Stop the ringing.
The HP LaserJet M1522NF rings about 10 times before a fax comes thru. How can I stop the ringing to one ring?
  • 3,866 Answers
In the FAX setup screen you should be able to control the amount of rings before it pick up the phone try that let me know if it works
Posted on Apr 23, 2009
How seup fax ring
Before selecting the ring to answer, under stand what it is..
Press Menu button, scroll to fax set up with help of arrow keys, press ok button, scroll to answering mode. Select desired "auto, manual, fax & tele/fax.
What are these?
Auto: Auto aromatically tele mode will coverts in to fax mode irrespective of selected ring count. suppose if ring count selected as 4, printer will ring 4 times then stops ringing & converts in to fax mode. It doesn't matter whether it's telephone or fax.
Manual: Printer always telephone mode. To convert in to fax mode, need to press fax button while ringing.
Tele/Fax: Printer detects the incoming call type as tele(analog)or fax(digital) accordingly its will act. If its fax , line converts in fax mode with out any ring(silent detection), prints the received fax.If its telephone,printer rings as tele phone.
* In auto mode only you need to select desired ring to answer(2-6 rings)
There fore first you need to select "auto"mode, then scroll to ring to answer, press ok then select desired ring count, press ok to confirm..
Aug 23, 2014 | HP LaserJet 3050 All-In-One Printer
I have a provlem with fax on the HP LASERJET M1522nf
I have problem with my MFP 1522nf Printer I cant recieve fax on incomming call it is quite dead while It is set in automatillay answer mode when I dial it dial and gives tone but while in comming call no rings no reply ring answer mode is 1 but quite I checked every way settings wires but cant understand can any one know about this and help me.
My email gujjal@hotmail.com
Thank you
Mar 30, 2011 | HP LaserJet M1522nf Multifunction Printer...
I can not set my hp m1522nf printers for fax, I can not received & sending any fax. pl. solve my problem. Thanks,
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Have a nice day and do not forget to rate please...!
Dec 29, 2010 | HP LaserJet M1522n MultiFunction Printer
Data sending to fax fax to not recvied
go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set.
Feb 02, 2010 | HP LaserJet M1522nf Multifunction Printer...
The hp laserjet 3330 diverts to fax too quickly
What you need to do is on the printer, hit the menu/enter button, then scroll through until you see "Fax Setup" click enter, then scroll until you see "fax receive setup", click enter, then scroll until you see "rings to answer". Here can you set it to a higher number of rings, just remember to click enter once you've got the number set to where you want it.
Jul 09, 2009 | HP LaserJet 3330 All-In-One Printer
Stopped Receiving
use the print menus option in information, it should show the menu path settings
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Not receiving faxes
Any electrical disruption, interruption,disconnection can and will reset machine.
If you have ANY KIND of telephone answering machine BEFORE the hp3030, then you have to tell (or command) the answering machine to pick up in 2 or 3 rings. Tell the hp3030 to pick in 4 to 5 rings. I am sure that you know that a fax has a different signal then a regular "talking" signal. If both try to pick up at the same time, u confuse the ' poor little thing '.
Also:: take a look at all the wires going to the fax, telephone, answering and the wall output. Look for bent,cringed,cramped,twisted wires and replace if necessary. They will cause problems.
Mar 27, 2008 | HP LaserJet 3030 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
Changing the amount of rings
Pick the phone up earlier it will stop ringing......:-)
To set the number of rings-to-answer
To set or change the number of rings-to-answer, use the following steps:
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Fax setup, and then press tick
3. Use the < or the > button to select Fax Recv. setup, and then press tick
4. Use the < or the > button to select Rings to answer, and then press tick
5. Use the alphanumeric buttons to enter the number of rings-to-answer, and then press tick
But I still think picking up the phone earlier would be easier
Your Manual, please rate as fixya or post back
Dec 28, 2007 | Office Equipment & Supplies
Answering machine turns on and I can't receive faxes.
Why don't you consider a separate Phone/Fax switch. It will answer first ring and detect a fax and then ring the fax/printer you can set that to one ring as well, otherwise it ring the answering machine that is plugged into that and you can set that to answer on 3 or 4 rings. Then you have time to pickup phone if you are available.
Thanks what I do. The boxes are about $30 They are fairly cheap.
Nov 24, 2007 | HP LaserJet 3055 All-In-One Printer
210 people viewed this question
jasbo
jasbo
