Question about Frigidaire Refrigerators
Frigidaire 5303B compressor running all the time. Changed broken thermostat but did not cure problem
Refrigerator and freezer don't cool
Have you checked or replaced the thermostat? There may also not be enough refrigerant in the lines. This takes an expert to correct.
Jun 24, 2014 | Frigidaire Refrigerators
Frigidaire refrigerator not cooling at times
Click this link below for problemRefrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
---------This will help.Thanks.
Feb 09, 2012 | Frigidaire Refrigerators
My frigidaire is not getting cold. Is there a way to troubleshoot to detemine if it's the compressor gone bad?
Good day,
Here is a basic checklist any qualified tech would use to isolate why a refrigerator won't cool.
Items that will cause a refrigerator not to cool.....
1. Defective thermostat
2. Defective freezer fan motor
3. Defective defrost timer or electronic defrost control.
4. Defective defrost thermostat
5. Defective defrost main heater.
6. Defective condenser fan motor
6. Defective compressor overload protector
7. Defective compressor start relay
8. Defective compressor start/run capacitor (some models only)
9. Defective compressor
10. Restriction in refrigeration sealed system
11. Loss of refrigerant (leak)
12. Excessively dirty condenser
13. Broken wires, bad wire harness connectors, ect.
14. Defective fan motor switch (some models only)
As you can see, there are multiple reasons a refrigerator won't cool, or cool properly.
To zero in on the compressor might take you away from the true non-cooling reason.
However. The compressor might have a defective relay or thermal overload that would prevent it from starting or running. Theses items can be removed from the compressor and taken to any appliance parts houses. Most all would be glad to test them for you.
As well, the compressor could have a bad valve internally that would prevent the compressor from pumping refrigerant, or there could be a restriction in the refrigeration lines preventing the refrigerant from circulating properly, or the windings in the compressor could be burned out or shorted, or lastly, the system could have developed a leak. All of the above compressor related issues, except for the first one could only be checked by a qualified tech.
I would treat the problem as a whole with the compressor being one of the potential issues.
Not to throw a monkey wrench into this but a refrigerator is like a car.
9 out of 10 times the problem and solution are obvious. It's that last 10% that take all the training and experience.
May 19, 2010 | Frigidaire FRS26H5AS Side by Side...
Frigidaire dishwasher won't end cycle - will run on and on for hours. Sometimes it cycles through, usually it just endlessly washes and rinses. I have to CANCEL the cycle, which causes the dishwasher to...
I would say the resettable thermostat has failed. There is a thermostat which senses the water temperature, and when it fails, it causes the dishwasher to run constant. Replace the thermostat underneath the dishwasher and that should cure problem. Part number is 154290204 (I know the number off by heart, that's how often it happens!)
Apr 07, 2010 | Frigidaire 24 in. FDBB540 Built-in...
My frigidaire refrigerator does not cool? what should i buy for it
Good day.
12. Excessively dirty condensor
Thank you for using FixYa
Jan 17, 2010 | Refrigerators
Model ufp19n-lx2 freezer will freezebut motor run all time and hot
its very likley that the thermostat has stoped working in the on posion and the freezer is running 24/7 this wont do the compressor any good at all, change the thermostat asap,
Nov 22, 2009 | Frigidaire Freezers
Frigidaire freezer not working
The thermostat may have shorted out so that it is no longer making contact to put power to the compressor. After drying out the components try bypassing the thermostat and see if it will start or make any sound whatsoever. If it does start and run with the thermostat bypassed replace the thermostat. 4-6 inches of water can also get to the relay on the compressor. Replacing the relay and over load assembly also be a good idea.
Sep 13, 2008 | Frigidaire 13.7 cu. ft. / 388 liter...
Refrigerators Logo
21 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
