Question about iRiver H320 MP3 Player
H320 keeps switching off. Battery is fully charged.
My H320 keeps switching off (usually if I am scrolling through songs). Sometimes, it just cuts out for no reason. Called the retailer and they just said the battery needs replacing. However, if I switch the player back on, it can play for another 30 mins, then do the same again. It doesn't appear to be the battery. Retailer not going to do more. What do you think it is please? Firmware has been updated and still having the problem. Thanks!
  • superred Jan 27, 2008
    I am having the same problems with my iRiver H340 player. Sometimes it just switches off for no reason and says "Low Battery" even though the battery is fully charged. Then an hour later it will work fine for a while, before switching off again. And sometimes it works just fine, for 6-8 hours before the battery really does need recharging. Does a battery replacement fix this problem? I'm wondering if it is specifically a battery issue, or if it's a connection/internal wiring problem. Please let me know at superredmachine@yahoo.com.
    Thank you.
    Problem Solver:
  • 14 Answers
Re chargables are not forever, and it could be the culprit here. Also if it has a power save more it may decide you are not using the player and not sensing your browsing. Maximum life span of a normal use rechargable is 2 years or the hours marked on the packaging it came in, like 3000. Do the math. High energy drain devices also wear out their batteries faster if the backlight and keys are in constant use, turn the brightness down and run off a list of your tunes from you computer program and look at that.
Posted on Oct 16, 2007
TAZZ SOMETIMES DOES NOT WANT START
Sounds like you need to get your battery fully charged on a battery charger and then tested at a garage. Driving will put some charge in your battery but not fully charge it. After your battery has been flat it is less likely to fully recharge and the alternator is designed to keep the battery topped up rather than fully charge it. Jon
Dec 09, 2013 | Toyota Cars & Trucks
H300 battery after being charged lasts about 15 minutes tops
buy a battery kit from the site underneath your question and install it yourself.I did this-cost $29 now my iriver h320 has anew life and is better than ever!
Mar 29, 2009 | iRiver H320 MP3 Player
Iriver H320 GIVES ME PROBLEMS
can i suggest that you download rockbox software (it does everything iriver firmware but is not a strain on the battery life) www.rockbox.org for h320.....................and or you can buy a new battery, here an ebay link http://cgi.ebay.com/NEW-High-Capacity-1700MAH-Battery-iRiver-H320-H110-FSH_W0QQitemZ390057094924QQihZ026QQcategoryZ20336QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
start over as new
Sep 17, 2008 | iRiver H320 MP3 Player
Iriver h320 over heating
well since you copied your files..........now copy the iriver software (hidden too) and paste to a temp file (folder) on pc...fortmat the 320 now place the software back onto it from the temp file........and put 2 or 3 songs unto it also (to make sure it was done correct)..press play if all is well...include all your files back on to it.......a little bit late but feel free to rate the help
Aug 19, 2008 | iRiver H320 MP3 Player
IRiver H320 will not charge
did you turn off your USB so that the AC adapter can get through to recharge your battery.
Apr 02, 2008 | iRiver H320 MP3 Player
Iriver H320 battery problem?
I had a similar problem. It seemed to just die with a light blue backlight, not the usual one. It would not turn off or on. I thought it was gone for good. However, I re-installed the driver (in control panel, system, hardware, device manager) I had to do this a number of times, with the h320 attached by usb and not attached. After a number of attempts, I got a message 'disconnect iriver h320' I then let the 320 completely lose its battery power (over a day or so) then attached the charger and got the charging message. It works fine now. Hope this helps
Mar 22, 2008 | iRiver H320 MP3 Player
Cannot Load Songs onto iRiver H320 Player
1. if your player is not working properly just reset it by using paper clip on the hole and press down the player will turn off then try again
Oct 17, 2007 | iRiver H320 MP3 Player
Iriver h320 battery problems
your battery is broken you must buy new battery (very good battery is 2200 mAh because battery install in your iriver is 1350 mAh)
Oct 01, 2007 | iRiver H320 MP3 Player
IRiver H320 is completely dead
Hi, you can get a step by step video tutorial on how to change the battery here.. http://www.videojug.com/film/how-to-replace-the-battery-in-your-iriver-h320-or-h340 all the best John
Mar 04, 2007 | iRiver H320 MP3 Player
IRiver H320 won't turn on
Hi Andy- I have the same problem. Spoke to IRvier America & was told that they have no repair service for anything out of warranty- so we're on our own. Was also told that there are third party repair companies that can be found online. Myabe between the 2 of us we can find a solution. Care to keep in touch? Terese
Dec 27, 2006 | iRiver H320 MP3 Player
iRiver H320 MP3 Player Logo
61 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Peter Dragonetti
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
