My carrier weathermaker sx gas furnace is about 20 years old. Something's going on with the fan senser. The furnace kicks on. Normally after it heats up, the fan kicks on and runs until thermostat temperature is reached. This is what is going on to a point. The fan kicks on, but after only a few minutes it turns off. Soon the furnace turns off, triggered by the heat and lack of circulation. I can turn the fan from auto to on, and it raises the temperature. It is the only way I can keep the temperature correct in the house. I've paid repair people twice to look at it. I've tried to explain what is going on, but they keep telling me nothing's wrong. But there is. Help!
  • 148 Answers
Capacitor of blower motor need to be check of it ok you need a new motor
Posted on Nov 12, 2013
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 53 Answers
Pls send me snap of your furnace controller , i can help you
Posted on Oct 15, 2013
3 Suggested Answers
wbwill
  • 68 Answers
SOURCE: Carrier Weathermaker SX model 58SX060-CC Blower runs all the time
Remove all power from the furnace, it is likely the brain in the furnace is need of being reset, from the battery replacement, why did you change the battery, was there an indicator telling you to change it?
Many times just removing all the power to the furnace will do the trick with a reset, if not let me know and we will go from there, but it sounds like the main brain is confused or bad, more likely confused, so try the power removed first.
Than let me know wbwill@sbcglobal.net
Posted on Nov 22, 2008
SOURCE: Carrier weathermaker sx 58 furnace
I have serviced these furnaces for 20 years and I can tell you most of these models did not have diagnostic lite on them. (although some did, especially if the control board has been replaced) The problem is most likely a bad 3 wire pilot. This will cause exactly what you describe. 2 things to consider though. 1, If you were to replace the pilot don't get a cheaper knockoff. In my experience these do not last long at all. Get the right one from a carrier dealer. It will cost more but be much more reliable. 2 What is the condition of the secondary heat exchanger? Most if not all of the sx series had issues with the secondary heat exchangers rotting out and leaking. If the furnace is out of warranty you would be much better replacing the furnace as the cost of replacing the secondary heat exchanger will probably be almost the same as a new furnace. ( those babies are EXPENSIVE!)
Posted on May 01, 2010
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Carrier weathermaker sx (model 58sx040-cc power vent motor and gas velve cylanoid are kicking in and out, do you know what i can do to fix this problem ??
I believe this is the furnace with a spark to light the pilot light. If so the best advice I can give is to replace the whole pilot assembly. There is a very old style flame sensor in there that is not serviceable. This has driven many a technician around the bend.
**NOTE: It is a real pain to get out, and back in. You need to take off the fire box cover and the panel underneath it to get it out. You also need to take the pilot tube off the gas valve. This may be something that you want to call a service tech for. It could be a little tricky and because you are dealing with gas, you want to make sure that it is put together correctly and safely.
Nov 08, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
I have a new home 1 yr and when the furnace kicks in, I am assuming the fan it makes a noise but as soon as the heat starts the noise is gone, could this be the furnace blower
Check by turning the unit off and turn the fan to on. Do you hear the noise now? The noise your hearing could be coming from your combustion fan assembly instead. Newer furnaces have a in-shot burner and are nosier than the old style of heater.
Jan 04, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Extreme heating bills
easy way to fine the high usage is to turn everything off and watch your meter and have someone start turning thing back on and watch for the most usage of power
Jan 25, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
When burners come on makes a swiching noise and then goes out and
The carrier sx series went through a number of control systems over the years. can you find the full model, and series numbers? They are located behind the door on the left side. (i.e. 58 sxc080-100 series100)
Dec 30, 2008 | Heating & Cooling
Oct 22, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dec 17, 2007 | Heating & Cooling
Heating & Cooling Logo
268 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
