Question about SPL Audio Car Audio & Video
Spl 620 wn put out loud enough does have sound did i wire it wrong?
  • ace_sterling Apr 23, 2009
    much better but amp still i guess not strong enough for a 12" sub but thanks
  • 655 Answers
Hello ace_sterling,
Not knowing what you have the SPL-620 driving or knowing how you have it wired, it's rather difficult to determine if it's wired "wrong".
I show the SPL DK2-620 as being a 2-channel amp with 150 watts output at 4 ohms, or 180 watts at 2 ohms. Even if the power is somewhat overrated, it should provide more than enough power for a set of standard 2-way or 3-way speakers, or component speakers with a separate crossover.
Powering one or more subs is another thing. You would get sound, but the subs would not be very loud. In bridged mode, the amp is only stable to 4 ohms. So if you are trying to power 2 4-ohm subs, the best connection would be 1 sub connected to each channel. If you are powering only 1 sub, then the bridged connection would be best.
Hope this helps. If it does, please rate as "FixYa".
Posted on Apr 23, 2009
Crown xls 1500 power amp
That is a subjective statement. You need to measure the SPL at the speaker and check against the specs and also measure the power from the amp to have the data to check and compare with. That will give you an objective answer. You could have lost part of your hearing, I do not know!
Jan 12, 2014 | Crown Audio Players & Recorders
Ok i was playnig on my celviano ap-620 and then 8 of the keys started to sound rare, very loud, it seems like it lost the key touch sensivility on those keys from the center (C) and 8 keys down i tried...
What has happened is that one signal wire of the matrix that scans the keyboard has opened up. Each key has two contacts. One closes before the other and that is how they measure key velocity to control the loudness for piano sounds for example. When one contact doesn't work, often the sound is set to MAXIMUM key velocity resulting in MAX loudness. The key contacts are scanned digitally in groups of usually 8 or 12 and, for instance, every C key has a single line attached and then every group of 8 or 12 has a second line and then there are two complete sets of these to implement the velocity sensing. Your unit probably has either a break in a cable or possibly a cable connector that has failed or not seated OR worst case, the circuit board under the keys has a crack breaking one wire or circuit trace going to that section of the keys. The problem will require opening the keyboard to repair. If you are not electronically adept, besst to take this to a repair shop.
Aug 14, 2011 | Casio AP-620 AP620 Digital Cabinet Piano...
How do i know my power supply enough to my amplier
An amp is usually wired straight to the battery and power distribution is controlled within it. The battery will deliver a 12v dc current to it. This is the same no matter what vehicle it is installed in. The only case that would be different is if you had a competition sound system.
May 21, 2010 | SPL Dynamics XL2-1600 Car Audio Amplifier
I have a Planet Audio Big Bang 3000 Watt 1 ohm stable amp I was wondering if i could run 2 HIFONICS OLYMPUS 15's they are 2,400 Watts rms each 4,800 max each so would i overload my amp and im putting it in...
that should be fine, but with that much power you might want to invest in earplugs, the SPL or sound pressure level from those speakers could rip your ear drums out of your head, kick them around for awhile, spit on them and shove them back in through your nose.
**Disclaimer, I am not a medical doctor and do not claim to be, I am simply warning you about hearing loss as I have suffered from between 30 - 50% hearing loss because of loud bass. but seriously, if the speakers sound like """" turn it down a little bit. that system should work fine though.
Mar 03, 2010 | Car Audio & Video
OUR TV SOUND DOES NOT COME IN LOUD ENOUGH. IT SAYS ITS ON 100 BUT ITS VERY SOFT
You may have your wires in the wrong place.
Take a look at the colors of the plugs and where they go!!!!!
Feb 17, 2010 | iLO 2600 Television
Location of a 2003 dodge stratus horn, also not loud enough
Horns are usually in front of the radiator and behind the grill--look for two of them, one on each side. Make sure they both sound. If only one works, there is a significant reduction in sound level. There may be road debris stuffed into the horn's throats--poke a hooked stiff wire into the throats and see if anything comes out. Most are sealed and can't be taken apart to clean--replacement is about the only recourse. (look in a wrecking yard for replacements)
Nov 06, 2009 | 2004 Dodge Stratus
Got a new cdibox it work for 5 min then 1 coile pack no spark
check the charging system on the bike, if the lights go dim then they aren't getting enough electric, this can mess up your coils also. Make sure you don't have a damaged wire somewhere or **** up ground first and have the charging system checked before you change the coils, otherwise, you could put new ones in and they can burn right up again. Goodluck
Sep 18, 2009 | 1992 Suzuki GSX-R 750 WN
The fuse blew on my spl 1920watt amp and now the protect light wont go off and it wont do anything
Did you put a new fuse in it? If you didn't then put a new fuse that is rated at what the amp calls for. If you have and the light stays on, then odds are there is a broken wire inside and the amp needs repairing or replacing.
Jul 12, 2009 | SPL Audio Car Audio & Video
1992 Camaro RS 305 V8, Auto
A knock is not good. Does it change when you put the car in gear? Is it loud enough to hear at idle? If it changes in gear then it is a possible cracked flywheel. If not you can idle the car pull the plug wires 1 at a time to see which one changes the sound. This will tell you which cyl has the problem. If it changes pulling the wires then it is an internal engine problem, get ready to spend some money, sorry. Good Luck.
May 07, 2009 | 1992 Chevrolet Camaro
Car Audio & Video Logo
145 people viewed this question
Top SPL Audio Car Audio & Video Experts
xxxxxx xxx
Are you a SPL Audio Car Audio and Video Expert? Answer questions, earn points and help others
