Question about Sharp AR-208D Printer
Sharp ar 208d maintenance reset - Sharp AR-208D Printer
Cogz
  • 1326 Answers
SOURCE: Sharp AR-M237 Reset Codes
You have to get into the sevice mode and reset the "PM" counter back to zero. Go to service mode and enter code 24 then enter sub code 04 back to all zeros and exit out and turn the copier off then back on and it should disapear.
Posted on May 09, 2008
Cogz
  • 1326 Answers
SOURCE: Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
Posted on May 15, 2008
  • 300 Answers
SOURCE: Sharp AR-M205 Calling for Maintenance.
1. unplug the printers power cable it resets ALL printers
2. Once you have it unplug the power cable back in and turn it on make sure it's plugged into the computer.
3. you may need to uninstall and reinstall any software and drivers that came with the printer
4. download and install all the critical updates and service packs for your operating system
5. download and install any updates for your printer from the shap printer driver site
Az.
Posted on Sep 17, 2008
  • 990 Answers
SOURCE: Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
Posted on May 30, 2009
intelsrinu
SOURCE: sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Posted on Apr 18, 2013
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Need help for maintenance on Sharp AR208D copier
It is time to call the telephone number and request maintenance. When the copier gives you a message that it needs maintenance, the machine needs a trained technician to perform maintenance on it. Don't just keep using the copier as you can permanently damage the machine.
Aug 05, 2014 | Sharp AR-208D Printer
HOW TO FIND THE IP ADRESS OF MY COPIER
The 208D had a network module on the back of it where the Cat5 cable plugs in. there is a little black button on there, if you hold it down it will print out the network config page.
Copier Collin Houston TX Copier and Imaging Expert
Jul 28, 2014 | Sharp AR-208D Printer
HOW TO REPLACE THE PRINT DRUM ON A SHARP AR-208D COPIER
  1. fold down the bypass tray on the right
  2. hit grey button on right door to open it
  3. fold the front cover down
  4. press green button to remove the toner
  5. the drum is the other thing you can grab and there and remove.
  6. reassemble in reverse order of 5-1
Jun 09, 2014 | Sharp AR-208D Printer
Sharp ARM207
try typing the error code into a search engine.
Dec 06, 2013 | Sharp Ar-208d Duplex Copier, Printer,...
Sharp ar 5516 maintenance reset
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
Need to know how to add developer power to a sharp ar-208d. my copies are all coming out blank
No need developer.When your machine need developer,it show developer signal.blank page print means,charger problem please check corona wear may be it broken or displace.
Jan 07, 2010 | Sharp AR-208D Printer
How add developer to sharp ar-208d
Set-up for this copier sure isn't well-documented. We just got ours working today, by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
Sep 28, 2009 | Sharp AR-208D Printer
Sharp AR-208D copier needs developer - how to add?
Set-up for this copier sure isn't well-documented. We just got ours working today, found out how to add the toner by following the instructions here: https://www.businessneedz.com/Manuals/ar168s_setup.pdf (yes, it lists a different model number, but the instructions worked, and were linked from the ar-208d product page from the supplier)
Apr 02, 2009 | Sharp AR-208D Printer
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
Sharp AR-208D Printer Logo
183 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
