Question about Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Take pump apart - Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
    Top Expert:
  • Comfort Line Master
  • 6,465 Answers
Don't bother replace whole pump less hassle
Posted on Dec 05, 2017
Wayne well pump
How to take apart
Brian, Could not find a lot on this pump, maybe download manual or contact Wayne at the link below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Literature Wayne Pumps
Apr 01, 2016 | Wayne 6624027 1/2Hp Shallow Well Jet Pump
Craftsman shallow jet pump
the pump end should be repairable without taking the motor apart ..normally the long bolts that run through the motor housing can be taken out and the pump end serviced without pulling it all apart..send a photo of the pump..
Dec 13, 2013 | AO Smith Pool & Spa
I have a leaking drain pump. The water seams to be comming out of the motor / impeller coupling. Can it be fixed?
more than likely the pump can be rebuilt unless its a sealed pump but highly unlikely if u r mechanically inclined take it apart and replace every o ring and seal if u dont want to tackle it take it to a pump shop probably cost 75 to 125 dollars but if u take it apart pay close attention to how it comes apart and make sure it goes together exactually the same way hope this helps
Feb 25, 2010 | Miele Novotronic Premier 500 Front Load...
F 02 Error code, took apart and found 2 small
WHAT DID YOU TAKE APART AND FIND THE NAILS? WAS IT THE PUMP? SOME MORE NAILS MIGHT HAVE GOTTEN BACK IN THE PUMP OR THE PUMP IS DAMAGED.
Feb 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cant seperate pump motor from jets tring to clean jets
Every thing is made to come apart, look for any screws , if no screws then it doesnt come apart.
Feb 03, 2010 | Flotec Corrosion Resistant Shallow Well...
Pump fell apart - inner piece fell out
On these newer pumps, the plastic piston comes apart, and to fix it a new part is in order. Without looking at it, I think that is what might have happened. Bicycle pumps are almost throw-away items these days. In the old days you could buy all sorts of pump parts, but not anymore. Good luck
Jan 05, 2010 | Cycling
Hayward 2607 pump
FROM WHAT I CAN SEE ON MY SCAMATIC THE PUMP HAS A MECHANICAL SEAL, THE PUMP IS FROZEN TO THE MOTOR YOU CAN GET THIS APART BY TAPPING WITH A PLASTIC MALLET AND PATIENTS THEY CAN BE TOUGH SOME TIMES
Aug 22, 2009 | Hayward 1.5 Hp Northstar High Performance...
HELP!!! I keep getting an f-02 error code
F-02 is usually the drain pump on Maytag and Whirlpools.
I would take the pump apart- it should have three screws that hold it together. It could be that the pump has something really small like a paperclip stopping the impeller. Once you have the pump apart, you can even (carefully) wire the two electrical prongs on the pump to an old electrical cord, (carefully connecting one wire to each prong) and plug it into the wall to see if it runs.
The drain pump works on 120 volts just like the wall outlet, so if it doesn't spin when you plug it into the wall it needs to be replaced.
Also, there should be a technician sheet inside the machine somewhere which might have some helpful troubleshooting tips.
I wouldn't advise taking the motor apart until you have tried a lot of other things first.
Mar 24, 2009 | Washing Machines
Fuel pump replacement
the connectors come apart just take your time they will come apart
Jul 21, 2008 | 1995 Pontiac Bonneville
Kenmore 41729042990 Front loading washing machine
you can take the pump apart by removing the 3 screws that hold it together. take it apart to make sure there nothing in it that could be blocking the impellar. if theres nothing in there, replace the pump
Nov 26, 2007 | Kenmore 44042 Front Load Washer
Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White  Logo
49 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
