Question about Maytag Washing Machines
How much is a 2 year old maytag washer worth - Maytag Washing Machines
5 Suggested Answers
  • 2976 Answers
SOURCE: our 7 year old maytag washer won't aggatate
Only you can answer that. The belt costs about $10 and a new machine costs from $400. If the transmission is out, thet can be purchased for about $100.
Posted on Dec 28, 2009
  • 401 Answers
SOURCE: Maytag neptune MAH3000aww washer, will not work on
NEPTUNES HAD A ISSUE WITH THE DOOR WAX MOTOR SHORTING OUT BUT IT BURNS OUT THE MAIN BOARD.IF THE DOOR LOCK LIGHT DOES NOT COME ON REMOVE POWER THEN REMOVE SCREWS OFF THE TOP OF THE TIMER COVER AND TIP IT FOWARD. LOOK ON THE MAIN BOARD AND SEE IF YOU NOTICE A BURNT RESISTOR P-11 POSITION I BELIVE
Posted on Jan 12, 2010
SOURCE: I have a maytag Atlantis washer - 7 years old, it
I have a Maytag Atlantis top load washer which leaks in the rear right hand corner under the discharge hose, how do I take the machine apart to get to the problem.
Posted on Feb 06, 2010
rickyrt441
  • 4399 Answers
SOURCE: Maytag Atlantis mav8551aww my washer is
Thanks for choosing FixYa and welcome to the site. More then likely, you probably have a bad spin bearing or motor drive. Since your problem appears to be within the spinning, I would check the spin bearing first. Anytime noise is associated with spinning, it is usually one or the other. It just depends which one is bad. The bearings are not a large financial setback. If the motor drive is bad, it can get a little costly.
Posted on May 05, 2011
My Maytag Ensignia washer is making a clunking noise like something is loose when it is in the rinse cycle.. also does not appear to be spinning as well as it should. What could be wrong with it
Mine had the same problem! Turned out to be the transmision going bad. My machine is only three years old. Transmision cost over $250 Not worth fixing. The inside of this machine is very poor quality. I am very disapointed. Maytag not the quality it once was. I WILL NEVER WASTE MY MONEY ON A MAYTAG PRODUCT AGAIN
May 24, 2010 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag washer will not agitate
A Maytag A412 is well over 20 years old....
Best guess is a corroded upper drive shaft, the one that the agitator is mounted on. Certainly it can be called a transmission problem.
Jun 28, 2017 | Maytag Washing Machines
Our 7 year old maytag washer won't aggatate , is this worth fixing?
Dec 28, 2009 | Maytag MAV2755A Top Load Washer
I have a maytag neptuen washer purchased in 1999. During spin cycle is making a lot of noise and I have repair man check and he said it would be over $500 to fix as it's the bearing and the drum would need...
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer ID doesn't mean
much to me. It's been about 55 years since I had
experience with front load washers. However I can
suggest you go to www.applianceaid.com where
they have very good trouble shooting and repair
information on front loaders. I think you'll find what
you need there. Good luck with it.
Nov 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
I think my Maytag MAV6200AWW washer has a bad tub seal & bearing
if you have had this unit for over 5 years Then it is TOTALLY NOT worth the repair - if it is only a year or 2 old then call MAYTAG and they may offer a parts/labor concession. average life is 5-10 years now as sucky as that is!!
Nov 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Can't find value or date of manufacture of wringer washer(maytag)
I have a 1936 maytag gyratator wringer type electric washing machine in very good condtion - it works like a charm. What is it worth? I am out of room to continue storing it inside and it too good to leave outside - all the decals on it are like new with the exception of the bottom of the one with the years of maunfacture on it - it goes from 1922 to 1936
Mar 19, 2009 | Maytag Washing Machines
Agatator problem
being a maytag about 30 years old i would say the belt is broke or transmission is locked up ,,,, if it was a newer style you may have difference problem that could be easier repaired
Dec 08, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag legacy series washer leaking
Price is right. Repair time is right for an inexperienced repairman. Worth it ? If you watch what you are doing and not rush then, yes, it's worth it.
Jan 11, 2008 | Maytag Legacy Series Top Load Washer
All my washer will do is spin no matter were In set it
The timer contacts have welded together. Replace the timer.
Jan 11, 2008 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
