Question about Lightnin Mixer
Manual for lightnin series 10 - Lightnin Mixer
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/fp-12dc.pdf Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
How do I replace the governor on a kitchenaid mixer KSM150PSBK
With two screwdrivers, you can carefully pry off the governor assembly. Be careful no to bend, remove the governor drive stud and lay it away so it will not be lost.
See page 6 of the service manual Fig. 22, and page 11 will show you how to reassemble the governor.
Service Manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Thank you,
Colleen
MendingShed.com
800-339-9297
Jan 06, 2013 | KitchenAid Kitchen Aid KSM150PSBK -...
Where can I get a manual for my K5M150PS 5Qt Artisan mixer. Do not have a manual. I purchased this mixer last Jan and just opened the box. Could I find out what speeds 2,4,6,8, and 10 are until I can...
Hi and welcome to FixYa, I am Kelly. You can download the 60 page manual here:
http://www.ambientedirect.com/skin/frontend/ambiente/default/media/2184.pdf
The pdf file is copy protected so I can not copy and paste the speed control page. You will have to download the manual. Rt click, save as.....
The speed control guide is on the printed page 15 (green page number bottom of the page)
The guide states you also can select speeds 3, 5, 7, and 9 by moving the selector in between 2, 4, 6, 8, and 10
Thanks for choosing FixYa,
Kelly
Dec 15, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid KP26M1X never used. First time turned on and it ran for 10 seconds then shut off. Turned it off and restarted then it ran for 10 seconds then shut off again. Keeps doing this. Would this be...
Hello CANADA43. From the symptoms you describe, I would say that your there is something awry with your mixer’s internal speed control assembly. You said the mixer had never been used and the spotty running started the very first time it was used. Is it still under warranty (have you owned it for less than one year)? If so I’d contact KA immediately and tell them about your problem with the stir speed not working correctly. The KA website is at: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Contact Us> and the toll free phone number is listed to speak with someone. You can also look under the Warranty & Service Plans to see what KA will do for you. I've extracted parts of it here:
Hassle-Free Replacement Warranty
We’re so confident the quality of our products meets the exacting standards of KitchenAid that, if your mixer should fail within the first year of ownership, KitchenAid will arrange to deliver an identical or comparable replacement to your door free of charge and arrange to have your “failed” mixer returned to us. Your replacement unit will also be covered by our one year full warranty. Please follow these instructions to receive this quality service.
If you reside in the United States and your KitchenAid® mixer should fail within the first year of ownership, simply call our toll-free Customer Satisfaction Center at 1-800-541-6390, 8 a.m. to 8 p.m., Monday through Friday, 10 a.m. to 5 p.m., Saturday, Eastern Time. Give the consultant your complete shipping address. (No P.O. Box Numbers, please.) When you receive your replacement mixer, use the carton and packing materials to pack-up your “failed” mixer. In the carton, include your name and address on a sheet of paper along with a copy of the proof of purchase (register receipt, credit card charge slip, etc.).
If your mixer is no longer under warranty, then you can still replace the control assembly by yourself. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> enter the visitor type “Consumer” and then Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.)
For a series -4 mixer, turn to pgs. 4 & 4, titled Case, Gearing And Planetary Unit that shows an exploded view for the disassembly and reassembly of your mixer, along with all the parts. Locate Illus. No. 8, Control Assembly (incl. Knob). (For a series -5 mixer, turn to Pgs 4 & 5, and locate Illus. No. 19, Control Assembly). You’ll want either the black or grey knob contol assembly. The part numbers are the same for both series mixers, so you just need to choose the right color.
Here are five potential online vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). Prices can vary widely between vendors, so do some comparison shopping.
Finally, here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer. The mixers displayed in the links are different KA models, but the principles are the same.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer, should you decide to go that route.
If you feel this repair is beyond your capability, then I would seek out a local small appliance repair shop in your area. KA Customer Care can give you names of local KA authorized repair shops in your area, but you can also do an online search to supplement what KA may provide you. Call to explain your circumstances and find out their hourly rate and get an estimate of what they think it would cost to repair your mixer. Also, always obtain three or more estimates – do some comparison shopping. Good luck, I hope this helps. Howard, Burke, VA
If this solution was helpful, please rate it, thanks! – hslincoln
Jul 06, 2010 | KitchenAid Food Mixers
HOW DO YOU REMOVE THE PLANETARY ON A KITCHENAID MIXER MODEL KP26M1XGR3
Hi DAVE, Merry Christmas & Happy New Year! The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case: KP26M1, and select one of the first two files listed under Parts List (47) (The first file, KP26M1XAZ4.pdf (304.18 KB), is for a -4 series model and the second file, KP26M1XAZ5.pdf (724.41 KB) is for a -5 series with slightly different insides, so make sure you have the correct Parts List manual.) (For the purpose of this solution I will use the 5 Series Parts manual. Substitute accordingly if you have a 4 Series model.)
Turn to pages 4 & 5, titled “Case, Gearing and Planetary Unit”, which provides and exploded view for the disassembly and reassembly of your mixer, along with all the parts.
(1) Remove your KA Decorative Trim Band (Illus No. 3) by removing one (1) screw (Illus No. 22).
(2) Remove the four (4) head cover screws (Illus No 14) and lift of the mixer head cover (Gearcase Motor Housing top, Illus No. 1).
(3) Next, remove the two (2) screws (Illus. No. 14) securing your (Speed) Control Assembly (Ilus. No. 19) so you can move the Control Assembly out of the way. This will allow you better access to the Transmission Housing (Illus. No. 4).
(4) Remove the four (4) Transmission Housing screws (Illus. No. 14). Carefully lift the Transmission Housing off the base. The Transmission Cover Gasket (Illus. No. 6) may come off with the Hosuing or remain on the base. (Recommend reordering a new gasket if damaged)
(5) Remove all grease from inside the transmission cover and off all your gears. (This is the messy/fun part. While cleaning away the current grease, be sure to be keep and eye out for metal ‘filings’ that may be suspended in the grease.
(6) Remove the Worm Gear drive assembly (Illus. Nos. 16, 17, and 18) and set aside.
(7) Remove Retaining Clip (Illus. No. 7) from the Planetary shaft.
(8) Remove (lift up) the Bevel Gear (Illus. No. 8) from the Planetary shaft. This may require a little friendly persuasion, but it should eventually slide off the shaft exposing the Retaining Pin (Illus. No. 9).
(9) Remove the Retaining Pin. It should come out easily in either direction.
(10)You can remove the Worm Gear Follower (Illus. No. 10) but once the retaining pin is removed, you should be able to push the Planetary Assembly (Illus. No. 28) down through the Lower Center Bearing (Illus. No. 12). A few taps with a soft faced mallet may be required.
You now have access to the Planetary gear and Agitator Shaft Assembly (Illus. No. 34). Apply the same techniques to remove/replace any components from the Agitator shaft.
Assemble in reverse order above.
Continued in "Comments" - hslincoln
Dec 28, 2009 | KitchenAid K45SS Classic Stand Mixer
Need user manual for Kitchenaid Artisan Series Mixer Model RRK150 OB serial no. WS 1208816
Looking on the KitchenAid site, your model did not look up, buyt I put miune in and this is the link to download the manuals.
Nov 25, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
Speed control
You need to either clean the contacts on the control board, or replace it. Parts are available online or use Google to look up a repair shop.
Oct 08, 2008 | KitchenAid KSM50PR Professional Series...
KITCHENAID K5-A STANDUP MIXER
Hi. For a manual that supports your K5 mixer, goto www.mendingshed.com look for their Kitchenaid Service Manual. Download these files, they are very thorough and helpful.
If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 20, 2008 | Food Mixers
Lightnin Mixer Logo
138 people viewed this question
Top Lightnin Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Lightnin Food Mixer Expert? Answer questions, earn points and help others
