Question about Panasonic DVD-LX95
Panasonic dvd-lx95 error code h03 - Panasonic DVD-LX95
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 62 Answers
Lube up the slider that the laser slides on (slides in towards the center of disc and back out). Check for any debris that may be present.
Download Panasonic DVD LX95 Manual
Posted on Mar 18, 2015
SOURCE: error code on Panasonic LS50 portable DVD player
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. i pointed out that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
Posted on Dec 12, 2007
Benimur
  • 6966 Answers
SOURCE: H03 Error
With the indulgence of bbtoast and DARKLORD1...
This is a known common problem with most Panasonic DVD units. An HO3 error display indicates a "Traverse Servo Problem". The traverse servo is the motor that drives/moves the optical pickup (lens + cradle) to slide along a shaft while reading the disc.
A HO3 error could either indicate problem in the:
1. shafting/slider: possibly clogged with dust, dirt or dried up lubrication;
2. stuck up/defective traverse motor;
3. defective wiring connection, electronic regulator/controller.
As you will note, all of the above requires opening the unit and component level repair. Since this would need familiarity with electronic components/circuitry, use of a DVM and possible a soldering iron, perhaps you might be better off seeking the services of a qualified professional.
Hope that this be of additional help. Pls post back how things turned up or should you need additional; information.
Good luck and kind regards.
Posted on Jan 05, 2008
SOURCE: panasonic DVD ls 850 , H03 Code error
I have an LS82 and the following advice from www.avsforum.com fixed the problem for me. Note that the number of screws that hold the bottom on the machine vary depending on the model. Also the server frame might be plastic instead of metal:
Originally Posted by Hossam fixing code H03is very simple but needs some courrage and small philips screw driver.
the problem arrise from the laser lamb which moves up and down the disk through a mechanical shaft
I do believe when we press the back space for long time it will take the laser lamb beyond its limit and get stuck at the end of the rotating shaft so the servo motor gets difficulty and resistance to get it back to tract
all you have to do is open the back of the LS50 " 12 small screws"
mad.gif when you remove the back cover be carful not to damage the cables mad.gif .
you will find the servo motor and laser lamb on one metal structure hanged to the body by three rubber suspensions
remove the whole structre and turn it upside down slowly
move the small black rotating joints up or down you will notice the the mechanical shaft will start rotating and the laser lamb will start to move away from the servo motor relasing it from where it get stuck
and it will work perfect after that
return the back cover and screw the 12 screws and you are done
Posted on Jun 13, 2008
  • 98 Answers
SOURCE: panasonic DVD ls 850 H03 code error
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Posted on Oct 21, 2008
alpug
  • 1961 Answers
SOURCE: Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Posted on Jul 17, 2010
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Player will not read. Error code H03 shows up on screen.
Dirty worm gear on laser (dirt or particles got caught not letting the pick up move easy go take apart but be careful many small screws and gears.
Oct 06, 2009 | Panasonic DVD-LS91 Portable DVD Player...
HO3 error panasonic DVD-LS80 disc will not play?
como hacer funcional el lente del equipo, tengo un error h03 VDV-LS80
May 26, 2009 | Panasonic DVD-LS80
H03 Error & Disc Tray Error
Most likely the tray for your player came out of aligment, this happens when someone pushes on the tray to close it, instead of using the "Open/Close" button, you need to take it to somebody to realign the disc tray.
Jun 13, 2008 | Panasonic DVD-RP56 DVD Player
Panasonic DVD ls 850 H03 Code error, how to solve this problem
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Code h03
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its path. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jan 17, 2008 | Panasonic DVD-LS90 Portable DVD Player
Panasonic DVD-LX95 Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
