Question about Kenwood KDC-716S CD Player
Will power up,will hide, will open on igntion start
This happened some time ago, so I don't know if this is a fixable problem. One hot day the radio just died the screen went crazy then turned off. But it still goes thru the motions; when I start the car the face plate pops open like it is going to play, it gets into the correct position and then faceplates lights do a very pretty light show and thats it. The backlight is on but nothing works. I've disconnected the speakers thinking there might be a short but that hasn't helped. Oh when I turnoff the car it goes thru its shut down procedure faceplate flips halfway down 5 second delay then closes completely. is there any type of hope for this unit?
  • 78 corvette Aug 19, 2008
    It goes thru the motions; when I start the car the face plate pops open like it is going to play, it gets into the correct position and then faceplate displays all features. When I push the buttons nothing works. When I turnoff the car it goes thru its shut down procedure faceplate flips halfway down, delayS then closes completely. Is this a ribbon problem? I've only taken the faceplate off and replaced it since the problem stated.
Yup.. needs a new face plate ribbon cable.. just like mine :-(
Posted on Dec 06, 2007
SOURCE:
Will not turn on.
Could be an open internal fuse or power supply failure
Jan 21, 2018 | Samsung HL-R5087W 50" HDTV-Ready...
1999 harley davidson electra glide classic INT start.
The igntion switch is the point that both connect to.
Feb 07, 2012 | Motorcycles
Just put new battery in started fine then it started to over heat and the steering wheel got hard to turn.What could be the problem? It was not like this a few days ago.
Sorry it sounds like the other two problems just happened. Try this for the overheating tape a thermometer to the upper radiator hose right next to the engine thats where the thermostat is normally or use an infrared thermometer and shine it at the top ot the housing.Make sure it is full of coolant start engine when it is getting close to normal temp hold the top radiator hose all of a sudden it will get hot check your thermometer it should read about 192 thats where the thermostat is suppose to open. If the car is getting to hot because the thermostat did not open replace it. It fully opens at 222 your fan should be running if not your sensor is bad. Don't have your air cont on or fan will run all the time. The other problem make sure the power steering is full check your owners manual mine takes ATF+4 then have some one turn the wheel with inflated tires and see if the belt is slipping change belt if it is and make sure there is no oil on pulleys. Clean them with brake clean or alcohol
Dec 04, 2011 | 2002 Chrysler Town & Country
I have a new unit less then a year old, recently about a 2 weeks ago, the compressor has been shutting off from about 145pm to 2pm almost every day and going on and off till about 6pm. It is very hot in...
Just before or when this happens, take the filter cover off the ceiling assembly, and have a flashlight ready. Look up into the evaporator coils and fins at the opening for return air being drawn up/in and see if you see frost on the fins. Be sure to look right down to bottom, and let me know if there is frost. I'm thinking there may be a problem with the sensor positioning for the frost, or you may even have an obstruction on the forced side of the duct work if it is the ducted system. If it is the ducted system, be sure you don't close too many of them, if you are closing any of them, and take it off quick cool if your using that as well. ( quick cool is where you open louver to blow straight down from ceiling assembly )
let me know what you find. Mike
Jul 16, 2011 | Dometic Rooftop RV Air Conditioner
My radio has water damage and does not work at all. Is it fixable?
Hello
Replace the time memory battery from it first. Open the set, and wipe all the water out by a spnge of cloth. Left it for about 2 hours or so opened under a ceiling fan at moderate speed. After that, blow hot air, with a hair dryer with moderate heat; so that the traces of water left will evoporate. Do this process two or more times, because there will be water in between and under the terminals of ICs. It is best to turn it ON after two days it left opened. OK.
Jul 14, 2011 | Bose Wave Radio
I have a 2001 Sienna. I find in the morning the radio will sometimes lose it's presets. Also,the van starts fine but the odd time, when you go to start the engine, nothing happens when the key is turned. ...
If it starts without a jump, i would say it's the igntion switch that cuts off power to the radio at times. If it does need to be jumped, then replace the battery.
Jan 10, 2011 | 2001 Toyota Sienna
I have a 2001 Yamaha R1 that works perfectly, a few days ago I turned the ignition on, kill switch off and had no power at all the the starter button. I have power to the kill switch, no power to the...
You checked the solenoid? (ont post hot all the time - the other post only hot when you press the start switch) Check the low volt wires from battery to solenoid and solenoid to switch and from switch to ground.
I think you will find your trouble.
Please let me know what happens.
Thanks for using FixYa.com
Nov 01, 2009 | 2001 Yamaha YZF-R1
Engine won't start!!!!!
It's possible the "anti-thielf" system has been failing and went out while you was driving. If the ignition key has a chip in the shaft of the key your car has anti-thieft. It's possible the system doesn't reconisethe igntion key and shut the system down. Try using another igntion key if it came with 2 keys. If the engine started you'll need to get the other igntion key replace.
Apr 18, 2009 | 1995 Pontiac Grand Am
Pioneer 345 DEH
Intermittent faults especially one as intermittent as yours can be very difficul to trace but the first things to check are loose connections on the power supply leads at the back of the radio and if they are ok you will need to dismantle your radio and check for dry joints usually around the plug and if needed resolder these dry joints
Dec 09, 2007 | Pioneer DEH-345 CD Changer
Samsung TXR3079WHX TV shuts itself off!!!
transistor bad shorted tr-power j6920 org. part#0502-001230 located near flyback.don`t no location #
Aug 24, 2007 | Samsung TXG2548 TV
Kenwood KDC-716S CD Player Logo
178 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
