear in parentheses will
not be stored in the CC button's memory as your last
selected service. Only services that you have selected
with the CC button are stored.
If this doesn't work, the TV may need a software upgrade.
I can get you a copy of my manual LC-32SB23U for you. But, are you sure there is and "A" in the middle of your model number?
Jun 02, 2009 | Sharp LC-32SB23U 32 in. LCD TV
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Connecting external speakers to Sharp LC-32SB23U
Invest in a sharp soundbar (about $175.00) matchs the cecor of the TV fits right at the bottom and looks like part of the TV and the sound is super.
Jan 04, 2009 | Sharp Televison & Video
No sound
Please try unplugging the TV for two minutes then replugging and turning it back on. Werked fir me!
Dec 12, 2008 | Sharp Aquos LC-32D40U Television
Televison & Video Logo
Top Televison & Video Experts
