Question about Samsung RF4287HA
Have a Samsung RF4287HA, sd by sd on top,middle drawer and freezer drawer. My panel shows OF on Refrig temp and OF on Freezer temp????? Tried unplugging and plugging back in, no help. Dusted back, no help. Any clues as to problem? Thanks
    Scholar:
  • 50 Answers
Do a little internet reasearch on your modle and get the error code listings. If that does not give you what you need the get back to me with that error code definition.
Posted on Oct 12, 2013
SOURCE: Samsung RS21w USA style frige freezer panel problem
If the fridge has been making more noise than usual, like the sound of a plastic fan grating against something then the fan has probably seized up with ice. This will cause the fridge temperature to rise. It is located at the back of the fridge behind a plastic panel at the bottom where the water cooler pipe and bottle are. You need to partially remove this panel just enough to be able to aim a hairdryer down the back of it to defrost the fan.
Posted on Sep 20, 2007
SOURCE: Samsung RS2533SW freezer not cooling problem
mine did the same thing. It was the mother board.
and guess what? they don't sell that motherboard anymore.
I will never buy Samsung again!
Posted on Dec 15, 2007
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
tborn6
  • 700 Answers
SOURCE: flashing temp on freezer door
take and press the two top buttons on the control panel and reset the unit. it appears the the freezer is not operating properly and may by frozen up
Posted on Mar 23, 2009
Error message 1F on refrig
I have the same model and had the same problem after 3 years of use. I checked this and other sites and here's how I fixed it -- easy, peasy.
1. Turn off the power to the refrig. I have a ckt breaker for the refrig so I didn't have to pull it out of its alcove.
2. Open the bottom freezer section, pull up on the front of the middle drawer and pull it out. If you look to the back inside wall of the freezer you'll see 3 vents.
3. Make a platform that will support a common hair dryer to bring it up to the level of the central vent. I used a couple of packs of napkins topped with a towel.
4. Turn on the hair dryer. I left it on for about an hour and heard two chunks of ice fall free at about the 15 and 30 minute points.
5. Remove the hair dryer and platform, put the middle drawer back in the opposite of how you removed it, and close the freezer section.
6. Turn the power back on.
7. Put a towel on the floor to catch the water from the melting ice chunks.
It's been 24 hours and the error has not reappeared.
If this doesn't work, then other comments suggest that it may be the related circuit panel and you'll need to call in for repairs.
I hope that this helps.
Feb 11, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hi Localwonder We have a new Samsung Fr. Door Refrigerator RF4287HA.We got it in Jan. and it worked fine until June when the freezer slowly became warmer and warmer. Then the freezer died...
Check the motor of the refrigerator if the motor is functioning if isn't the motor is damaged or short circuit. Also check the prion if there's a leak if there is search for the place were the leak is coming.
Jul 01, 2011 | Refrigerators
Water is pooling under the veg/fruit drawers..cant tell where its from. Freezer temp is uneffected, temp appears fine, no condensation anywhere on refrig or contents...The first I noticed it was a week...
Your freezer goes through a defrost cycle and drains the melted ice ,somewhere the drain is clogged or iced up .Look for a little hole or hose coming into drain pan underneath and trace up.Might have to take back off.
Feb 17, 2011 | GE J Series 20.6 cu. ft. Top Freezer...
My Kenmore Elite refrig./freezer (2 doors refrig on top, 1 pull out drawer freezer on bottom) is not working correctly. The front panel where the temps are set, light, etc. now has flashing lights that...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 11, 2010 | Kenmore Refrigerators
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 23, 2009 | LG LSC26905TT Side by Side Refrigerator
GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Samsung RF4287HA Logo
98 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
