Question about Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater
Flashing r05 when push powe to turn on - Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater
I have qnexusnx wireless adapter. when I try to make flash go off i get error r05 which is supposely a buffer message and the shutter will not trip.
Try this method Switch on the adapter, while on remove the battery Leave for about 30 secs with the adapter still in 'on ' mode reinstall the battery let it power up then switch off leave for 30 secs then switch on. This may clear the buffer.
Oct 02, 2015 | Cameras
R05 error on nikon d80
The Nikon D-90 users manual says on page 256 that the ERR message indicates a camera malfunction and that it can be cleared by releasing the shutter.
I've found on my D-90 that the only way I can get the shutter to release is my turning the camera off. When I turn it back on the ERR message is gone and the camera functions as it should.
Occasionally, I have had to remove and reinstall the battery to make the camera turn off but this happens only rarely.
The users manual says if the condition occurs frequently or persists that you should contact a Nikon authorized repair center. I suggest that you contact Nikon tech support at www.nikon.com to see what they suggest. I think this information would apply to the D-80 as well.
The r05 is not an error message. It is an indication that the camera is shooting in burst mode (multiple shots with one button push) and that you can shoot five more shots before the camera must pause, clean its cache and be prepared to shoot again.
Feb 02, 2014 | Nikon D80 Digital Camera with 18-135mm...
No turn on
pow pow pow pow
check all 4
power circuit breaker at panel power cord power outlet on wall
power switch on unit
Jul 11, 2012 | Amcor KF 9000 BTU Silver Portable Air...
I tried using a masterlink tool on a pow-link and squished, nowthey binde a bit and i still cant get the pow-link off. hellpppp!
the power link doesn't use pins like normal chain you have to push the link together then it will come off sideways.
Mar 04, 2011 | Sram Bicycle Chain Power Link Connecting...
D80 suffering from error code r05 and r06 along with flashing err on the lcd display. Camera only captures a shot every other shutter release. Removed lens and cleaned contacts, cheged to a different...
As far as I can read in the manual there is not any error code r05 and r06. My guess is you are seeing that in the LCD on top of the camera. Turn to page 36 in the D80 manual there you is what you are after. The r05 and r06 are the number of shots remaining in the buffer.
Aug 07, 2010 | Nikon D80 Digital Camera with 18-135mm...
During using D90 for son's b-day my camera kept freezing up and giving a code of r05 and another code once that I don't remember. Why and what does r05 mean? I even turned the camera off at times but it...
The r05 is not an error. It's simply telling you that the buffer has room for five more pics. It's only a problem when it gets to 0 and stays there.
As to the other error, I'm afraid I can't help you there.
Jul 10, 2009 | Nikon D90 Digital Camera with 18-105mm...
Metz 58 AF with Nikon d90 wont flash
Hi, Bad news for you.
Try this.
  1. put new batteries in flash.
  2. turn flash on off camera.
  3. listen for capacitor to squeal (high pitched whistle). If you hear it it is charging. If not capacitor is bad.
  4. Also should see flash ready light come on. If it does not same as #3 above.
  5. If you pass #3 & 4# above press manual flash/check/test button on flash. No flash means bulb is out. It can be replaced.
Hope this fixed ya. Please rate. Good Luck! Comment back if you need further assistance.
Mar 14, 2009 | Metz 58 AF-1 FLASH f/NIKON TTL Flash
1996 Ford Crown Victoria Shifting
when was the last time you had the fluid and filter changed? This trans should be done every 30,000. Is it shuddering as the torque converter locks up?
TSB 97-10-6 has a repair procedure for this ysmptom:
Vehicles equipped with an AODE or 4R70W transmission may experience a torque converter clutch shudder or vibration. This occurs under light to moderate acceleration above 56 km/h (35 mph) while in 3rd or 4th gear. This may be due to either transmission fluid breakdown and/or the Powertrain Control Module (PCM) calibration.
Verify that bulk fluid does not have moisture contamination. If suspected, use quart containers of MERCON®. Refill transmission with the proper amount of Motorcraft MERCON® Multi-Purpose Automatic Transmission Fluid (ATF) (XT-2-QDX).
NOTE: DO NOT USE MERCON® V.
Check emissions decal to verify vehicle has the latest calibration. If it does not, reprogram the PCM to new calibration level using Service Bay Diagnostic System (SBDS) or New Generation Star (NGS) Tester with May 1997 CD-ROM or later. Refer to the PCM Calibration Chart found at the end of this article for proper application.
NOTE: VEHICLES SHOULD BE DRIVEN A MINIMUM OF 480 km (300 MILES) TO WORK THE NEW FLUID INTO FRICTION MATERIAL.
PCM CALIBRATION CHART Application Old Calibration Old Part Number (-12A650-) New Calibration New Part Number (-12A650-) 1996 Crown Victoria/Grand Marquis 49S/Canada/High Altitude 6-18F-R05/R11 F6AF-AE 6-18F-R11 F6PZ-DJA 49S/Canada/High Altitude 6-18H-R05/R11 F6AF-BE 6-18H-R11 F6PZ-DKA Mexico 6-18H-R05/R11 F6AF-KE 6-18H-R11 F6PZ-DMA Police 6-18I-R05/R12 F6AF-CF 6-18I-R12 F6PZ-DLA California 6-18M-R05/R11 F6AF-DE 6-18M-R11 F6PZ-DNA California 6-18N-R05/R11 F6AF-EE 6-18N-R11 F6PZ-DPA
Mar 02, 2009 | 1996 Ford Crown Victoria
Panasonic NV-GS50 - Display indicates "To Service"
This means you need to get it serviced, because it has detected a fault or error.
Sep 06, 2017 | Panasonic NV-GS50 Mini DV Digital...
Ilo DVDR05 Firmware help
Goto www.cyberfixer/ilodvdr05_repair_guide_FREE.htm At the very bottm of the page there's updates you want.
Jan 27, 2007 | iLO DVDR05 DVD Recorder
Comfort Zone CZ1500WC Infra-Red Utility/Portable Heater Logo
20 people viewed this question
Top Comfort Zone Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
