Question about Pramac 5000 Watt Generator
I need an owners manual for a pramac es 5000 generator
3 Suggested Answers
  • 76 Answers
SOURCE: how to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Posted on Jun 29, 2009
kel1guy2002
  • 3740 Answers
SOURCE: perkins 3 cylinder powered pramac generator
Start looking at your safety circuits.
1. High water temp
2. Low Oil
3. Low water etc...
From the manual these are the protection circuits.
• Engine protection: low oil pressure, high engine temperature.
• Genset protection: under/over voltage, overload, battery charger failure, battery voltage out of limits,
under/over frequency, start failure.
• Circuit breaker protection: IV poles.
• Differential protection.
Any one of them will trip the fuel relay closed. What you may be able to do is disconnect one at a time each protection circuit and see when the fuel relay opens. (Make sure to reconnect each one if it had no effect on the fuel solenoid)
Once you isolate which circuit it is in then you can chase wires or change the bad switch.
Thanks for choosing FixYa.
Kelly
Posted on Jun 26, 2010
What is causing subaru portable generator to overrev?
Could be the return spring on the regulator has come off.
Oct 05, 2014 | Pramac Generator 5000 Watt Subaru EX27...
Fuel shut valve detached from bottom off fuel tank where it appears to have been glued on. How to reattach?
most have a rubber grommet that goes in the hole in the bottom of the tank and the shut off valve goes in the center
Aug 27, 2012 | Pramac Generator 5000 Watt Subaru EX27...
How to attach a fuel shut valve to fuel tank
WURTH, supply various adhesives suitable for use with fuel systems
Aug 27, 2012 | Pramac 5000 Watt Generator
Valve is sticking
TRY SOME LUCAS ENGINE OIL IT WILL HELP WITH THE STUCK VALVE!
Dec 11, 2010 | Pramac Honda 5000 Watt Generator
How to change oil and what kind to use on a es 5000 generator
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
Oil change
There are two 14mm bolts on both sides (lower) of the motor. Unscrew one or both and drain the oil....Replace with sae 30 or 10w30 oil and should take almost a quart. (Put the bolts back in and tork slightly.) Check oil level.
Jan 11, 2009 | Pramac Storm 5000 Watt Generator
Pramac 5000 Watt  Generator Logo
48 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
