My Canon Pro9000 Mark II has a print head that won't move. It slides freely by hand but the printer can't transport it. I assume there is a missing gear somewhere.
  • 624 Answers
SOURCE: Black print head not working well after transporting.
Hi Pete, your're printer is probably still good. If you haven?t done so you should run the nozzle cleaning utility a few times. Compare the first on with the second or third and see if it?s getting better. If yes some of your nozzles were clogged. If it?s close to being back to normal you can run the cleaning utility again or you can remove the ink cartridge carrier and clean the nozzles. I had a Canon printer similar to yours so it?s probably similar to yours. Your ink cartridges plug into a carrier which actually contains the ink nozzles. Remove the ink cartridges from the carrier, place a piece of tape over the bottom ink output hole and store them oriented as if they were in the printer (up). This will prevent the ink from draining to the top of the cartridge and possibly causing flow problems later. Tank the cartridge carrier and place it in a small plastic bin and fill with Windex till the nozzles are covered. Make sure you also put some Windex in the carrier itself in case the blockage is there. I use straight Windex (window cleaner containing ammonia for non-American types); I find the real stuff is better than the store brands when it comes to removing stubborn clogs. I also use a sealable plastic food container to soak the print heads in. When I?m done I snap the airproof lid on so I can save and reuse the Windex again. Once you?ve done that use a Q-tip to gently scrub the surface of the nozzles and let soak overnight. After the soak is done shake off as much of the Windex as possible and reassemble the printer. Make sure you don?t let the cartridge carrier dry out, that will probably re-clog your nozzles again. Run a couple of nozzle cleaning cycles to clean out the residual Windex and start the flow of good in again. If it worked your printer should be back to normal again. Let us know how it turns out and don?t forget to rate the posting.
Posted on Jan 06, 2007
SOURCE: Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Posted on Feb 14, 2008
  • 6 Answers
SOURCE: canon mp-730 print head does not move
it seems you open or unscrew the printer.
this may happen if the mother board has no nigative pole.
you have to reset the mother borad.
cannot do that from the available options
the reseting procedure is to take the motherboard out and you have to shortcut the battary for 10 seconds.
re install it , and try it
Posted on Mar 26, 2008
SOURCE: Canon pro9000 Carriage lift mechanism error [5110]
I am not a tech.  I don't guarantee anything.  It just worked for me.  Here is what I did.  uNPLUG THE PRINTER.  The covers on the Pro 9000 are snapped on so locate the slots that look like a flat screw driver will fit.  Insert the tip of the screwdriver and lift on the covers and they will come off.
Now, looking at the printer from the front, on the right side you will see a group of white gears with a black gear at the bottom.  The black gear has a 'flag' that us used by the sensor right there.  If you spin the white gear that is second from the top, it will lift the carriage to the hightest position.  Leave it at that position.
On ther front edge of the area where the printhead slides from the right side of the printer to the left and back, you will see a small switch that is a safety switch that stops the printer from moving the print unit back and forth.  I taped it down temporarily so that the printer thought the cover was on.
Next on the left side about 3/4s of the way down where the printhead would move to the left, you will see a small sensor looking up that sees the bottom of the print unit.  Lay a piece of paper over that sensor so that it is in the shade.
BE CAREFUL and keep your fingers out of the printer.  Plug the printer in and depres the power button.  The printer shoud first cycle the paper feed area.  Then, BE PATIENT, the ink unit comes to life and continues on its initiation.  It should slide to the right and actually tap the frame once, then do the same move, but tap twice.  Then after a bit, the left ink cartridge will light and the carriage will move to a sensor on the left and it will light up each cartridge, then it will lower the carriage for a second, then slide completely to the left and then the right.  After several more girations, it will put the carriage where it belongs.
That worked for me.  Good Luck
Posted on May 05, 2009
SOURCE: canon i255 printer--print head error
my cannon printer i255 head has a problem and it should be replaced so i need a printer head of i255, please give the price of printer head
Posted on Jul 08, 2009
Blurry colorwashed photos from canon pixma pro9000. What can I do to fix this?
Hi there, I located this video about removing the print head and cleaning it. I've had to clean my print head from time to time, so take a look at this video and see if it can give some help. Your printer might not look exactly the same, but you should be able to remove the print head. If cleaning the print head doesn't clean up the color issue, try contacting Cannon support: Canon Contact Us. I wish you best of luck!
-Mr. W
Feb 25, 2015 | Canon PIXMA Pro9000 Printer
Canon Pixma Pro9000 won't transport the print head carrier. You can slide it freely by hand from one end of the case to the other. It does seem to lift and lower by itself. When you turn the printer on,...
Check the print head drive belt. It should go around a drive pulley on one side of the printer and a spring-loaded tension pulley on the other side. Verify that the tension pulley is keeping the belt from slipping. Also, if you can see the drive pulley with the cover closed ( you may need to shine a light on it), watch to see if it is turning during a print cycle.
Jul 03, 2017 | Canon PIXMA Pro9000 InkJet Photo Printer
My Canon Pro9000 MarkII prints photos with a red tint
You probably haven't calibrated your monitor to show the correct colours, so in whatever photo programme you're using, you're setting the red tones too high. Test this by first not calibrating your monitor, but turning down all the red tone until it looks washed out. Print this and see if it's better. If so, set your monitor to a cooler colour temperature. If the result is no better, check your print dialogue settings to make sure you are using an appropriate colour profile. And, for example, if you're using Photoshop, tick 'let Photoshop manage colours' in the advanced profile settings box. Hope this helps. I doubt there's anything wrong with the printer.
Dec 29, 2012 | Canon Pixma Pro 9000 MARK II InkJet Photo...
My Canon Pizma Pro9000 prints photos that contain TOO MUCH black in it. All the colors appear to be much darker than on the screen. And when I lighten the pics, it doesn't help since all the shadows are...
Hi
I suggest you clean it manually by removing the ink cartridge and rub the print head into a paper with alochol and then run the print nozzle for 2 times to clear some ink residue that cause darken color
Mar 08, 2011 | Canon PIXMA Pro9000 Printer
I get error code 5100. Can't get past it. What to do...
This particular error has a lot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip.You can find the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display). Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corresponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on).
Thank you !!
Aug 09, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
Where is the serial number on my canon mark Ii pixma 9000
Lift the door as if to replace your ink cartridges and the SN is on the ribbon cable that is held to the printer on the right.
Jul 15, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
Printer prints every second line or prints 4 lines then skips a line or only prints half a line.....the top part of the line is missing.
Hello sir; I believe it's time to clean print head and ink cell, power on the machine open the cover ( as you replace cartridge) , when carriage move to the center , then UNPLUG the power cord. then you may move carriage freely by hand all the way to left, noe you can clean up ink cell easily.
Sep 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Noisy hp7450 printer
There's a rubber part in the printer on the right inside the printer underneath the print carriage that slides back and forth. If this has moved it will foul the print head. I moved mine back into the right place and the print head now moves freely.
Hope this helps,
Cheers,
Paul.
Nov 05, 2008 | HP Photosmart 7450 InkJet Printer
Printer does not power up
My Canon IP3000 would not turn. It turned out to be the Print Head. It had burnt out and gone short circuit. This caused the built in power supply to shut down, hence, the printer appears dead.
Now, how do you get the Print Head out when it is locked down on the left side (your right side if facing the printer)? Open the top lid and inside you will see a chrome sharft, about 10mm in diameter, that the Print Head slides along. Put you finger under this bar and lift it 3 to 4mm. It's under spring tension. The Print Head will also rise, releasing it from the lock. With your other hand, slide the Print Head to your left. You can now release the bar and move the Print head freely.
To confirm the fault, try to power up the printer with the Print Head removed. Don't forget to put the lock bar down first, to stop it hitting the cover when it tries to go home.
Jul 17, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
162 people viewed this question
jasbo
jasbo
