Question about Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
Bosch Aquastar error code F7 - Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125
SOURCE: I have a Bosch AquaStar 2400ES-NG, Error Code EA
There are three electrodes (connected next to each other by a single piece of metal) that run up into the heat exchanger. They are situated behind the black plastic air intake in the lower half of the unit. Pull out the electrodes and clean them off with steel wool or fine sand paper. Also take the opportunity to blow the dust out of the inside of the unit and clean out the air intake.
Posted on Jun 15, 2009
snap101
  • 117 Answers
SOURCE: Whistling Bosch AquaStar 2400ES-NG
if you have incorrect gas line size when it kicks on the lack of gas pressure to the unit will cause a wistling. make sure you have enough gas to the unit
Posted on Jul 29, 2009
  • 244 Answers
SOURCE: ec code come up & no hot water
Open up the front cover - look at the printed curciut board and see if you have two or three capacitors that the tops are slightly raised...if so, those capacitors on the board need to be replaced...they should be competly flat.
HTH,
Mike...
Posted on Dec 05, 2009
  • 33 Answers
SOURCE: Bosch Aquastar 2400E LP Does Not Heat Water
Sounds like the water flow sensor and servo, may just need cleaning, get it checked out by a Bosch agent
Posted on Jan 17, 2010
1stBSP
  • 52 Answers
SOURCE: i have a 250SX aquastar bosch tankless hot water
The 250 MUST have the condensate line connected. EC comes from gas supply problems and CO2 levels not being adjusted. LP units require 3/4" smooth gas pipe or 1" corrugated pipe minimum size. The LP regulator needs to be turned up to about 13 inches of water column and with all the gas appliances on, measure no less than 11 inches of water column. The CO2 levels must be measured by a qualified gas technician with a calibrated (with in 6 months) CO2 analyzer.
Posted on Apr 11, 2010
Getting an F7 error that won't clear. From what I found, this indicates Ionization is on standby. What does that mean? What do I need to do? Thanks!
you must read your owner manual read the troubleshooting section, and if the problem persist, get the website with your supplier and connect via ONLINE chat with technical personal in order to Help you and fix it.
God bless you
Oct 11, 2013 | Bosch AquaStar 2400ES-NG
Error code F7
reset the system turn OFF and wait by 5 minutes, and start again. If the problem persist, you must get support via ONLINE chat, in order to fix it.
God bless you
Oct 11, 2013 | Bosch AquaStar Propane Tankless Water...
Bosch aquastar wont get hot
1) If tankless is not showing error code, the problem might be single-handled faucet cartridge:
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
2) Catch up on maintenance, such as cleaning combustion parts, have gas pressure checked, etc.
Feb 20, 2013 | Bosch AquaStar Natural Gas Tankless Water...
E7 code what to do ?
Before calling service technician, call Bosch. 800-642-3111
E7 is not shown as common error code.
Error codes are considered start-point for troubleshooting.
Open following links for general Bosch troubleshoot resources:
Common error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Service bulletins for reading how to fix tankless yourself:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/ServiceBulletins/tabid/1300/Default.aspx
Aug 27, 2011 | Bosch AquaStar 2400ES-NG
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Nov 10, 2009 | Bosch AquaStar 2400ES-NG
Bosch AquaStar Indoor Natural Gas Tankless Water Heater with Vent Hood #125 Logo
66 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
