Question about Intuit QuickBooks Premier 2008 (3-User Pack): Windows
Company file in use message when several users access the file
Pop up message ''Company file in use'' when several users access the data file yet it is a multi user environment quickbooks software.
Then a certain user is performing a task please wait before you continue delaying the whole process and a slow response time.
  • rjivaro May 11, 2010
    Unfortunately the multi user part of your software means multi installation and not multi same file opened.
    If you think about it, it would be pretty much impossible to provide such a feature. If Joe and Bob both have the same file opened and both make a change to line 1, who gets to save their version? Computers are dumb beasts that can only do what they are told to do, and fortunately effort is expended when software is written to avoid exactly the above situation.
    This is an inconvenience for many more people than you (myself included) but at least at the current state of computer and software development it is impossible to avoid.
    Delays are usually because the computer is doing processing work, it needs more memory, more disk space or faster disks or leaner software that makes more efficient use of the system it is running on, or even that the software has to commit changes to disk before it can start the next requested process. Without more specific information I am unable to narrow it down. It might be worth going to the Intuit website to see if they have an update or a workaround.
  • Dick
    Dick May 11, 2010
    This is correct behavior, to prevent the document from getting out of sync. Only one user can use a file at a time. If you need multiple people to use the same file you need to have them working on multiple copies of that file, then merge the data from the multiple copies back into a master file. So - MASTERCOPY-->COPY1, COPY2, COPY3...
  • 122 Answers
If this is a real time program changes should be able to be made simutaniously. Check with your IT department, they may have to increase the allowed user #. If your position is top priority, some programs will allow more than one "super user" profile, the "super user" can make changes at anytime, but that profile is subject to corporate approval.
Posted on Apr 23, 2009
Tallyerp 9 memory access violation
If there are any user defined TDLs defined in the Tally.ini file set Default Companies to NO start Tally and check.
If the problem persists
Increase the screen resolutions to 16 bit high color small fonts, Load Tally and check.
Delete the printer drivers available in the Printer panel. Execute Tally. If this resolves the issue you can then re-install the printer drivers.
If the difficulty persists
After checking above-mentioned in case the difficulty persists please check the following.
Check for viruses in the system
Delete the Tally.sav file and check
Re-install Tally in a different folder and check
Disable the real time protection of the Anti Virus Software
Incase the problem persists please send an email to support@tallysolutions.com .
In case the problem is rectified when Default Companies is set to No in Tally.ini it indicates that the default company is corrupted. In such cases please follow the steps mentioned below
Take a backup of your company data
Execute Tally 9
From the Company Info Menu press Ctrl Alt R.
The Rewrite company screen is displayed. From the List of Companies screen select the Company in which you are facing the difficulty. The screen Rewrite Yes or No is displayed. Press Enter to re-write.
The error message indicates a data corruption. Please restore an earlier data backup which did not have this problem and proceed.
If you do not have the Backup then create a copy of the existing data and rewrite it by clicking Ctrl+Alt+R before selecting the Company.
Before rewriting ensure that the Company you wish to rewrite is not in use on any of the nodes and the command has to be applied before selecting the Company.
The data preferably should be available in the local hard disk. Ensure that you create a back up of the data in the the hard disk or a medium like CD.
Check http//www.tally9.info
http//www.tallyerp9.com
I found this howto here: https//answers.yahoo.com/question/index?qid=20100521043632AAsKkQs
Mar 31, 2014 | Computers & Internet
User logon error for 2004
From quoted information from Peachtree's KB system:
Go to Task Manager by pressing the CTRL+ALT+DEL keys and on the Processes tab look for W32MKDE.EXE, click to highlight and choose End Task. If W32MKDE.EXE is not shown, close Task Manager.
Go to Start, Find or Search for conn*.* Be sure you are searching the DATAPATH for these files.
Select all connco and conndp files from your datapath and choose delete.
Since you are using Peachtree First R2004, you will then need to go to Start, Run, and type in PFA110.INI and hit enter. This will open it in Notepad.
Scroll down to the [Options] section and look for the line ShowStartup=No, change this to read ShowStartup=Yes.
Look for the line LastCompanyOpen=[company name] where [company name] would be your last company opened company name. Delete the FULL company name after the equal sign.
Look for the line LastCompanyOpenShort=[company short name] where [company short name] would be your last company opened Folder Name. Delete the company folder name after the equal sign.
Select File from the menu bar and choose Save. Close the ini file.
Open Peachtree and select one of the sample companies. After the sample company opens, select File, Open Company and open your company data.
Mar 28, 2014 | Peachtree Software Peachtree Complete...
After updating the program, the server computer does not allow access to programs. Error messages come up -6150 and-1006. the file directory list every file 3 times, with no access from file directory...
Looks like it can be caused by:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
You can convert the file to a .qbw which is a quickbooks working file
Jan 19, 2011 | Intuit QuickBooks Pro 2010 Full Version...
I am getting error codes 6129,0 and 6073, 816 on my quickbooks 2008. What can I do to open the company?
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Jun 01, 2010 | Intuit QuickBooks Pro 2008: Windows
The connection to the company file has been lost Quickbooks must close immediately. Any unsaved data will need to be re-entered. My Company file is damaged and i have tried opening it on the another...
You will need to verify and rebuild your data file. Please follow the steps i provided, this will guide you threw the process.
Verify your data:
1. Close and reopen QuickBooks to create a new Qbwin.log file.
2. Choose Window > Close All, so that no company files or QuickBooks windows are open.
3. Choose File > Utilities > Verify Data.
* If you see QuickBooks detected no problems with your data, your data is clean. Click OK.
* If you see Your data has lost integrity, your data file is damaged. Run the Rebuild Data utility to repair the damage. You may need to run Rebuild two or more times to repair all of the damage. Rerun the Verify Data utility after each rebuild to verify that the errors have been corrected.
* If your see A data problem prevents QuickBooks from continuing, then your data file has a structural problem. Run the Rebuild Data utility to repair the damage.
Rebuild your data:
Important: If the company file is on a network drive, copy the file to a local computer before attempting to run this utility. Be prepared for this computer to be unavailable for several hours running the Rebuild utility. Never rebuild or update a company data file that is located on a remote drive (for example, by accessing it over your network).
If you can't open QuickBooks to run the Rebuild Data utility refer to QuickBooks does not open.
If you're unable to open your company file when double-clicking your QuickBooks desktop icon, see Opening QuickBooks when troubleshooting.
To rebuild the file:
1. Choose Window > Close All.
2. Choose File > Utilities > Rebuild Data.
3. Click OK to the warning message requiring a backup of the company file before starting the rebuild.
Important: Do not replace your current backup. Intuit recommends using a newly formatted external media source for this backup (such as a CD or DVD). If necessary, back up to your local hard drive.
If a message appears asking if you want to replace the backup file, click No.
To avoid overwriting the current file, enter a new name in the Filename field.
4. At the bottom of the QuickBooks Backup window, click OK.
Important: If the backup process fails, at the Rebuild prompt, click Cancel.
Do not continue the Rebuild process with your original company file if the back up process does not complete successfully. This can lead to permanent data loss.
You must make a copy of the company file and attempt the Rebuild process again using the copy of the company file.
Rename the copy of the company file with a unique name to avoid confusion with the original file.
5. The Rebuild Data utility starts as soon as the backup process completes. Click OK to the Rebuild has completed message.
6. Close the company file, and then reopen it to refresh the lists in the file:
1. Choose File > Close Company.
2. Open the company file:
* QuickBooks 2008 and 2007: Choose File > Open or Restore Company. Then select Open a company file and click Next.
* QuickBooks 2006: Choose File > Open Company.
7. Click the company file, and click Open.
8. Run the Verify Data utility.
Sep 22, 2009 | Computers & Internet
Error message : File is damaged. Rewrite!
Step 1: Start Tally.
Step 2:
Step 3:
Tally asks to select the company to rewrite. Select the desired company to rewrite and then press Enter key.asking-tally-to-rewrite-a-company.png
Step 4:
Rewrite confirmation will be appeared on the screen, press "y" to start rewriting process.rewrite-confirmation-in-tally.png
Step 5:
After rewriting the data Tally creates Tally.rew file in Tally folder.open it in any text editor and go through it about the corrupted data.rew-file-in-tally.png
Sep 15, 2009 | Computers & Internet
Error message
Hi beulah_jane,
What version of Simply Accounting are you using? 2007? 2008? 2009? Using Windows XP or Vista? Are the Simply files stored locally on the C drive or on a network? Can you open a sample company or are you getting the same error?
If you're trying to open the file using a shortcut to the data file itself, try using the Simply Accounting Program shortcut and then opening your file. If you're getting an encountered an error message, try searching through our knowledgebase.
In either case, I or another user can help you in our Simply Accounting Community at www.simplyaccounting.com/community
This includes a free Knowledgebase, Discussion Forum and blogs that you'll have access to. You may even find your answer already posted by another user in the forum. We have several knowledgeable users and our business partners going through the forum as well that can help you as well.
I hope this helps.
Andrew C
Simply Accounting by Sage
Online Customer Support Analyst
Mar 19, 2009 | ACCPAC Simply Accounting 2004 PRO...
Quick books error code(-6010, -100 ) Occasionally I will not be able to access my Quickbooks file. I receive error code -6010,-100. Rebooting the computer solves the problem, but this is not an acceptable...
Solution 1: For a standalone PC install of QuickBooks
  1. Choose File > Utilities > Stop Hosting Multi-User Access.
  2. Close and reopen QuickBooks. QuickBooks should now open without error.
Solution 2: Rename the .nd file associated with the company data file:
  1. Search the computer for files with extension .nd (Example: *.nd).
  2. Locate the .nd files with the name of the company having trouble opening.
  3. Right-click the .nd file, click rename and type old at the end ( for example, company.nd would become company .nd.old).
  4. Open QuickBooks.
Solution 3: If you are running NOD32 Antivirus Software with Internet Monitor (IMON)
  1. On the computer where the QuickBooks data is stored, find the NOD32 program.
  2. Disable IMON functionality.
  3. Reboot the computer.
Solution 4: Run reboot.bat
http://support.quickbooks.intuit.com/support/Articles/SLN41401
for more help step by step visit
QuickBooks Tech Support
Feb 07, 2009 | Symantec Computers & Internet
Software Exception c0000005
to solve this type of problem first of all take backup of your tally data then right click on ur tally icon on desktop go to properties then click on findtargate open ur tally configuration file see the line
load comony=yes (change yes into no) save the file & exit start ur tally pres ctr+alt+r selct the company which was giving error press enter tally will ask to rewrite the company press y to yes let the finish rewrite task then start working on tally
try this this works
RAKESH RANA
98682225794
Feb 02, 2009 | Computers & Internet
Sage 50 Accounts 2008
I think I got the solution for you ...
User Name is Already in Use / Cannot Access YYY because XXX is logged in
Typically, when you get this message you will be asked if you want to remove the user from the request list. If you are asked this question, simply answer Yes and you'll be able to continue.
An alternative solution is to go in the data folder for your sage data (the default folder for versions prior to 14 is c:\program files\sage\accounts\accdata for v14, the folder is c:\documents and settings\all users\application data\sage\accounts\2008\company.000\accdata on XP and c:\programdata\sage\accounts\2008\company.000\accdata. In the data folder, you will find a file called QUEUE.DTA - delete the file and you should be able to get back into Line 50. If you have a multi user version of Line 50, you should only delete this file if you are sure that no-one else is using Line 50.
Mar 20, 2008 | Sage Instant Accounts 8.0 (013604ug)
Intuit QuickBooks Premier 2008 (3-User Pack): Windows Logo
164 people viewed this question
Top Intuit Computers & Internet Experts
Scott Fair
Scott Fair
Dan Shibata
Dan Shibata
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
