Question about Jensen's VM9312 Car DVD Player
Screen wont open all the way
The screen will only come out a lil bit but after a few times of trying it will come out more and more then it will finley come out the hole way. why?
I know on mine i had to push it back gently then use the tilt function to bring it back. I have to do this at least once a week.
Posted on Oct 15, 2007
SOURCE:
Smoking white
Probably going to need new piston rings. Pretty sure your burning a little oil.
Feb 10, 2014 | Suzuki Motorcycles
I don't know why but my star theater pro the slide stack in there and I can't take it out now
Try this use some rubbing alcohol and needle
Throw a lil bit of alcohol and gently move ur needle all the way around until u have worked it all in
U might have some sticky grime in their and its preventing the button from extracting Here's another tip open up ur device WITH OUT POWER and inspecting it a lil bit more up close
Dec 17, 2013 | Audio Players & Recorders
The begining gameboy screen comes up but the nintendo logo has lil dots above each letter n it stays on that screen help if you how to fix this
it sounds like your game is messed up you might have to buy a new one but try taking it out and blowing on it and putting it back in a few times
Dec 22, 2010 | Nintendo Pokemon Crystal
55cc air induction chain saw wont start,keeps flooding
what do you mean by flooding?
if it is overflowing?
try to remove the 4 screw underneath the carb,
take out the diaphragm,and then followed by float valve..
there is a tiny spring,be very careful...
stretch the spring a lil bit more at about 2mm...
as time passes,the diaphragm deteriorate and one way to correct them is by stretching the tiny spring to give more strain on the diaphragm...
this is what i did if i am too lazy to go out and buy the diaphragm kit..
only 10 bucks...hehe
Jul 15, 2009 | Husqvarna Garden
My sun roof doesn't work well
I would open the sunroof COMPLETELY , clean tracks , and lubricate tracks as far back as you can. Operate the roof back and forth a few times. This should help
May 14, 2009 | 1995 Lincoln Continental
Have problems starting motorbike
Look around the accelerator cable for like a little twisty knob thing that controls the throttle and turn it up a little bit. Basically opens the cabs up and lets a lil more fuel in making the rpm a lil higher and should prevent it from stalling. As for the hard to start problem, Try usung the choke a bit and if that fails give it some gass(if the throttle has been opend and closes when off it may be flooded or try replacing the starter motor and battery.
Apr 13, 2009 | 2005 Hyosung GT 250
360 not working
That means that its overheating! Microsoft has offered an extended warenty on these types of situations, call them and they should service the issue for you. in the mean time, try removing anything from the sides of the 360 and make sure that it has lots of room to breath. also take a cloth and wipe off all the dust from the unit, as that can help quite a bit.
Jan 25, 2009 | Microsoft Xbox 360 Console
Dropped my phone a few too many times. now when i shut the phone, the screen appears "blank" or not illuminated at all. keys are illuminated, but not the screen. still haven't gotten the id...
its the electronic belt that connect the screen to the keyboard is might be cutted or got a lil bit moved from its original place disassemble the phone and see what can u do about that if its cutted buy a new one and solder it its edasy u can
Aug 16, 2008 | Motorola Cell Phones
Jensen's VM9312 Car DVD Player Logo
159 people viewed this question
Top Jensen's Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
