Question about Copystar CS-1815 Printer
Copystar CS-1815 reports a paper jam at the document processor
This occurs with first feed attempt, but no jam found. Code is 7F
  • 3,866 Answers
Check for debirs in the unit that could be tripping the jam sensor if not the sensor has gone bad.
Posted on Apr 23, 2009
Copystar cs-1815 error code 3200, how can it be fixed
If it is a c-3200 code it means that you have a exposure lamp problem.Defective scanner,defective scanner PCB,lamp or inverter board,incorrect shading,poor contact of the connector terminals on lamp assembly. Look for a bad connection And look at lamp. Look for blue rings or burnt ends. Now don't look at that light while its on.
Feb 02, 2015 | Copystar Office Equipment & Supplies
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
Copystar CS-C2525E. Paper Jam error 91. No paper
Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
Oct 06, 2009 | Copystar CS-4035 Copier
Code e70 on copystar 1810
Jam code 70 means: No origional feed. Paper is detected on the doc feedr tray, but when the start button is pushed - the origional don't feed through.
Mar 12, 2009 | Copystar CS-1810 Copier
Paper Jam
Ok, The Copystar CS-1820 is a Lemon, as an Authorized Independant dealer for Copystar. I can attest to this. This is a common problem from Copystar and their's not much that can be done. Unfornatel they should of stuck to the CS-1810 design they would of been better off/
Mar 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Can you help with kyocera cs-1820
Look in the Document Processor, That is the auftomatic feed device.Look for a scrap of paper jammed in the machine.Try using a dustblaster(canned air) to blow the debris out of the feeder.something in the feeder is operating the switch that detects paper in the feeder.Good Luck
Feb 11, 2009 | Kyocera Copystar CS-1820 Black and White...
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Nov 07, 2008 | Copystar CS-1815 Printer
Copystar 1505
j98 means there was a misfeed of the paper, you may have to have a tech look at this to figure out why its jamming, could be poor paper quality, worn feed tire and/or rollers. i would look at replacing the feed tire first that seems to be the problem most of the time...
Hope this helps...
Jun 07, 2008 | Copystar CS-1510 Copier
Constant Jam 71 in the document handler
Check feed Rollers,and Timing Switch-no 4 in attached file.
Switch was not deactivated in proper time .That means,maybe paper path has some obstructions(paper scrap etc... ) or some spring on switch is not in proper position.6845a74.jpg
Oct 16, 2007 | Copystar CS-1815 Printer
Copystar CS-1815 Printer Logo
143 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
