Question about Amcor PLM-14000E Portable Air Conditioner
"Starts running and after about ten minutes trips the circuit breaker anf nthe shuts off. This is the PLM14000EH.
HotSprings hot tub trips circuit breaker
Could be a wrong breaker for that circuit or a problem with the tub.
• first see if there are other lines on that circuit- should be only the tub.
• Check the specs for the tub that the circuit is the correct amperage.
• if clear on those items, there is a problem with the unit and that's another question.
Aug 16, 2014 | Electrical Supplies
Dryer blows circuit breaker after running 10-20 minutes.
indicates problem motor , overheating in the wiring or excessive loads in the drier
Jun 07, 2017 | Kenmore Dryers
Overheat protection tripping
Aug 13, 2012 | Amcor PLM-14000E Portable Air Conditioner
We have a 1999 "Thermal
DO NOT install a 20 amp breaker, you can cause a fire. The breaker is rated for the WIRES, and unless you change out the wires, the 15 amp wires will overheat and can cause a fire.
Typically, A/C units need dedicated power, with nothing else on that circuit.
One step that you may try is a new 15 amp breaker. Once a breaker starts tripping, is starts tripping earlier....
You may wind up running a new circuit for the A/C, if you do, size it for the A/C.
Jul 18, 2011 | Heating & Cooling
SL24J30 KILLING CIRCUIT BREAKER
Here is a tip that I wrote that will help you ti find out why the circuitbreaker is tripping.
Circuit Breaker Keeps Tripping
heatman101
Jun 24, 2010 | Friedrich SL24J30 Air Conditioner
GE Spacemaker Microwave JVM1441 BH04 tripping circuit breaker
your power transformer for the magnetron could have a shorted primary power winding,the door safety interlock switch could be mis-adjusted,this normally blows the internal unit fuse,a shorted high voltage capacitor,or diode,a bare wire inside the unit,more than the microwave on that circuit or a weak circuit breaker in the house power panel
Jun 19, 2010 | GE JVM1441 Microwave Oven
Refrigerator trips circuit breaker
try standing it upside down for a day it will work
May 28, 2010 | Amana ATB2135HR Top Freezer Refrigerator
The power cuts off after 2 minutes of cooking. The microwave doesnt turn back on for ten minutes.
There is an automatic circuit breaker that it tripping. One of two options
1) Something in your oven is either malfunctioning (difficult to find and replace). It is likely better to just replace than pay to have it fixed.
2) The house circuit that you are using is not providing enough power to the microwave. Check if something else is connected on the same circuit. A microwave runs poorly when not getting the full 115 volts that it was designed for and may fall into a safe mode and shut down for a while.
Newer houses should have the microwave on a dedicated circuit and should not have this problem - I say should not because electricians can make mistakes too.
You can try to trip your microwave circuit and see if anything else stops working. If so, that is likely why your microwave is falling into a safe mode - it is not getting enough juice.
If you have an older home (pre 1995), try to find what else is on your microwave circuit by tripping the breaker as listed above, then not using the other appliance when using the microwave.
Good luck.
Mar 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My electric furnace keeps tripping the breaker , it will run for about five or ten minutes then trips.
If you dont have an ampmeter it is hard to tell whats going on. First check the breaker and see if it is getting hot. If so turn off power get a screwdriver and check to see if wire are tight on the breaker. Loose wires cause breakers to trip. If the unit has ran before and it has not tripped the breaker and it hss just now atarted replace breaker but do not put a larger one in. Check the size of your heat strip in Kw or what they call for on the size of the breaker. 10 kw no larger that 60 5kw no larger than 30. 15 kw has a 60 amp and a 30 amo circuit. Let me know whats going on.Rus
Dec 07, 2009 | Refrigerators
Amcor PLM-14000E Portable Air Conditioner Logo
22 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
