Question about Samsung HL-S5087W DLP TV
Color disappears from DLP display
I've got a Samsung HL-S5087W 50" DLP tv, which is about 2 years old. It has recently started to have some issues with color display. Basically what happens is the color blue disappears, and the image almost looks black and white. You can tell from logos, etc on screen that the other colors are OK. This happens pretty randomly, then just as randomly fixes itself. I'm thinking about getting a replacement bulb, but I'm not sure that's the issue. Any ideas?
  • 68 Answers
The problem here is the crt cicuit unplug from the wall take off the back its the cicuit board thats pushed on to the tv screen pull it off. you will see R G B its the B one thats faulty it looks like a transistor. call an engeneer and he will put a new one in for you i hope this helps you???????
Posted on Apr 23, 2009
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Samsung HLS5087W picture keeps turning off. Sometimes it happens after a couple of hours and then every 10 minutes after that. recently changed both bulb and color wheel. Tv only 6 years old.
I would first check the lamp is properly seated and was it a Samsung or a generic brand? Also not indicated is does sound remain or not.
Dec 05, 2012 | Samsung HL-S5087W DLP TV
My dlp tv (model number-hl-s5087w)is making a humming noise
Bad Color Wheel.
Samsung Parts 1-800-627-4368
Mats 1-800-628-1118
Oct 14, 2010 | Samsung HL-S5087W DLP TV
I have a Samsung HL-S5087W approx. 5 years old. I had a problem with picture going out, the picture would come on after some high pitched sound and turning the unit on and off a few times. The picture was...
Hi,If you are getting a black and white picture,color discoloration or a humming high pitch sound, it will be an issue with the color wheel.The color wheel is a rotating disc that spins at high rpm and its in charge of creating the colors on your set.Found it here:http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm You can replace it
your self here's an example: http://guides.fixyourdlp.com/samsu/bp96-01579a.php
Good luck and God bless you!
Nov 19, 2009 | Samsung HL-S5087W DLP TV
Screen blacks out on samsung DLP
It may be a loose conetion inside the set. Open and carfully check the conections.
Aug 20, 2009 | Samsung HL-S5087W 50" HDTV
My set started humming recently. Not real loud,
Hi, sounds like a bad color wheel, a technical repair that should be done be a trained repairman, cost around $250-275 installed
Aug 17, 2009 | Samsung HL-S5087W DLP TV
We have 2 problems....dark screen/bright light on right side
Replace the light engine. If you wish to get some details; visit the site linked here. Pull up older posts.
Apr 11, 2017 | Samsung HL-S5087W DLP TV
Turn tv on and then it will turn itself of can immedately turn back on it is a 50 inch SamSung one year old can any one help with this problem
do a voltage check the transformer & the bridge rectifier and the whole off the power supply use a meter ther may be power starvation
Mar 11, 2009 | Samsung HL-S5087W DLP TV
Samsung HL-S5087W DLP TV Logo
172 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
