Question about Gestetner - DSm618d Digital Imaging System Standard Duplexing Copier
Disabling the fax function
Good afternoon,
Is there a simple way to disable the fax function? We are unable to print nor to copy. Machine keeps on wanting to print a fax report which gets consistently jammed in the machine. We barely use the fax anyway and disabling this function (rather than addressing the jamming issue which will require to get a technician "in") will help us in the short term. Please help!!
Thank you
  • nathalie504 Apr 24, 2009
    Thank you but the machine automatically set itself to the fax function, try to print the report and it gets jam again. I even turned off the machine off for a couple of days hoping that any jobs in memory would be deleted -even this has failed. There must be a way to disable the fax function. Thank you :-)
    Thank you for your prompt response.You are right, "fax" light is lit...
    The "stop communication" did not help me. A message popped up with "no communicating /standing files". As far as checking the RX button, there are indeed a list of 40 files / faxes that have been sent, but no where is a button to delete any of these files.
    In reference to post #1, the tray,. paper size etc... are properly adjusted. The jam takes place when the paper is being rolled around. It seems that there is a "tooth" that crumbles the sheet, resulting in a paper jam.
    Sounds like the best way to resolve this would be to re-set the software, but if this can be done by internet, can this be done over the phone then? Or you can e-mail me directly at Nathalie@somacreativegroup.com. Thank you for your help. This is MUCH appreciated
You can set the fax portion of the machine to manual receive like this:
"User tools"
"fax features" ok
"reception settings" ok
"switch reception mode" ok
"Manual reception" ok
"user tools" to exit
Thia will prevent the machine from picking uo any incoming faxes
....However, if the machine is jamming trying to print a 'fax' report, it will jam regardless of the feature you are using -they are unrelated. Depending on the cause of the jam, it could be a specific tray that is causing the problem, so you may want to remove the paper from that tray, and see how it works. The other reason, that is common for jams from one particular tray is that the size is set incorrectly. Check that the paper size dial on the tray is set for the appropriate size in the tray (including orientation).
If none of this helps, please describe the location of the jams, and I may be able to give further advice.
Posted on Apr 24, 2009
  • Anonymous Apr 24, 2009
    You must be talking about the "default" setting being set to "fax" as opposed to "copy". In other words, the "fax"light is lit. It matters not, what the default setting is, if there is something in memory, it will try to print.
    There is a way to reset the software in service mode, but it is too risky for me to post here...I'm sorry.
    You can try the following to wipe out the pages in memory, to stop the printing. I know this works from pages waitning to be sent; However not sure if it works for pages received in memory.
    First, after removing jam, leave paper drawers open to prevent reprinting, then press the "fax" button, press "Job information", press "stop communication", there would not show a "stop tx" (transmission) button if there were any messages waiting to be sent. My hope is that thee is a "stop Rx" button to delete anything that is waiting to be printed. If so, go through the files and delete them all. I hope this helps....Perhaps you should check the "tx" status as well, in case the machine is trying to print any kind of transmission result report (for example) if this feature is "eneabled"
    Again, as I said, you will still continue to have a misfeed problem, because there is something wrong somewhere - because paper feed problems are unrelated to the feature you are using. You didn't answer any of my questions in the first post about trying any of the suggestions. Please let me know if any of this helps.
    So the paper is jamming in the fuser, now we're getting somewhere. These machines have a little bit of history with "picker fingers". I'm sorry to say, that no matter what you do, you're not going to be able to get a piece of paper through this machine until the fuser is serviced, and the picker(s) replaced.
    You'll have to call a tech.
    If by chance, you're in the Toronto (Canada) area, I can help you, otherwise call someone local.
    Good luck :)
How to disable the fax?
Use a cancel button. Press the button for another function (copy scan, print pictures from a flash card. Turn machine OFF and ON again. If the telephone line is not connected to the MFC, the fax will not work.
Oct 13, 2013 | Brother MFC 7420 All-In-One Laser Printer
Error 388 when trying to send a fax
The local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames. If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Dec 17, 2010 | HP Photosmart C7250 All-In-One Thermal...
Unable to do fax can print but unable fax
Canon PIXMA MP250 series serves with PRINT + SCAN + COPY function. No FAX function
Jun 10, 2010 | Canon Pixma Mp250 Allinone Inkjet Photo...
Unable to receive faxes
Make sure its set to fax only by pressing the function button and then recieve mode!Keep pressing recieve mode untill it says fax only and press set/ok!Try cleaning the big grey roller at the back of the machine!Good Luck!
Apr 13, 2010 | Canon FAXPHONE L80 Laser
Error 388 keeps coming up
Solution:
http://h20000.www2.hp.com/bizsupport/Tec... Source(s): http://h20000.www2.hp.com/bizsupport/Tec... just try this out buddy
Jul 02, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Brother fax 560
Try this: Press MENU, select FAX, then scroll down to REMAINING JOBS. If any jobs are displayed , you can choose to print them. To print from the fax memory, first exit out of the MENU functions totally. Then, press MENU,2,5,4. Next, press START. After all faxes in memory have printed, press STOP/EXIT button. Check REMAINING JOBS again, if it is clear, fax memory should be clear, Also.If the fax machine has a PRINTER function, press the JOB CANCEL button to clear the print Queue.
Apr 15, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
When I turn on the printer "Download Mode" appears on the lcd screen.
The machine might be trying to download the latest firmware wait a few minutes it may go if not it is it the user manual under on screen messages.
Thanks J
Sep 13, 2007 | Sharp AL-1661CS All-In-One Laser Printer
174 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
