Question about Jamo Audio Players & Recorders
My jamo DVD S VSR 25 the DVD tray will not open (no DVD installed ) and makes mechanical noise continuously can you help.
4 Suggested Answers
SOURCE: DAV-HDX265 dvd tray doesnt open
well, if you hearing clicks is possible that you will only be able to fix by opening and looking if the door has been misplaced..... is possible that a cd is stuck and you need to open to fix.....
another way to fix is to press and hold Eject and Stop ON THE UNIT! while turning the nub to the right (volume up)
that will open the the service unlocking the system!!!!! THAT WILL ONLY WORK if the door or a cd is NOT stuck on it
Posted on Mar 14, 2009
zappanut
  • 959 Answers
SOURCE: Unable to load DVD and mechanism makes noise like gears slipping
I think that ;
somehow someone bumped the unit and dislodged a DVD from the tray..
thus impeding the opening mechanism as well as the turntable (the unmeshing gears).
I would unplug the unit and remove the screws holding the top cover on , and take a look at the tray .
once thats done , let us know how this is going.
Posted on Aug 01, 2010
SOURCE: hi
OK I fixed it. One of the CD's had gotten stuck between trays in the loader. I pulled out a few CD's by forcing open the trays gently. However even after removing as many cd's as possible one was still stuck. 1. Remove screws holding cover plate on in back and sides. 2. Remove cover. 3. Lift face plate latches and lift over top of unit. Remove serial cables from connectors on board. Take face plate and place aside. Remove screws from back of CD tray unit and bend back metal tab with flathead screwdriver. Lift CD unit up on one side so you can get your fingers up inside underneath and push stuck cd towards tray openings. You can gently force top few trays out. You may need to shake unit so that stuck cd reaches open end. Pull out CD. 4. Replace faceplate and connect serial cables. Plug in power cord, power on unit and make sure trays will eject normally. 5. Put it all back together!
Posted on Feb 09, 2011
The tray on my DVD player won't open. When I press open/close, it just makes a whirring sound.
Failure of the loading mechanism, possible that the drive is struck or the belt is worn out ,. You will need to remove the tray mechanism to check and confirm. The motor seems to work as there is noise but the drive is not working , possible belt slipping or gear slipping.
Feb 21, 2011 | Televison & Video
I think that ;
Aug 01, 2010 | Panasonic SC-PT460 Theater System
Rosen entertainment DVD player in a '04 Yukon will not eject
One of the biggest problem facing CD/DVD players are the drive mechanism. When the stay shut or chatter when you try and open them, means the through mechanism that ejects the tray will not push the holding tray open. If you want to open the tray by hand, there is a small hole whereby you can push a pin or paperclip into and push open the tray by hand. That is the only way to open and hand shut the tray into the player and get it operational. Other than that, replace the DVD device...no other choice.
Feb 03, 2018 | Car Audio & Video
Wondering if anyone is any good with lite on shm 165 drives? Been trying to figure out why it wont open the disk tray. No disk inside, pressing the button makes an audible clunk noise. Pushing the pin...
Problem found on mine: tray opening mechanism is belt driven, while others are gear driven, belt tends to stretch with time and slips on motor pulley, gears do not. Just cheap built. Remedy= Belt can be removed from front with open tray, soaked in rubber rejuvenation liquid for few seconds, cleaned and dried, re- installed on pulley.
It works now, but for how long, I have no idea.
Aug 15, 2009 | Lite On SHM-165P6S DVD RW Dual Layer...
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Jamo DMR 60 system tray open/close
the remote supplied do not do it.you will need the remote for dmr61 that is updated with the function.i can supply you one brand new for £12 including delivery.i can send you the picture so that you can see the difference yourself.
Jan 10, 2009 | Jamo DMR 60 DVD Player/Receiver
Sony DVP-NC600 Powers down during CD playback
The tray won't open. I took top off and dvd top side holder, but the laser mechanism won't disengage so the tray will open, even with no dvd in it. How do
I reset it. I power on, hit open key, it makes hum noise then goes by to
standby mode.
Jan 06, 2008 | Sony DVP-NC600 Multi-disc DVD Player
Dvr 50
Hi I have jamo Dvr50 system and it has been frozen since yesterday. I have power down few times but nothing is happening. It comes on and panel lights up but that is all.
Nov 08, 2007 | Jamo DVR-50 System
Problem with Jamo DVR50
You have defective caps on the power supply pcb which needs replaced.the top of the caps will look like they have been bubbled up..change all of those that look like that.
Apr 10, 2007 | Jamo DVR-50 System
150 people viewed this question
Top Jamo Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
rjivaro
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
