Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
I have a Sting trimmer Model # TB42CS 4 Cycle, It starts and every time I press the lever to run the attachment it turns over then it just dies and then it takes a few pulls to start again the I go threw the whole process again ( as long as I don't try and run the trimmer, tiller ... attachments it will stay running)
  • 246 Answers
Hello wds8of10:
From your Description it Sounds like the Exhaust Port or Muffler is Restricted with Carbon Deposits, the Carburetor Metering Pump Actuator Gap is Incorrect.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
Is the Fuel Line from the Fuel Filter Staying Full of Fuel?
The Carburetor Metering Jet Actuator is Set so the Pump Diaphram Dowl is Just Touching the Actuator Arm. These Components are Located Under the Cover with 4 Small Screws Holdong it to the Carburetor Body.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
TB425CS
can u explain little bit clearly?
Sep 28, 2008 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Craftsman 25cc weedwacker (358.791030). Zama carburator (C1U-W19) Just rebuilt carb but did not adjust low speed/high speed screws. Starts on first pull (with choke lever actuated), and after warm up,...
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Sep 17, 2010 | Craftsman 25cc Gas Line Trimmer
Trimmers floods its self, will not stay running
It is unusual for a trimmer to flood itself. It is common to have a lean condition diagnosed as rich.
So lets start by seeing if its lean or rich. Get unit running and apply as much throttle as possible and keep unit running then slowly close the choke. If unit starts to run better as choke is closed then it is lean. If unit dies immediately and is hard to start again it may be flooded.
4 possible reasons for flooding...
1. piece of debris in inlet needle, needle lever adjusted too high
2. adjustment screwd turned too far out
3. exhaust screen clogged
4. low compression
If unit has a stuck inlet needle it will flood while engine is off and be very difficult to start- remove fuel source and/or turn adjustment screws all the way in and pull rope until unit starts ( 4 or 5 times)
clean the carb, screws should start at 1 and 1/2 turns out on the low and 1 turn out on the high.
clean the screen.
If the unit has low compression it is not worth repairing- the cost of repair will exceed the cost of replacement.
Jan 02, 2010 | Homelite Mighty Lite Lawn Trimmer
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
New TB70SS used one hour run great started easy. Following week started on run fine for 10 minutes it became sluggish and died. Has not started since. Yes new gas correct mix. check spark arrester for...
If the trimmer is new and giving you these problems, then take it back to the retailer and either trade for another one, or pay a little extra for a 4 cycle. The 4 cycle is a little hard to start too, but will run out perfectly and no more mixing of oil.
The higher price tag is well worth the time, effort and aggrivation experienced versus a 2 cycle engine.
I hope this helps.
Jul 05, 2009 | Troy Bilt Tb70ss Gas Trimmer
The weedwacker dies when I squeeze the throttle trigger
You need to clean the carburetor. Remove and disassemble carb. Use a den Tek Brush, (used to clean between teeth), to clean the small portals in carb. Use a carb. cleaner while cleaning. Make sure the small screen in carb. is free of debris. The smallest of paticles can cause the carb. not to run right. Reassemble the carb. and try starting. If there is no change, then you will need to buy a carb. kit for your trimmer. Replace all appropriateparts: gaskets, diaphragm, needle valve, and the small screen.
Jim
May 30, 2009 | Craftsman 25cc Gas Line Trimmer
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
324 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
