Question about HP Compaq Presario 2200 Notebook
Note book turns on, but stays on windows screen.
I just replaced the AC connector in my 2200 Copaq notebook. Put it all back together and it only gets to the windows screen. also the light for the internet doesn't light. What did I do wrong?
  • 1 more comment
  • Joe Torpey
    Joe Torpey Apr 23, 2009
    Thanks for responding. I had my wife try it (she has the computor at home) it comes on in safe mode and gives you the count down to respond, when she hit the f8 key a bunch of words come up like multi disc yada yada yada. Does that help?
    Thanks
    Joe
  • pontelemon
    pontelemon May 11, 2010
    It gets to windows screen and then what?
    Stays? Shuts down?
  • NitrusInc
    NitrusInc May 11, 2010
    Please attempt to boot into safe-mode by hitting F8 when you power on your computer.
    Please let us know if you are able to log-in this way.
I have a Dell Inspiron mini 10 . net book. Out of now where said something about windows and shut off ... now we cant get it to turn on, wont go past the inspiron load screen the little blue only goes...
tryt to do this
1.unplug the ac adapter
2.remove the battery
3.press the power for 30 secs
4.plug the ac adapter back in and after few secs try to turn it on
Oct 04, 2010 | Dell Inspiron Mini 10 Notebook
My armada e500 will turn on, do the little compaq sign then just stay on a blank screen and won't do anything further. HELP!!!!
Try draining the flea power first:
1. Remove the battery and ac adapter
2. Press and hold the power button for at least 10sec.
3. Put back the battery and ac adapter
4. Turn on the computer
Check if it will load to windows, if not, there could be a problem with windows. Try startup repair on advanced boot options. Hope this helps.
May 13, 2010 | Compaq Armada E500 Notebook
How to open the dell inspiron 2200 to clean up
Leave it alone!
If it ain't broke don't need fixin..
With all that said..
Take a vacuum cleaner and put the hose on the blower side and stick it in every opening on your note book and blow the dust out.
Jan 19, 2010 | Dell Inspiron 2200 Notebook
I got an Insprion 2200. It turns on, but once I move it the power cuts out. Not sure if it's the ac jack on the back of my laptop or another internal problem. Even with the battery in there left to charge,...
The DC connect on the system board may be loose. Take hold of it at the connection and wiggle it slightly. If it moves alot, the DC connector on the board is loose.
If not, take your battery out and power up the unit and see it stays on. If it does then it is the battery.
Jul 18, 2009 | Dell Inspiron 2200 Notebook
Can't get laptop to turn on. Battery pack lights show full charge, power cord is plugged in. No indicator lights illuminating at all, wondering if it is my motherboard. Compaq Presario 2200 laptop.
very first thing u have do is if u have any other laptop try and connect the aac adaptor with that laptop and also try the battery if it is working with the other laptop that means the motherboard of the computer has gone bad u need to replace it and what also u can try is disconnect the ac adaptor and take out the battery from the laptop and the without ac adaptor and the battery press and hold down the power button for one minute and then connect the ac adaptor and put the battery back in and then try and turn on the computer and also what u can do is shut down the computer first and then just hit the power butoon once only to turn it on and then keep tapping f8 key on the keyboard and it will take u to windows advance options and select safe mode with networking and then try if it turns on to the windows screen or not......and if it doesnt turn ono then definately replace the motherboard...good luck....
Jan 23, 2009 | HP Compaq Presario 2200 Notebook
Note book freezing after fan change
This is just an easy problem... what you'll have to do is follow this steps
Step 1: If you have manual of your computer it is better.. restart your notebook, press and hold the key to boot in BIOS setup... try pressing this key F1, F2, Delete or F8, because some laptop and notebooks have different method of going to BIOS.. you will know if it is BIOS Configuration because it has a BIOS Settings at the Title of the screen.. now go to Power Management or Power Monitoring.. you can find the Fan option there.. because you change the fan of your notebook, it detects that the Fan that you installed is not standard with the note book.. go to step 2.
Step 2: Now when you find the fan option try to set to ignore the fan RPM and The Voltage that is uses... if there is... then save your settings by pressing F10 key and wait for the notebook to start normally.. if the notebook won't start normally, then go to step 3.
Step 3: In this step you'll have to Start in Safe Mode.Restart your notebook, while booting press the F8 key then a boot menu will show in your screen.. if there is drive selection, choose the hard disk drive.. if none then proceed in selecting the Safe Mode menu.. wait until its done booting your windows in safe mode.. after have complete run in safe mode.. properly restart your notebook by going to Start>Turn Off Computer> Restart, and it will boot in windows normally...
Hope I Can Help
CLCTECH
Nov 23, 2008 | HP Compaq Presario 2200 Notebook
Compaq Presario 2200 won't hold a charge - on or off AC
I have a Compaq Presario 2210US. The wireless toggle button is in front on the right side, slightly under the top of the computer. Feel for it with your fingers or use a flashlight. It glows a bright blue when on.
Oct 30, 2008 | HP Compaq Presario 2200 Notebook
Screen cuts out when A/C is plugged in
hi there!
this problem should have 3 possible culprits. 1. ac adapter - it could be shorted. if you can find another working ac adapter and try it in your system the better. 2. the motherboard. 3. LCD. does this computer still has warranty? try calling their support and see what they say. if this doesnt have warranty anymore, then try to find another ac adapter to narrow down the issue.
pls revert back to me if theres any other issues.
hope this helps!
Karlox :)
Mar 11, 2008 | HP Compaq Presario V2000 Notebook
Dell Inspiron 2200 loose DC power pin connector
hi, the power jack must be removed by a strip out and de solder of jack and a new one fitted. I was lucky a guy took £30 for the job.
Feb 17, 2008 | Dell Inspiron 2200 Notebook
HP Compaq Presario 2200 Notebook Logo
53 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
