Question about Epson Stylus Pro 9600 InkJet Printer
Epson 9600 magenta won't print - have new cap assembly installed
Can't get the magenta (ultrachrome ink) to print at all. Cleaned many, many, many times. Flooded the cap assembly - didn't work. Ink is being pumped through the line. Magenta Ink doesn't seem to come out of the print head at all - all other colors test print great.. How can you tell if your print head is bad?
  • lisak407 Apr 23, 2009
    Thanks for the imput. I did try several mag. cartridges and the ink seems to be pulling but not dropping from the print head. Do you know much about how a print head works? I know there is a damper part (i call is a bladder) before it goes to the printhead. It doesn't seem to be clogged but was wondering if there is a electronic with this damper of just a storage device. Those can be replaced very cheaply. Printhead seems to run 350.00-500.00.
    suggestions?
  • 3,866 Answers
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Posted on Apr 23, 2009
Ink streaks on print epson 9600
The problem solved by "switching off" the Digital Signature.
Since the driver from Epson was safe it was allright and safe to do that...
Apr 02, 2013 | Epson Stylus Pro 9600 InkJet Printer
Epson Sx415 New Cartridge,empty already?!?!
1. New original ink tank will dried for several times of head cleaning procedure.
. ....ran a nozzle check and cleaned print heads because it wasn't printing any ink on the paper.... ???
Nothing at all? If yes, problem is in the printer main board. Lost electricity to the head.
Jan 13, 2013 | Epson Office Equipment & Supplies
Even with new inks, magenta and yellow won't print
The ink you replaced costs as much as a new printer that comes with ink. Get a new one.
Aug 27, 2012 | Epson Stylus 2200 InkJet Photo Printer
Maintenance required 0040 code
Hello.
Your error code means the Pump/Cap/Cleaning assembly has reached the end of its life and will soon fail. This is a major replacement part and it is typically more cost effective to replace your printer rather than repair.
You can continue to print, but soon you will experience leaking ink, damaged hardware and poor prints.
Hope this helps.
Nov 14, 2009 | Epson Stylus Pro 9600 InkJet Printer
Epson 9600 print head missing numerous nozzels during test print procedure. Tried power clean several times. Do you have a remedy?
You willl probably need to clean the Pump Cap Assy.
You will need a strong flashlight/clip-on lamp to see what you are doing up in the area you are cleaning.
Move the print head to the left side of 9600. (If you need help with this let me know.)
Use a foam tipped swab slightly dampened with warm water to GENTLY wipe around the seal area of the Pump Cap Assy.
DO NOT USE A COTTON TIPPED SWAB !!!
Dip, Blot, & Wipe. Clean the Foam Swab often to wash off the residue it will pick up. Remenber to keep the swab slightly moist - not dripping wet.
If this does't help, it generally means that the Print Head is also very clogged with gummy/dried ink.
The Print Head cannot be cleaned without removing the Right Side Cover & then removing the Pump Cap Assy. This removing and cleaning is about a 1.5hr-2hr job for an experienced tech. Anyone with moderate mechanical skills can do it though.
Pump Cap Assy cleaning is usually done BEFORE replacing the Print Head.
If the Print Head cleaning doesn't work then a New Print Head is in order.
Hope this helps ! Good Luck !
Jun 10, 2009 | Epson Stylus Pro 9600 InkJet Printer
No yellow
buy a new one srry man if u eney thing els tell me at alexswierenga@yahoo.com
May 29, 2009 | Epson Stylus Pro 7600S InkJet Printer
I have an Epson 4000 which has a clogged nozzle
I have an Epson 4000 which I started using new in Sept 2004 and my magenta is clogged too. I've gone through 2 maintenance tanks trying to clear it, (and LOTS of ink), but the magenta is still blocked. I even tried this: http://www.youtube.com/watch?v=3NR8g4qUAJc trick but it didn't seem to work. I hope you have better luck.
Feb 23, 2009 | Epson Stylus Pro 4000-PS InkJet Printer
Unclog yellow
Same problem yellow almost completely clogged, any tried a power clean from the printer control panel?
Jul 12, 2008 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 horizontal banding problem
the banding is a result of clogged head. I had the same problem and fixed it with many cleanings.
Epson stylus pro 9600 driver
on site tech service for epson 9600?
Dec 31, 2007 | Epson Stylus Pro 9600 InkJet Printer
Epson Stylus Pro 9600 InkJet Printer Logo
693 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
