Question about Tools & Hardware - Others
Compatible staples workzone staple gun - Tools & Hardware - Others
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
  • 2712 Answers
SOURCE: staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
tbirdfan1
  • 3051 Answers
SOURCE: reloading ace 22084 staple gun
Hello there:
when you purchase staples for this particular gun even though you might get a staple that is says it fits this gun you need to look at the type of staple if you get the one that says heavy duty it will not work it took me 2 times to find out the right ones for this gun it comes in a green box and says standard duty on it not heavy duty this is where most people make their mistake. ok?
best regards michael
Posted on Oct 03, 2009
SOURCE: how to remove jammed staples in staple gun?
Take out the small bolt that is secured with a nut at the back of the gun (at the end where you feed the staples) -- then drop the inset. Now you have access to the jammed area. Clear out jammed staples and put the stapler back together. Easiest way is to hold the nut and turn the bolt from the other side.
Posted on Jan 07, 2011
Where can I get 8x11.3x2mm staples for an Aldi Workzone Staple Gun
8mm = .315" rounded to 5/16"
11mm = .445" rounded to 7/16"
2mm = .079" rounded to 5/64"
5/16 x 7/16 x 5/64 staples...
Jun 01, 2017 | Staples Tools & Hardware - Others
Bought workzone hand stapler kit but have used all of the flat channel type staples can you help
sorry we do not sell anything here . go to the store you bought it from and ask any clerk .
Oct 28, 2015 | Staples Tools & Hardware - Others
Why doesn't my Arrow fire any staples any more? It's not jammed. The piston doesn't seem to raise high enough to get over the next staple in line. Is it worn out?
Might be could also be that you have the wrong staples in it. Arrow makes about 15 different staple guns. The reason for that is so they can sell you the right for your use staple gun. This also means that certain staples only work for certain guns. Check the model then check arrow web site and find the compatable staples for that gun. Hope this helps
Aug 19, 2014 | Tools & Hardware - Others
Need instructions for Workzone staple gun
insert staples , point away from living things (dogs,cats,humans etc.) and squeeze the lever to discharge staples.
Mar 24, 2013 | Tools & Hardware - Others
Craftsman 68514
The replacement pack for this gun say the staples are compatible with "Craftsman 68514 and 68517; Arrow Brand T50 Staplers T50 and T55; and Stanley/Bostitch TR110 and BT110 staple guns", so I assume they are also backwards compatible. That's just an assumption though.
Mar 22, 2013 | Arrow Tools & Hardware - Others
Stockists for workzone staples
where can i locate staples for workzone sttapler
size are 8x11.3x1,2
Jan 01, 2012 | Radio Communications
Can't find staples for the Swingline powergun 1000. Suggestions?
use arrow #606 in the gray box. the back of the box lists compatible staple guns.
Aug 31, 2010 | Staples Swingline® 36115 Staple Guns Tools...
Won't shoot staples. Proper loading instructions please.
Make sure the staples you are using are compatable with your gun they should be type 53 or JT21 staples and they are not longer tham the gun is capable of taking I think the maximum capacity for this gun is 5/16 or 8mm.
Turn the gun upside down and pull back the carriage, the staples are laid in the empty chamber in the gun itself not on the carriage points facing in the direction they fire ie points facing you .
Push back the carriage this should slide over the strip of staples until the carriage clicks shut.
You should now be ready to fire, try and keep pressure down on the gun as the recoil can make the gun bounce and you will leave the staples proud.
Hope this helps.
Sep 02, 2009 | Omega Easyshot Staple Gun & Desktop...
Tools & Hardware - Others Logo
37 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
