Question about Teleflex 11 The Rack Back Mount Rack Steering Package
How can I unlock inner cable from hub from a teleflex boat steering system
    Problem Solver:
  • 6 Answers
Idiot!!!!!
Posted on Oct 12, 2013
I'm looking for the torque wrench settings for the power steering rack mounting nuts for a au1998 xr6
They all still need to be checked with a torque wrench periodically. ... My BA XR6 has developed a clicking/knocking usually while turning while ... There is a torque setting for the nuts, it cast into the sub member near the mounts. ... Maybe thats all the mid-life b series steering click is, the bolts coming loose.
[PDF]BA Torque Specs
members.optusnet.com.au/~matt_l/tridocss_files/ba_torque_specs.pdf
Torque(Nm) Torque(FtLb) ... Cam chain tensioner blade to cylinder head nut ... Front and rear upper mounting bolts .... Front Suspension/Steering .... NOTE: In stages A and B a torque wrench of known and accurate calibration must be used.
Teleflex Mechanical Steering Tech Reference & FAQ
www.jamestowndistributors.com > Home > How Tos
I'm replacing a Teleflex rack & pinion cable in a 1985 boat. ... If you have installed a non-tilt "Back Mount Rack Helm," order Friction Kit part number ... Morse Command 200 Rack: use Teleflex Back Mount Rack for power-assisted or NFB Rack for ...torque feedback from the engine (which can make the steering wheel turn on ...
Dec 28, 2015 | Cars & Trucks
Steering gear
Hi Alfred.
Your answer will depend on the fishing boat.
For really small boats, with an outboard motor on the back, the motor will be on a pivot joint, and have a handle in front. You point the running motor side to side to steer the boat.
Larger boats with outboards will have a steering wheel with a mechanical linkage to an outboard motor or motors that will pivot them side to side to steer.
Larger fishing boats, especially commercial boats, will have an inboard engine and prop shaft, a fixed external propellor or propellors, and a rudder that is connected with a mechanical linkage to the steering wheel or ships-wheel to move the rudder side to side and steer the boat by deflecting how the water flows by when under way.
Hoping this helps.
D
Dec 16, 2015 | Boating
Where can I get a repair manual for a Luhrs 1974 32' Flybridge?
Boats this size are a collection of components from various manufactures, each with their own repair and parts manuals. i.e. Mercruiser inboards, Teleflex steering components, etc.
May 07, 2014 | Boating
Boat steering cable
This steering is swedged at the factory and can not be separated. If you will remove one end. (Motor end works best) And slide a cut bicycle innertube down over the end and hose clamp it to the plastic covering, you can force some light oil into the steering.
If this doesn't work in a day or two, you need a new steering cable.
Jul 18, 2012 | Light Boating
Procedure for replacing rear whl brgs on a 2003 escape awd
4-Wheel Drive
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    • Negative battery cable
    • Rear wheel
    • Rear brake shoes
    • Rear halfshaft nut and loosen the halfshaft from the hub
    • Wheel hub and place it in a vise
    • Inner wheel bearing race from the hub
    • Antilock Brake System (ABS) sensor bracket and move the sensor aside, if equipped
    • Parking brake cable from the steering knuckle
    • Brake line from the wheel cylinder and support the knuckle
    • Lower shock absorber nut
    • Lower ball joint by holding the ball joint stud
    • Upper ball joint
    • Coil spring while noting the location of the insulator
    • Steering knuckle cam
    • Steering knuckle
    • Snapring and press out the outer wheel bearing race from the knuckle
      Rear hub and bearing
      Click to Enlarge
To install:
  1. Install or connect the following:
    • New wheel bearing into the steering knuckle
    • Snapring to the knuckle
    • Wheel hub
    • Steering knuckle cam and hand tighten the bolt
    • Coil spring
    • Shock absorber lower nut. Torque the nut to 85 ft. lbs. (115 Nm) for 2002-04 models; 129 ft. lbs. (175 Nm).
    • Upper ball joint. Torque the nut to 76 ft. lbs. (103 Nm).
    • Lower ball joint. Torque the nut to 76 ft. lbs. (103 Nm). Align the steering knuckle cam and torque the bolt to 85 ft. lbs. (115 Nm).
    • Brake line to the wheel cylinder. Torque the brake line bracket bolt to 15 ft. lbs. (20 Nm) and the brake line fastener to 11 ft. lbs. (15 Nm).
    • Parking brake cable to the backing plate. Torque the bolt to 16 ft. lbs. (22 Nm).
    • ABS sensor bracket. Torque the bolt to 80 inch lbs. (9 Nm), if equipped
    • Halfshaft nut. Torque the nut to 214 ft. lbs. (290 Nm).
    • Brake shoes
    • Rear wheel
  2. Fill and bleed the brake system.
  3. Check and adjust the wheel alignment as needed.
2-Wheel Drive
    • Rear wheel
    • Rear brake drum
    • Wheel hub nut
    • Wheel hub
    • Snapring
    • Wheel bearing outer race from the knuckle
      Rear hub removal
      Inner wheel bearing removal-rear hub/bearing
      Rear wheel bearing removal-2wd
      Rear wheel bearing removal-4wd
To install:
  • Wheel bearing in to the knuckle
  • Snapring
  • Wheel hub into the wheel bearing
  • Wheel hub nut. Torque the nut to 214 ft. lbs. (290 Nm).
  • Brake drum
  • Rear wheel
    Rear wheel bearing installation
    hope this helps if so send testimonial comment or even any other questions you have
Jan 16, 2011 | Ford Escape Cars & Trucks
1973 NAUTA-LINE, 34ft....have twin helms with cable back to a TELEFLEX Power "T" power assist. Cables moves freely when disconnected from power assist unit, tiller moves freely when disconnected. Have...
This site used to have a Boat section which would have more interested parties than Cars and Parts do. I would relist to proper area. The Marine parts area is one I happened to get involved with through rebuilding my salvaged Bayliner. You need someone to be a Research Librarian to find your parts. Try using the Brand and if you can find it, then go to specifics.
I would look at the tiny ads in Boating magazines and Boating Trader type papers. When looking for my Volvo outdrive components, I discovered that speculators buy pallets of old stock from Marinas going out of business. They then list some parts on Amazon or Ebay. Unfortunately some throw away cheaper parts that you may need but are not worth it to them to list.
I live in Michigan and had found my parts in Florida and California as well as Kentucky and Tennessee. You will find that some brands are not popular in some states and the makers never had a Dealership in certain states.
I worst situation comes up, there are Boat junk yards similar to car junk yards.
Aug 31, 2017 | Ford F-150 Cars & Trucks
Stearing on my 4yo 60hp mercury outboard will not budge
if you have "rotary" or "rack and pinion" steering. what your dealing with is rust. 2 things you can do to test the steering system. (1) tilt engine all the way down using the trim an tilt system. On the engine, you will see a steering rod that is parallel to the transom. One side of the rod is connected to the engine(ignore that connection), the other side curves down and connects to the steering cable. Disconnect steering rod from cable by unscrewing the nut counter clockwise. Once you disconnect the steering rod from cable. Push steering rod forward towards bow swinging it out of the way. Engine is now free from boat steering system. “Testing the engine steering tube“ all you have to do is manually turn the engine port and starboard using your hands. If your able to turn engine, the problem is the boat steering system. which you can fix. If you can' turn the engine then the job will require the engine to be removed from boat and transom bracket rebuilt. Take it to a repair shop.(2) with the engine still disconnected from the boat steering system. Get in the boat and turn the steering wheel. A good steering system you should be able to turn the wheel with just a finger. If wheel does not turn, you have one of two problems. Bad cable or bad steering helm. I always tell my customer to change both as a kit as a safety issue. if you are trying to save money. pull cable from helm, turn wheel if it turns easy replace cable (keep cable don't throw it away you have to get it matched) if wheel still stuck replace helm.
Oct 31, 2009 | Boating
How do i replace front wheel bearings on a 1991 subaru lyale 4wd wagon ?
  1. Remove the steering knuckle assembly from the vehicle, and secure in a soft-jawed vise.
  2. Drive out the hub from the steering knuckle. If the inner bearing race remains in the hub, press it out.
    NOTE Be careful not to scratch the polished area of the hub.
  3. Remove the rotor shield.
  4. Remove the inner and outer seals.
  5. Remove the snapring from the steering knuckle.
  6. Press the inner bearing race to remove the outer bearing.
  7. If equipped with ABS, remove the tone ring.
  8. Press the wheel lugs from the hub.
    NOTE To prevent deforming the hub, do not hammer the lugs out.
To install:
  1. Press new wheel lugs into the hub.
  2. If equipped, clean all foreign material from the hub and tone ring. Install the tone ring.
  3. Clean the inside of the steering knuckle.
  4. Remove the plastic lock from the inner race and press a new, greased bearing into the hub by pressing the outer race.
  5. Install the snapring into its groove.
  6. Press a new outer oil seal until it contacts the bottom of the housing.
  7. Press a new inner oil seal until it contacts the circlip.
  8. Apply grease to the oil seal lips.
  9. Install the rotor shield and tighten the bolts to 10 ft. lbs. (14 Nm).
  10. Attach the hub to the steering knuckle.
  11. Press a new bearing into the hub by driving the inner race.
  12. Install the steering knuckle.
Front axle and bearing assembly—Sedan, Coupe, Loyale, XT, Wagon and Brat
Driving out the inner bearing assembly
Pressing the bearing in
Oct 19, 2009 | 1991 Subaru Loyale
Frozen steering on mariner 75
It sounds like your steering cable is rusted in the eng steering bracket or your cable has gone south (Rust) try some heat to free it up and if that dont work its time for a new cable
Oct 04, 2008 | Simrad 20187423 Teleflex Adapt Lf 3000...
Teleflex 11 The Rack Back Mount Rack Steering Package Logo
54 people viewed this question
Top Teleflex Marine Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Teleflex Marine Vehicle Part and Accessory Expert? Answer questions, earn points and help others
