Question about Samsung PCL545R 54" Rear Projection Television
Convergence Problem Hi, I've gone through the forums and can't seem to find a definitve answer on my problem. My Samsung PCL545R is having a problem with the blue convergence. Red and Green are OK. I've been able to determine from others that this is problem with a convergence card. If I want to replace this card(?)on my own, how hard is it? I'm not very savvy technically, but if it's simple enough, I'd like to attempt it on my own. Thanks!
  • trish63 Nov 10, 2007
    We have the replacement convergence board but are unable to locate it within the TV . Any ideas
    Novelist:
    Scholar:
  • 149 Answers
This is something that specialist go through training for. I'd recommend checking out some specialist who deal with that. Try lionav.com to see if they can talk to you about it or know someone in your area who can do it. Again, if you dont have the option on your set I'd advise to seek a professional to assist you with this.
Posted on Sep 24, 2007
SOURCE:
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
Color convergence off and bowing effect on top and bottom of picture
Yes, if you have replaced the IC's correctly (and used the correct IC specifications) then the issue could be with faulty resistors and / or capacitors.
Jun 01, 2008 | Samsung PCL545R 54" Rear Projection...
Cannot manually Converge Samsung PCL545R 54 in. Rear Projection Television. Perfect focus doesn't work either.
Try website like Tv repair World.com to buy a whole convergence board to replaced.Samsung/Akai use the same convergence board.
Apr 26, 2010 | Samsung PCL545R 54" Rear Projection...
My TV was snapping or arcing then no picture at
Sorry to hear this. What has happened is that CRT coolant has leaked from one or more CRT's down onto the Main bd and or the Power Supply bds and shorted them. You must replaced ALL three CRT's and the shorted Main bd and or the Power Supply boards. Then a Full Convergence Alignment must be done by a very good and experienced tech. Not cheap.
Apr 04, 2010 | Samsung PCL545R 54" Rear Projection...
No Picture
I have the same TV samr problem, so far I have dicovered a cap on the power card AA41-00342A has gone bad, c812 a 2200uf 250wv. I can't find a cap or replacement card. I'm still working on it, when i get more answers I will pass it on.
Aug 20, 2008 | Samsung PCL545R 54" Rear Projection...
Green bow tie, convergence not helping
Yes, your geometry correction has failed and you will need to seek qualified tech for help. You need what are called STKs and you should be able to get the job done inhome for under 300.00
Craig www.classtorations.com
Jun 08, 2008 | Samsung PCL545R 54" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
PCL542r convergence
Samsung part number AA95-00706C its available at www.partsstore.com
Mar 13, 2008 | Samsung PCL545R 54" Rear Projection...
Convergence Problem?
Mike, on this set don't bother with the chip changing as the complete convergence amp. board is only 63 bucks. Check it out here: http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=1201%2D001225&search%5Fmodel=PCL545R Good luck
Apr 26, 2007 | Samsung PCL545R 54" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
37 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
