Question about Yamaha RX-V757 Receiver
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
My Yamaha HTR-6050 Surround Sound system shuts off at random times.  Then, a message pops up that says "Check SP Cable".  I've checked all the cables, but the problem continues.  I'm not a huge technology guy, so I don't exactly know which cable is the SP Cable.  So, if someone has a suggestion or can tell me what the SP Cable is, it would be appreciated.
Thanks I've got a Yamaha RX-V757 hooked on Definative Speakers. It shuts of every time i get to about -17db although different songs might last longer than others im guessing the wave lenghts. Is this with all Yamaha?
  • zandermagic May 12, 2009
    I am having the same problem, and it is really annoying. I get an error message (1) but I don't knwo what that is.
    I have the same problem. When the audio peaks or spikes during a film the receiver just shuts down. I get the same error message and the menu says error (1) but I don't know what that means.
  • 44 Answers
I think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Posted on Apr 23, 2009
My yamaha receiver RX-V363 keeps shutting off and saying check SP cable
It is one ot two things, the audio output transistors or ic,s are shorted, or the speaker wires in the back of the surround sound are shorting.
Apr 08, 2012 | Yamaha RX-V363 Receiver
TV/DVD surround sound through receiver
Try running digital audio from the source - cable/sat - to the receiver. The fewer intervening connections and entities, the better. TV's are NOT considered sound sources for high end purposes or we wouldn't have Yamaha HTR-5860's and better speakers, would we?
Apr 22, 2010 | Yamaha HTR-5850 Receiver
NO sound, display says CHECK SP cable? Just bought yamaha292 theater system with AV receiver HTR-6230, all speakers are wired, plug with 1 optical to my TV, selected the inputs and there's no sound. ...
Probably the speakers are not wired correctly. Check this by turning on the receiver without speakers connected. If the message is gone, issue was in the connection of speakers. Check that you have not short-wired the + and -.
Dec 13, 2009 | Yamaha HTR-6130 Receiver
Problem with sp cable (yamaha)
The speaker cables are the ones that clamp or tighen down on the back of the reciever. All the spkr wires have to have the positive and negative leads correct. Also not aven one little strand of wire can be touching another conductor or you will have this problem. Make sure all leads are correctly ran and hooked up positive to positive and negative to negative from the back of the reciever all the way to the speakers. This should solv your problem.
Jul 25, 2009 | Yamaha HTR-6030 Receiver
Yamaha 5.1 says Check SP Cable and shuts down - has been fine.
It has nothing to do with the input you choose. A speaker wire is shorted. Disconnect each one in turn and try it. The last one disconnected before it stops failing is the one.
Mar 22, 2009 | Yamaha HTR-6030 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
That is a check the speaker wire error, caused by a short or perceived short. If you look at the back of the receiver you may see 1 strand of the wire loose, they are very hard to see sometimes. You may use banana plugs as it is painful to get everything hooked up without a few loose strands.
If there is still the issue check your speaker connections for the same issue. If they are in ceiling/wall speakers disconnect them all then plug them in one at a time to narrow it down.
If the issue persists perhaps one of your speaker wires has a short somewhere, could be a misplaced drywall screw from hanging a picture, or a carpet tack strip, or a pet deciding it was a nice chew toy.
If you are completely sure it is none of those then I would say it is a bad speaker or receiver. Try changing in and out known good speakers/receivers if you have access to them to see which one it is.
Good luck
Feb 03, 2008 | Yamaha HTR-6030 Receiver
6050 yamaha receiver issues
the problem is how you wired it, guess you plugged the ps3 directly to the tv. to hear the ps3 through surround sound, you would have to wire it through the reciever like everything else...
Jan 28, 2008 | Yamaha HTR-6030 Receiver
My yamaha htr 6050
Make sure you speakers are turned on on the receiver,
Jan 23, 2008 | Yamaha HTR-6030 Receiver
"Check Speaker Wire" error on my Yamaha Receiver
found the source of the problem with "Check SP Wires"! to solve it is necessary to check each speaker connected to the device Yamaha on the rear panel (red and black) using the device for determining the number of ohms, which shall not be less than 4 ohms, in large passive speakers experienced in Amfitone AU-027, the result showed that left at 0.45 (7) ohms, and the right-hand column, as such, no.
The successful test ... and good music!
Mar 13, 2007 | Yamaha HTR-5790 Receiver
Yamaha RX-V757 Receiver Logo
1,119 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
