Question about Building Materials
My genie powerlift 900 won't program to my remotes.
4 Suggested Answers
blanchettohd
  • 143 Answers
SOURCE: I have a Merlin Powerlift-Model 2500L Garage door ...
This is a foreign design but here is what the instructions say to do.
Remove the light cover then remove the colored plastic rectangle strip located underneath. This will reveal a red Learn/Delete? button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode. 2. Push the big button on your remote for 2 seconds 3.Push the little button on your remote for 2 seconds Minimum of 1 second is required between each action Your remote will now operate with your motor b) Overhead Doors Remove the coloured plastic rectangular strip located next to the Merlin label on the front of the motor. This will reveal a red Learn/Delete button. 1. Push Learn/Delete button for 2 seconds the lamp will blink continuously to alert you that it is in Learn Mode 2. Push the big button on your remote for 2 seconds 3. Push the little button on your remote for 2 seconds *Minimum of 1 second is required between each action Your remote will now operate your unit. Thanks BB
Posted on Sep 03, 2010
taran_2005
  • 10515 Answers
SOURCE: Have a Genesis MX-900 universal
There is a simple fix that will resolve most problems with the MX-900, including some that seem to be PCB failures like garbled screen text or the dreaded "stuck in test mode". If you have any problems with this procedure, call URC tech support so they can walk you through the process, called the "Boot Loader" procedure.
1.Open up battery compartment & remove 1 battery from cup.
2.Press & hold the "On" & "Mute" buttons simultaneously. While pressing both buttons, reinsert the 4th battery into the cup. You should get a blue screen with the word "Loader" on the page heading.
3.Download your programming to the remote. If you get an eror message pertaining to the USB connection, ignore it, as your file should have down-loaded successfully. If not, run the boot loader procedure again.
I have also seen instances wherein I "unlocked" whatever failure the unit was experieincing using the boot loader procedure. Before downloading the programming, however, I simply removed & then reinserted the batteries, & the unit retained it's previously programmed information. Most of the time, however, you will have to reinstall the custom programming. I have found this fix(the boot loader procedure) to work with about 90% of the MX-900s I have serviced, even for remotes that have seemingly died & will not boot up when batteries are installed.
In case if the problem persists, you need to call a technician on site for repair.
Thanks and Regards
taran_2005
Posted on May 14, 2011
ercupa190
  • 12223 Answers
SOURCE: genie g3t-r remote seems like it 's programmed but doesn't open door. led's suggest it was programmed.
1) test the batteries 2) rETIGHT THE spring contact batteries 3) Resolder wires for contact batteries, see if there are some wires missing. 4) Try again with the codes.
go www. fitness.manualsonline.com get the code , and reset again.
Otherwise the remote control you must go to the repair shop.
God bless you
Posted on May 10, 2012
Beam: one red light, one green light - how to make both green?
Have a look at the 'remote control programming' section on page 9 of the manual. Note, the manual says that the LEDs illuminate blue, not green.
http://www.geniecompany.com/data/products/genie_owners-manual_eng.pdf
Apr 24, 2016 | Genie PowerLift 900 1/2 HP Screw Drive...
Garage door closes but doesn't stay closed
if nothing is obstructing the door then there are 2 possibilities:
a) your limit switch for closing is too low and the closer detects the motor stall as the floor is reached, then opens in case it's a kid under the door.
b) your tracks and garage door are mis-aligned, causing excessive force to trigger the reversal. Make sure the door closes easily by hand.
Jun 19, 2015 | Genie Powerlift 900 Garage Door Opener
How to program a remote for a genie garage opener model 209
When programming a genie remote press the learn button
Then you will have to press the genie remote at least three times before it stores the code older genie models 5 times genie i
Apr 05, 2015 | Building Materials
Genie 900 door operator
hello,there is an adjuster on the side of the motor,also check that the micro switch[if fitted on your particular type} is 'clicking' and actually in contact with the arm as it revolves closed. hope that helps, cheers
Jun 02, 2014 | Genie PowerLift 900 1/2 HP Screw Drive...
Why wont the carriage assembly go past the screw splice
I think the threads are different. I have the same problem and the threads in the small splice part are different. i must have the wrong splice.
Dec 30, 2010 | Genie Company Genie PowerLift Excelerator...
I bought a chamberlain clicker and want to program it for use with a POWERLIFT garage door
This remote is compatible with your power lift. It should of come with a manual on how to program it as well. Each opener has a different sequence to program it so I can't just give a general answer. On a chamberlain powerlift look for the color of the button while programming it. If you need a copy of this manual you can get one at chamberlain.com. Thanks BB
Aug 29, 2010 | Chamberlain Clicker Universal Remote...
Genie excelerator light won't turn off...
First unwire the wall button. If the light will go off now replace the wall button. If not then you will need to replace the logic board on this unit(genie.com for replacement). Protect this with a surge protector as well 900 joules or higher. Thanks BB
Jan 21, 2010 | Genie Company Genie PowerLift Excelerator...
Building Materials Logo
37 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
