Question about Dell Dimension 2400 PC Desktop
System doesn't powero u, fans turn on also light on MB
As power plugged in it lights up just informed by former owner it was turned off for a couple mnths.also 1 ram was sold leaving only 128mb.system is dell dimension 2400
  • 2 more comments
  • betsoncliffo Apr 23, 2009
    it is a p4 2.2Ghz about 2 yrs old. He said he used it mostly to download or just upgrade programs and games but he got a new system so he just unplugged it and put it up and sold the ram also he stated that when tried it again a few weeks ago it said sleep mode and the cd tray opened once when tried it again nothing it has XP
    it has windows xp
  • Frank
    Frank May 11, 2010
    how old is the machine?
    what is the problem???
    the latest spec for the machine is Intel P4 2.2Ghz
    128Mb or memories should fire up the machine, nothing else much.
    to run any of the latest software, you need at least 500MB of not max out the memories slots. 4GB in this case.
  • Mark Gough May 11, 2010
    which windows does it have?
    President:
  • 415 Answers
Second time is charm. put at least 512Mb into system if it works then you can either keep it the same or increase memory
Posted on Apr 23, 2009
  • Mark Gough Apr 23, 2009
    first solution wan't posted
    Genius:
  • 1,605 Answers
Best solution is reinstall the OS.
it is difficult to pin point the problem, since there are lots little thing can cause the OS not to function correctly.
if all possible install OS on a new HD and use the old HD as second, you still able to see what is on the second HD if that is what you want. if not reformat and reinstall.
No power when turned on - light green on back - no lights on motherboard - no fans
sunny,try with a other powersupply if possible.
faulty PSU are often the cause.
Jul 13, 2013 | HP Media Center m7250n (ED842AA) PC...
99 grand cherokee blower selector high position not working. Blows only level 1-3. replaced resistor, same problem.
automatic or manual a/c.
I'm going to assume manual but Auto is simular and i can give some direction if you have that as well.
There will be a black with tan wire at the blower resistor. This is the wire the HVAC control head grounds to turn the fan on high speed. With a test light hooked to power unplug the resistor, set the blower speed to high, turn the key to the run position. the test light should turn on when you probe the connector. If it doesn't pull the control head and back probe that same wire at the back of the control head with everything still plugged in. If the test light again does not illuminate the the control head is bad and not providing ground
If the test light does turn on when you probe the blower resistor connector plug the resistor back in. Turn the blower speed to the low setting. With your test light hooked to ground see if there is power on the black with tan wire. if there is turn the HVAC off and ground that wire with a jumper wire. the fan should run at high speed. If it doesn't you have a defective resistor.
Jul 01, 2011 | Jeep Grand Cherokee Cars & Trucks
No power on dell e520 dimension
On the 20 pin connector, short the green wire to any black wire with a paperclip. This will force the power supply to turn on manually if the motherboard is not giving the correct "ON" signal.
Feb 26, 2010 | Dell Dimension E520 PC Desktop
System wont power on unless mb power connector on mb is reset
by mb pwr connector do you mean the swich on the pc case that you press to turn it on or do you mean the large block connector form the power supply ?
If you mean the case switch then you have a faulty one that is sendinga constant signal and locking up the power supply
Jul 17, 2009 | HP Media Center m7060n PC Desktop
Plugged computer back in after move and won't start. green light in mb on.
Actually, there is nothing you can do with the hard drive. If its shorting out the power supply when its pugged in then it is defective. However, most hard drives carry a 3 year warranty from the manufacture. If the drive is younger then 3 years old, I would call the manufacture and get it repaired or replace. Hope this helps . . .
May 16, 2009 | Antec EarthWatts EA380 380-Watt Power...
XION Case and Supply
Try unplugging, then plugging back in the 20/24pin power connector. When you plug in the power connector, make sure the power supply is OFF and the switch in the back is OFF and nothing is plugged into the computer.
Jul 21, 2008 | XION (XON-500F8X2-201) (XON-500F8X2-201)...
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Power to Computer
No power or computer does not turn on. Additional information to why you may be recieving now power from the computer and/or why the computer is not turnning on.
Computer Power Supply Information Helping you with questions you may have about computer power supplies.
Computer Post / Beep codes The computer POST (Power On Self Test) tests the computer, insuring that it meets the necessary system requirements and that all hardware is working .
Installing a pc computer power supply Additional help and information about installing a computer power supply.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq nc6320 Notebook
Dell Dimension 2400 PC Desktop Logo
66 people viewed this question
Alun Cox
