Sc 863-14 on a ricoh 3025 - Office Equipment & Supplies
4 Suggested Answers
  • 86 Answers
SOURCE: Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Posted on Jan 13, 2009
  • 67 Answers
SOURCE: como quitar el error sc
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Posted on May 16, 2011
santosj27
  • 263 Answers
SOURCE: Ricoh Affcios 3025 Functional problem with copier
Hello!
This code is related to a Fusing temperature error.
You probably need to change Hot roller (or fusing roller), Pressure Roller and both thermistors.
You can reset this code but it will pop-up again sooner or later.
The best advise i can give you is to call a technician (if you do not have technical knowledge)
If you still want to reset the code try this:
Press yellow key
Press in the key pad 107
Press red key at least 5 sec.
Press "copy SP"
On the key pas press 5810 and #.
On the touch panel press "execute"
Exit all the way out.
Turn the machine off and on.
Hope this helps you
Posted on Aug 04, 2011
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh aficio 3025
Go get the firmware from the ricoh site. Get the rfu file if you are doing it remotely eg. from your laptop or PC. Just make sure nobody is using the printer while you are doing it.
Jul 16, 2014 | Ricoh Aficio 3025 All-In-One Laser Printer
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
Hello!
Press yellow key
Press "copy SP"
Hope this helps you
Aug 04, 2011 | Ricoh Aficio 3025P Black and White Copier
Como quitar el error sc 819 de una ricoh 3025
• RAM shortage
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
How to replace thermistor on Ricoh Aficio 3025?
Take the fuser covers off. The thermistors (I think there is 2 in this model) have red connectors. One screw for each.Check them first and see if they just have a build up of toner.
****You must have the correct ones for each Ricoh model ****
Feb 01, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio 3025. The first tray is stuck halfway out, it looks like something came loose please help me!
you have to check the paper feed clucth or the tegestration clucth or you have to chean the paper feed roller
Jun 16, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
101 people viewed this question
jasbo
jasbo
