My school have a Copier Rizo EZ 390U and have the following code P-94 -225
2 Suggested Answers
  • 81 Answers
SOURCE: error code d-17 in rizo rz 200ep
remove master from the drum and reset the master in the master making unit
Posted on May 26, 2010
How do i Factory reset lg rizo 8062 Android
Hold the Power button and the Volume Up button for 20 seconds and follow onscreen prompts.
Feb 24, 2016 | LG Cell Phones
How to fix error code c3102 konika minolta bhizub c754
Sir/Mam, Something is preventing one of the fuser (Hot Part) roller from turning had this happen at a school teacher melted a transparency in the fuser by using a ink jet printer type transparency on this model copier cost the school 2000 dollars. Anyway hope you did not melt a transparency any way check the fuser the hot part for paper that may have wrapped it self around the orange rollers in the Fuser (The hot part of the copier if so you need a new fuser or have a tech come out and see if he can remove it. IF you use any type of tool you can damage the roller and your copies and prints will have marks all over them. Trying to reset the code prior to verifying the motor can turn allows the possibility of burning the motor out and taking the control board that controls it now your talking 3 to 4 thousand dollars
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 11, 2015 | Minolta Office Equipment & Supplies
Rizo ez200E p12-309
Error type P12: System ErrorError point 309: Master-compression-motor encoder sensor count did not change as the master compression motor activated in the compress direction and moved out from the home position.
Try this: Press reset-key. If recovery fails you machine needs service.
Sep 19, 2012 | Riso RZ220 Duplicator
Riso kz30 error code a34
j ai un rizo kz30 aui ne marche il signale une feux orange n 4
Jun 20, 2012 | Office Equipment & Supplies
Riso 390U error code p19 208 .... doesnt seem to be loading the master roll correctly, any suggestions?
Error P19-208
Error type P19: Thermal-pressure motor lock Error point 208: TPH pressure sensor does not go ON within 2 seconds after the thermal-pressure motor activates in the decompressing direction.
Hints: Check mentioned sensor. Check mentioned motor.
Jan 06, 2011 | Riso RZ220 Duplicator
Our school owns a Riso RZ machine and theirs a problem with it; the code is A-06 it also has this -403. Could you please help?
our school owns a Riso EZ 200ep machines and their problem with it ; does not want to pull a master roll and give the code error A-06 and -403. Could you please help me on this.
E-mail me; nambwex007@yahoo.com
Jan 04, 2011 | Riso RZ390 Duplicator
We have a Rizo 220 ui with an error message
The rear cover may be off. Or you may have a bad cover switch.There are two switches at the top of the back coverone on the left and one on the right. Hope this helps.
Jul 14, 2010 | Riso RZ220 Duplicator
Error code d-17 in rizo rz 200ep
Nov 30, 2009 | Riso RZ220 Duplicator
My rizo 220 wich cannot pull a muaster roll
Normally when this model does not feed the master,there is a drive band jump off it place n the master drive unit.To correct this open the front panel of the master making unit and check that all the drive bands is in place.I am working 10 years with Riso and this machines is the best I ever worked with.
Nov 26, 2009 | Riso RZ220 Duplicator
Can't get playhut to ''fold up easily''
Here's a website that has folding instructions for many of their products. I don't see one specifically for High School Musical. But they do have a customer service number listed as well.
Hopefully one of these other products will be similiar to yours.
http://www.playhut.com/folding.html
Apr 08, 2009 | Toys
15 people viewed this question
k24674
jasbo
jasbo
