Question about Moen Plumbing
Loose Kitchen Faucet Spout assembly. Base is secure to sink.
  • 171 Answers
SOURCE: kitchen spout leaks
Hi buffy9,
I'm Harvet the Master Plumber.
Your question is: You have an American Standard two faucet in my kitchen and the base of the spout leaks at the base. How do you remove it and replace the washers?
Are we talking about an American Standard two HANDLE faucet or one of the single handle models?
Thank you,
Harvey your Master Plumber
Posted on Oct 17, 2008
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
SOURCE: water pooling at base of delta waterfall faucet spout
I have the same problem. The part that is needed is found with a simple Google search for "Delta Waterfall RP22934 O-Rings"
Simply Slide the collar up at the base of the spout where it swivels.
Gently open the now exposed split plastic retainer so that the tabs near the bottom are pulled from their holes.
Lift the spout off the base to expose the o-rings.
Replace with the new o-rings and apply o-ring grease.
Re-assemble and enjoy a dry sink area.
Posted on May 23, 2009
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
SOURCE: i have Geyser Kitchen Bar Sink/ Spray Faucet and i...
I have a Geyser GF8 that also leaks at the turning joint. Anyone know how to dissamble one of these faucets?
Posted on Oct 30, 2010
Moen cathedral keeps coming loose and it base moves when you rotate the spout from sink to sink.
tighten the lock down nut under the sink , also,, unscrew the cap (at the base of the spout,, and Lube the O ring ( with either plummer grease if you have it, or if not with vasoline) this should cure your problem
May 04, 2011 | Moen Monticello Single-Handle Kitchen...
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
American Standard Jasmine 3821.834 leaking where spout enters base
How long have you had this? is everythign tight? check underneath the sink to ensure all connections are tight. The spout may have came loose, and it may not be able to be fixed, may need to be replaced.
Mar 29, 2011 | American Standard Jasmine 3821.834.295...
The faucet has a single spout, no manufacturer identity, and the spray attachment can be pulled out. The entire faucet is loose at the base with no apparent means of "snugging it up" either from...
There should be screws that when tightened, will push against the metal flange that rests against the underside of the sink thereby pulling the faucet down and tightening it. Good luck!
Aug 05, 2017 | Moen Muirfield Kitchen Faucet with Side...
How do I tighten a Delta kitchen faucet that has become loose?
If it is faucet body on sink loose under sink there should be screws and a plate or washers holding it sink. Tighten them up.
Some have a bolt or nut in the middle requiring a socket to tighten.
If the spout is loose remove handle and it has a plastic ring on top to tighten spout up.
Feb 13, 2010 | Delta Faucet Plumbing
Repair leak on jasmine faucet - American Standard
you need to replace the 0-rings in side the spout between the base and neck,
Jun 13, 2009 | American Standard Jasmine Mixage Kitchen...
Kitchen faucet
look under your sink there will be a big nut screw it up toward the counter top this will fix your problem also may want to look into getting a prv for your house this will lower your water pressur in your house
Mar 13, 2009 | Kohler Forte entertainment remote valve...
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Water pooling at base of delta waterfall faucet spout
Nov 25, 2008 | Delta Faucet Delta 172-SSWF Waterfall...
Kitchen spout leaks
Hi buffy9,
Thank you,
Oct 16, 2008 | Plumbing
Plumbing Logo
22 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
