Question about Toro TimeCutter SS5000 50 in. 22HP Smart Speed V-twin Zero-Turn Riding Mower
Toro timecutter ss5000 leaving strips of grass "Mohawk" has new blades belt
3 Suggested Answers
  • 6468 Answers
SOURCE: toro lx 500 deck belt pops off
check for play in the bearings blade bearings and the idler pulleys
Posted on Apr 15, 2012
BAMOUT
  • 2478 Answers
SOURCE: How do I replace the belt on a toro ss5000 #74630 timecutter
Go to you tube On the line replace belt toro etc.
Posted on Jun 21, 2014
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
I have a toro timecutter ss5000 and the battery will not stay charged. I bought a new battery same problem. What actually charges the battery the solenoid?
Actually is the alternator on the engine thru a voltage regulator and 25A fuse then thru the ignition switch to the starter solenoid and on to the battery..
Mar 23, 2015 | Toro Garden
My blades wont come on when i pull up on the switch.never had this problem before.
The switch operates a solenoid. Check the condition of the wiring before you replace anything. I don't know if its similar to a JD but that operates an electric clutch on the drive. Check it out.
Aug 15, 2014 | Toro TimeCutter SS5000 50" 22HP Lawn Mower...
Jun 21, 2014 | Toro Garden
Timecutter PTO clutch switch clicks when I engage the switch but will not engage the belts
Check under the deck and make sure the blades can spin freely, there will be resistance but mostly check to see if they are stuck. If they are not and can move, yiu can try to remove the belt from the pto, engage and see if it spins then. If it does not than there is probably an issue with pto clutch
May 12, 2014 | Toro TimeCutter SS5000 zero turn mower
Toro 42 " Zero Turn; In tall grass and even in moderate grass it is leaving a double strip of uncut grass, that lines up with the division between the centre blade and both outsice blades, resulting in...
Your blades may be erroded on the edges? Or the center blade hub might be damaged or worn.
good time to inspect all the blades and spindles for wear or damage.
Jun 26, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Toro TimeCutter SS5000 50 in. 22HP Smart Speed V-twin Zero-Turn Riding Mower Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
