Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Machine won't return to the home position
I have a Saeco Italia type sup021 Yr and when I turn on the coffee maker it dosen't go back to the home position so I csn't put in the freceiver for the coffee. The warning light is on and I am assuming this is because of this condition. I have tried shutting the front cover and turning the power on and off with no luck. Can you help?
  • 1,089 Answers
Hi
2 things.
1. You may have a broken brew drive.
2. You may have a brew drive that has jumped its micro switch.
Call a service center
Posted on May 30, 2009
SUP021 YR keeps getting clogged
go to espressotec logo there you find how you can clean grinder.if still you dont have coffee try explain better whats hapend with machine when you want make espresso,good luck
Sep 04, 2009 | Starbucks Saeco Italia Digital Barista...
SAECO Incanto Type Sup021 grinds and jettison grounds - no coffee
Here's how to fix your problem, remove the brew unit and clean the shower screen located at the top, under the red o-ring. Remove the screen and clean, then try coffee again this time adjust grind about 2 numbers coarser.
Jul 30, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Italia SUP021 YR how to clean metal filter?
The item you were refering to is: http://cerinicoffee.com/Saeco_Brew_Group_key.asp
It is used for removing the screen on brew groups: http://cerinicoffee.com/saeco_vienna_brew_Group.asp
It connects to item #4 below.brew_group_vienna5.jpg Authorized Saeco Service Center
www.CeriniCoffee.com
Oct 28, 2008 | Starbucks Saeco Italia Digital Barista...
Broken door hinge
Where are you living?
Best regards
/Mirran
Sep 08, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia Sup021 YR flashing red malfunction light
I found a link in the forum where there are some informations.
http://cerinicoffee.com/Saeco_technical_documents.asp
Hope this will help you.
/Mirran
Aug 22, 2008 | Starbucks Saeco Italia Digital Barista...
Digital italia espresso machine
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 28, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia sup021 coffee dispenser stuck problem
Hi
Open the front door. Remove the driptray. On the left back side of the brew group, there is a single screw. Remove the screw. Grab the handle and pull carefully, but firmly. The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position. If your brew group did not come out call a service center.
To return the brew group to the centered position, you first need to drop the funnel. To do this look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. Push the "Press" button and the shark fin moves up and down. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between. these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and to the center. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group in to the machine. First
you must close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, open the door and insert the brew group.
Done
Apr 25, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
148 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
