Burners do not light properly - Heating & Cooling
  • Richard Dean
    Richard Dean Oct 13, 2013
    Intermittent problem from the start but has gotten worse with time (2 years). Unit is mounted horizontal with right to left flow. Altitude is 3500 ft. Trouble light blinks twice. Does not light the burners completely. Induction fan starts and steps up in speed, glow bar starts, gas turns on, top burner of 4 (the one with the glow bar) lights but the other 3 burners do not, the top burner does not ignite them. The flame sensor is on the bottom burner so it is not happy so the controller shuts it all down. After 3 tries the furnace locks out, as it should. The unit is setup for propane and the gas pressure is correct. Does not matter whether flue is connected. Gas orifices are clean. If I put a flame by lower burners they will light when the top burner does at gas turn on.
  • Richard Dean
    Richard Dean Oct 16, 2013
    Think I finally found the problem. The 16" by 1/2" flex line from the 3/4" black pipe to the heater gas valve was within manufacture spec
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 26 Answers
Burners rust over time. if there not bad you can clean them. make sure orfices & manifold are clean.
Posted on Oct 15, 2013
Top gas cooking range continues to make the ticking sound ( tick-tick-tick) even when all burners are off. There is sparking at all the burners too with the sound, I have removed the electrical plug f
This seems like the burner control valves are not functioning properly. The rear is still working properly so without knowing brand I would say the control valves are defective.
Apr 19, 2017 | Kitchen Ranges
Gas boiler will not fire
try jumping out the pressure switch
Nov 13, 2012 | Heating & Cooling
Burners run cool when set on high, when all but one burner is off, the single burner opporates correctly. Grill worked fine before.
There have been issues lately with the way regulators are not drawing gas out of the cylinders properly, and how some of the newer grills are not heating properly.
The issue with them not heating properly goes back (usually, from just what I have observed) to the position of the gas knobs at the time the cylinder valve is opened. On some grills, if the gas knobs are open when the cylinder valve is opened, the burners will not get the maximum amount of gas to all burners, but the performance of one burner is enhanced if the others are turned off, and this sounds like what's got you.
Turn the gas cylinder valve to the off position, and bleed the gas pressure down at the burners. Close the burner valves. Slowly crack open the tank valve, and work it slowly to full open. With the grill lid open, select and light one burner. If it operates properly, light the other burners. If the first burner does not operate properly, repeat the procedure. If you cannot operate your grill like it is supposed to, the issue may fall to the regulator. If the regulator is an older style, it may not actually be fully compatible with some newer cylinders. This seems to be a newer phenomenon, and seems to be found with the type of cylinders that are swapped for a refill. If this is your case, you will need to upgrade to the newer regulator.
Best regards, --W/D--
Mar 07, 2011 | Viking DVGBQ532-3RTL (LP) All-in-One Grill...
Grill will not stay lit if using 4 th burner will only work on 3 burners and gas is low
Check that the fourth burner tube is set properly into the unit. Then turn all burners off, turn off the natural gas supply or remove the LP tank. turn all the burners on (don't try to light) wait a couple seconds turn all burners off. reconnect gas source. turn on gas, open burners fully and try to light.
Aug 08, 2010 | Jenn-Air Grilling
Front Burners very low back burners not working
Front 2 burners light properly but back burner does not light. Checked cleaned spider guards, even removed the burner making certain it was clean. Reassembled the back burner but it still does not light.
Jun 23, 2010 | Weber Genesis Gold B Grill
Burners two and three will not light unless direct flame is put to it. Burner 1 will light off the ignitor.
Probably the ignitor sparker is not positioned properly or ignitor wire has short and it's not sparking at the burner. Compare the position of the one that lights with the others that don't and adjust position til spark arcs against burner and lights within 1-3 sparks.
May 12, 2010 | Char-Broil Advantage 463453306
Viking stove right burners won't light
can u see the burner spark if not then ht lead at fault of electrode
Aug 21, 2009 | Viking 31 in. VGSU101 Gas Cooktop
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Jun 29, 2009 | Thermador RDDS30 Dual Fuel (Electric and...
Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
May 27, 2008 | Kenmore 490 sq. in. Cooking Area Gas Grill...
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
