Question about Canon NP 6050 Copier
What is error e051 and how I can fix it ?
2 Suggested Answers
  • 118 Answers
SOURCE: ERROR CODE E051
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again thre is a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Posted on Jul 03, 2009
Error code e051
the horizontal registration home position detection mechanism has a fault
May 01, 2014 | Canon imageRUNNER 400 Printer
Toshiba estudio 167 E051
E051 use to be a false duplex jam on the IR-550 and was always a bad MSW5 switch causing the problem
Sep 20, 2012 | Toshiba Office Equipment & Supplies
Ihave canon 400 problems. e051, e901, e805 problems frequently please suggest me
by the look at your problems:
E051 - Horizontal registration sensor problems
E001 - Fixing temperature faulty
E805 - The Fan rotation problems
It can be that You have problems with DC contoller ( main pcb ) or the copier is in worst condition and there are faults on every segment.
For E001, you can try to reset error:
1. The following error codes cannot be reset by merely turning off and then on the main power.
They require resetting in service mode:
E000, E001, E002, E003, E004, E032, E717
1) Start service mode, and select COPIER>FUNCTION>CLEAR>ERR.
2) Press the OK key.
3) Turn off and then on the main power.
2. Error codes other than the above may be reset by turning off and then on the main power.
n Detail Code
Some error codes offer detail codes, which may be checked in service mode:
COPIER>DISPLAY>ERR (3rd block from the right)
BUT I THINK THAT THE BEST SOLUTION IS TO CALL SERVICE TO RECTIFY THE PROBLEM OR YOU BUY NEW MACHINE:..
Hope that helps!
Jul 22, 2011 | Canon imageRUNNER 400S Copier
Can the E051 error message be fixed by someone other than a technician. On a Cannon Image Runner 400/330 series. I tried finding the upper right side sensor that should have long white plastic teeth
Someone who is not a technician can only do the following:
1. disconnect the souter and detarche it from the machine.
2. E051 means the souter ias not functioning properly discopnnect and the problem is gone while you look for the technician to repair your souter.
Jul 12, 2011 | Canon imageRUNNER 400S Copier
Just got this used canon imagerunner 330s. It seemed to be working OK but now wont finish powering up and displays an E051 code. Can I clear or bypass this? What does this code indicate? Thanks, Keith
Error code E051 indicates there is a problem with the movable paper guides in the duplex unit. Check that the rear connector for the Duplex unit is clear of paper or toner
Feb 16, 2011 | Office Equipment & Supplies
Canon Gp 335 E051
E051 indicates that the side or horizontal registration sensor is not detected try to switch off/on the machine but if the same error code display again thereis a small motor that drive the sensor assy should be change.try to move the sensor manualy by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 17, 2009 | Canon imageRUNNER 400S Copier
My mich suddenly shows that E051 error can any one help me
E051 indicates that the side registration sensor is not detected try to switch off/on the machine but if the same error code display again there is a small motor that drive the sensor assy should be change.try to move the sensor manually by opening the upper right side peep inside you will see a long white plastic wth teeth push to this to right side hope this will help
Jul 07, 2009 | Canon Office Equipment & Supplies
ERROR CODE E051
Jul 03, 2009 | Canon imageRUNNER 210S Copier
Canon IR400 copier
dear sir, I have ir400 copier. please help me to solve the error no. e051. thanks,
regards
Jan 10, 2009 | HP Compaq dc5700 Microtower - Free Flat...
What is that eror code E000051-0000
E051-0000
At start-up, home position is not detected when the horizontal registration assembly is moved 100 mm in the direction of home position.
because The horizontal home position sensor is faulty or the horizontal registration motor is faulty.
Dec 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon NP 6050 Copier Logo
21 people viewed this question
old marine
old marine
