Question about Microsoft Xbox 360 Console
Xbox 360 dvd drive
While playing xbox360 the dvd drive will automayically open while disc is in and game is being played
Rats. Sorry to hear that. You've got a bad DVD drive. If it's under warranty still just get your serial number off the back and call 1-800-4MY-XBOX for repair or replacement.
This is a common problem and some people even choose to replace the DVD drive to reduce the noise while the console is operating.
Here's a link to help identify what drive you have in your console now: http://llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
Here's another user's story of how he solved a similar problem:
http://forums.xbox-scene.com/lofiversion/index.php/t533388.html
Here's a place to buy a replacement drive:
http://www.etech4sale.com/Philips_VAD6037_21_Xbox_360_Replacement/VAD6037_21/partinfo-id-213036.html
And lastly here's a tutorial with more details:
http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Posted on Dec 19, 2007
SOURCE:
Tip
How to resolve Xbox 360 disc read errors. Xbox will not play disc.
Is your xbox360 having trouble reading disc? In this guide I will provide some common solutions to help you fix your disc read issues.
1)Remove any memory devices or usb flash drives.
2)If the disc you are using is excessively scratched, this can cause the xbox to have trouble reading the disc. You can use a damp soft cloth to try and clean the disc. Grab the disc by the edges and using a soft damp cloth lightly wipe the disc from the center going outward.
3)Try removing your Xbox hard drive and then play a disc. Turn off the console. Locate the hard drive on the top of your system(depending on how you have it positioned). Press the release button on the hard drive.
If your system can read disc without the hard drive attached then you may need to replace the drive.
4)Clear the Xbox360 cache. Clearing the cache may remove updates to certain games. Keep this in mind.
Go to System Settings in the My Xbox menu. Select Memory, highlight your storage device and select Clear System Cache. Try and play the disc.
If after the above steps you are still having trouble. You may want to contact Microsoft Xbox live support to have your system serviced. You can find the support information in the link below,
Xbox Support
Regards,
G33k
Visit the links below for other technical articles
Connect your Nintendo Wii to the internet
Connect your Xbox 370 to the internet
Connect your Nintendo DSi to the internet
Connect your PlayStation 3 to the internet
How to access Windows 7 God Mode
Tips to clean and speed up your computer
How to configure a wired/wireless home connection
How to access facebook when it is blocked at school
Extensive list of device driver links for common electronic devices
Keywords
xbox 360 disc read errors, xbox 360 disc read, 360 disc read errors, xbox disc read issues, xbox 360 disc read issue, xbox 360 scratched disc, xbox360 disc not playing, xbox360 cant play disc, xbox360 disc will not play
on May 14, 2011 | Microsoft Xbox 360 Console
In my PES 11 on my xbox 360 , it doesnt start .... when i put in the disc it says region error . SO how do i fix it?????
For the xbox360, the region code on the disc must match the region code in the registry of the dvd-rom drive. The only way around this is to modify your xbox360 so that it plays different regions. This is highly illegal, voids all your warranties and is not at all recommended.
I own a US console (NTSC) and it will only play discs that match with the NTSC code. I can not play a Japanese game (NTSC-J) since NTSC-J is different from NTSC.
Use the following link to figure out which region disc and which region xbox360 you have:
http://support.microsoft.com/kb/906934
Mar 28, 2011 | Konami Pro Evolution Soccer 2011 for Xbox...
My xbox360 wont play some xbox360 games it says put in 360 console well it is a 360 console. What so i do?
you do it is very simple , you can manually fix your problem with the use of repair guide,, it is a complete version to fix your problems caused by xbox.
if you want to download click here.
May 14, 2010 | Microsoft Xbox 360 Console
My Xbox360 will not play Orginal XBox 360 Game Disc
hack cheat repair and unlock xbox 360 yourself in less than 1 hour
http://3redlight.tk
May 04, 2010 | Buck Legendary: The Box for Xbox 360
My disc drive says play dvd at the dashboard when i have a 360 game in it and when i press play it reads, to play disc put it in a xbox 360 console
Hello, Thanks for using FixYa. If you are encountering this problem it means that your xbox360's dvd lens had gone bad. Lenses have life time. Try to get a DVD lens cleaner disk first then use it on your xbox. If this doesn't solve the problem you will then need to have your lens aligned or changed if aligning doesn't fix the issue. I hope this helps. Thanks and good day. - HotRatchet
Feb 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 won't play discs
This is the thing to do. Open the drive and look at the tray. Then go to this site to identify your dvd make http://www.llamma.com/xbox360/Xbox_360_DVD_Drive_Comparison.htm
buy a good working drive or a new one you have to open the drive and change the pcb board (circuit board in the dvd drive) from your drive to the good or new one. Then reinstall everything. The motherboard and pcb board are keyed together so you can't just use the drive with out changing the pcb's. If you need a drive I sell good used ones for $29 and $10 shipping.
Mar 22, 2009 | Microsoft Xbox 360 Console
XBox360 won't play games
Well I just recently purchased an XBOX 360 about a month ago form gamestation(used). It was giving me disc read errors every time iplayed it, but i opened it up and cleaned my TOSHIBA drive and wiped everything down with a cotton bud, and then lubed up all of the parts which needed to be.
and that fixed my problem
please rate
Dec 17, 2008 | Microsoft Xbox 360 Console
Problem with xbox360
Try and open the dvd drive and clean the laser and the cd spinning motor with qtips and rubbing alcohol and see if that works. that is the most probable cause.
alex
Jul 08, 2008 | Microsoft Xbox 360 Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
187 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
