Question about JVC KD-G421 CD Player
SINCE MY CAR BATTERY WENT FLAT THE DISPLAY ONLY SHOWS 0000A I'VE GOT ALL MY STATIONS BUT I CAN'T GET RID OF THIS DISPLAY
Battery went flat radio wont work now.how do i get code?
Search Results
    Car Radio Stopped Working after the Battery Died
    cartech.about.com > ... > Car Radio Components FAQs, and More
    First your battery went dead, and now your car stereo is dead, and it's really ... or charge, and you're lucky, then you may find that your car radio fuse is blown.
    radio won't work after new battery installed - Car Talk
    community.cartalk.com/.../radio-wont-work-after-new-battery-installed
    Nov 30, 2011 - Today the dealership did a tuneup, replaced the timing belt, and put in a new battery. I started my car and the radio did not work. They went out ...
    Another Flat Battery - Radio No Longer Works - Hyundai Forums ...
    www.hyundai-forums.com/.../128744-another-flat-battery-radio-no-long...
    Jul 18, 2011 - Also now the battery has been recharged the redio will not work. .... Mybattery went flat, took it out and went to a battery shop who charged it up ...
    Dead battery..now radio won't work - Honda CR-V Owners Club
Dec 09, 2015 | Cars & Trucks
Battery went flat so need radio code for renault megane
With the car, comes a plastic "infocard" with the radio and alarm codes. If you lost the card or didn't receive it with the purchase, you can ask for the code to the radio manufacturer, they'll ask you the serial number of the radio and the car and they'll send you the code.
Jan 12, 2010 | Car Audio & Video
JVC KD-G230 will not work after my battery died
the battery probley shorted out your deck i think its time for a new one
Jan 11, 2010 | JVC KD-G230 CD Player
2009 Escape. When I purchased this year, I mostly listened to regular radio, which showed artist and title in display. Now, after playing Sirius a lot (which shows text info on display), the info no...
Does it do this on all radio stations? Some stations don't broadcast that information, some do. Also there may be an info button somewhere on the radio, try pushing that to see if it comes up.
Nov 12, 2009 | 2009 Ford Escape Hybrid
My sony ericsson w600i just went blank
i have white screen in W600i model please solve this problem
Sep 10, 2008 | Sony Ericsson W600i Cellular Phone
Vauxhall astra radio keeps switching on and off on its own
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Jun 24, 2008 | Audio Players & Recorders
DEH-1900MP - lost functionallity after disconect/connect batery
Yes for some radio's if you take away power it has a theft lock and will not let you back in except if you have the code. To reset you must take power away from it. I would suggest if you don't want to take cd player out of car then disconnect battery. then when reconnect eject. May have to set for a moment.
Sep 21, 2007 | Pioneer DEH-1900MP CD Player
JVC KD-G421 CD Player Logo
18 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
